Bilstein 4600 Upgrade
Discussion in 'Suspension' started by YucaTT4, Jan 22, 2020.
  1. Jan 22, 2020 at 7:59 AM
    YucaTT4
    YucaTT4 [OP] New Member
    2018 Limited Tundra 4x4 FFV Silver
    NONE...YET
    Looking to know what difference I can expect if I upgrade my stock 18 Ltd CrwMax shocks to the yellow and blue Bilstein shocks, front and rear, that come on the TRD Off Road packages?
    -Will there be a height difference? Not looking to get a lift
    -Will the ride be smoother, or rougher?
    I am a novice when it comes to suspension.....really, any modification for that case
    I have someone selling front and rear shocks that came off of a 2016 CrwMx TRD Off Road
    2-Part Nbr: 48530-0C041
    2-Part Nbr: 48510-0C041
    Do these look good?
    If they came off of a 2016, would they fit my 2018?
    Thanks
    YucaTT4
  2. Jan 22, 2020 at 8:03 AM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    Yes, they will fit the '18 and will not add any lift. It's oem upgrade replacement.
    YucaTT4[OP] likes this.
  3. Jan 22, 2020 at 8:09 AM
    YucaTT4
    NONE...YET
    I appreciate the verification. Would you be able to tell me, by looking, if these look good?
  4. Jan 22, 2020 at 8:11 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    No lift. Unless spring droopage.
    Will probably ride a bit stiffer going from limited to the TRD 4600's.
    Looks are deceiving. Looks fine, but seller could've wiped then clean and polished them up. Hopefully seller isn't an Ahole. The fronts are missing the top plates, so you'll have to break your front's apart.
  5. Jan 22, 2020 at 8:14 AM
    YucaTT4
    NONE...YET
    Sounds good, I appreciate the insight. Just looking for a good, cheap, mod to pop my cherry. :fingerscrossed:
  6. Jan 22, 2020 at 8:17 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    ... and I wouldn't pay more than $200 - 250ish for the 4600's. You can grab the adjustable 5100's new for $350ish range off Amazon.
  7. Jan 22, 2020 at 8:19 AM
    YucaTT4
    NONE...YET
    Getting all 4, with springs, for $100 from someone I know.:bananadance:
    Rex Kramer likes this.
  8. Jan 22, 2020 at 8:23 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    That's always the best. I have quite a few Tundra buddys that don't like to wrench, but have too much money. I have their take off parts to refresh mine.
    YucaTT4[QUOTED][OP] likes this.
  9. Jan 22, 2020 at 8:24 AM
    BigSkyTaco
    BigSkyTaco Successfully Social Distancing since 1998
    Aaron
    W. Glacier, MT
    2011 White DC Tundra TRD
    How much are they selling them for. Depending on price, i would go with 5100s and be able to level out the front.
    The 4600 really aren't much of an upgrade. Especially if you are paying for install and alignment...
    14CRWMX likes this.
  10. Jan 22, 2020 at 8:27 AM
    YucaTT4
    NONE...YET
    Plan on doing these myself at a buddy's garage. But you are correct, not much of an upgrade, but looking forward to the shocks.
    BigSkyTaco[QUOTED] likes this.
  11. Jan 22, 2020 at 9:28 AM
    jtaco11
    jtaco11 New Member
    it is a pain in the butt to manually compress coils with tool from auto part. plus if you plan on using your old top mount that's 4 coils need to compress!
  12. Jan 22, 2020 at 10:43 AM
    YucaTT4
    NONE...YET
    I did not think of that. I will have to find me a local shop that can help then. Thanx!
  13. Jan 22, 2020 at 12:36 PM
    jtaco11
    jtaco11 New Member
    live and learn id did 2 tacomas coils and it took most of day i cant imagine on tundras. hardest part was getting into right position to crank the thing w just one person even w the tool coils end up getting scratched. the big shop compressor is way better
  14. Jan 22, 2020 at 1:21 PM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    My 18 Limited came with the 4600's that you are looking to buy. Do you not have them on your Limited??
  15. Jan 22, 2020 at 1:59 PM
    Boerseun
    Boerseun MGM XP-Series
    Ferdie
    Sarasota Florida
    Do you have the TRD package? From your avatar pic it looks like you have TRD Off-Road wheels. Not all Limiteds have the TRD package, in which case they do not have the 4600s.
  16. Jan 22, 2020 at 2:19 PM
    CavBluTundra
    Howard
    Yes, I do have the TRD Off Road package on my Ltd. Sorry, thought all LTD's came with it.
    Boerseun[QUOTED] likes this.
  17. Jan 22, 2020 at 7:36 PM
    YucaTT4
    NONE...YET
    no. I have a “non-TRD” limited.
  18. Jan 22, 2020 at 7:47 PM
    YucaTT4
    NONE...YET
    Since the shocks are not an issue, will I have Swap our tires? Or can I keep the limited 20 inch rim and tires I currently have on the truck?
