Billet oil filter cap with drain valve installation
Discussion in '2.5 Gen Tundras (2014-2021)' started by Inquiringone, Apr 16, 2020.
  1. Apr 16, 2020 at 8:47 PM
    Inquiringone
    Inquiringone [OP] -Blue N Blac- an a little chrome
    Ter
    NorCal 408
    Not many yet, mostly stock.
    https://jowettperformance.com/
    Here’s the parts I ordered.
    Drain & remove the stock filter housing, using this
    filter housing tool.
    Old pleated filter.
    New & Old housings. You need to remove the inner stem tube, spring and spring cup from old housing. I used a forked molding tool, you can use a flat blade screw driver too.
    The stem tube can easily be bent to remove. Be careful not to bend to much. Slight pressure should pop it out of its seat in old housing.
    The quarter size spring Perch is not used in the new billet housing. The new housing has a grove that the spring sets in. Put the spring & stem tube together and insert into new billet housing, use flat blade screw driver to help it seat in the housing
    Check fitment of stem tub, check diameter of stem tube top, mine was a little slippery and I dropped it on the floor which bent it slightly, but I fixed it.
    Test fit new filter element.A1292476-4BE9-44B1-9F0C-E54B8FF567A3.jpgInstall new ORing on filter housing, below the threads where it will screw back into the engine housing on engine.
    Smaller ORing will not be used. It’s for the old filter housing.DF98BBDA-891C-4CA1-B191-7AB2CC929250.jpg
    Fomoto drain valve came installed, but check it to make sure it’s seated, and in off position. The Fomoto valve has a nipple & cap in the kit. Both screw on the end of the valve. I used the cap for my install and will remove cap and place screw in nipple and rubber tube ( not pictured) to drain out oil from filter next oil change.
    I used some painters blue tape on the hex head where the socket will be used. (OCD kicked in so I wouldn’t scratch the housing). Time to put the new billet housing on the truck for the first time.
    Using the 2 1/2” socket and extension, ones a good time to recheck things just to be sure you assembled it right.
    Put small amount of oil on O Ring & screw it into engine block housing. Hand tighten till it stops turning. Use torque wrench to torque down to 18.0 ft pounds. B5D6ED00-74A3-4D1F-BF5B-35F605E4474B.jpg29D0E67B-4776-4576-8DAE-4E2594B57B72.jpg
    With Fomoto cap in place, recheck end cap. Hand tight, then used the “Vulken” death grip to verify it’s not going to fall off. No need to use plyers on it. It’s got an O Ring to help set it.
    I had already drained the engine oil & replaced the oil pan drain plug. Refill with 8 quarts 0-20 synthetic motor oil. Start truck motor and verify oil pressure on dash and look under truck to check your work.
    Wa-la your done.
    Modded my stock skid plate for access to the new oil filter housing
    It not perfect but functional
    it came out ok, next year I’ll buy new skids. At least I don’t have to take it off anymore. :rofl:
  2. Apr 19, 2020 at 10:01 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    I replaced mine with Jowett's kit a couple years ago. No leaks, fires or engine seize, so I'm calling it successful!:D
  3. Apr 19, 2020 at 8:43 PM
    lakenorcan
    lakenorcan New Member
    jon
    northeastern Pa
    2016 4x4 DC limited
    Leer cap, weathertech vent visors, & floor mats, interior LEDs, drone remote start, front camera, tinted glass, trd rear sway bar, Thule cross bars, morimoto hid headlights, morimoto led fog lights
    I was interested in purchasing the same setup. I sent him an email on 4/6/20 since that is the only contact method listed on the website. I have yet to receive any response from him.
    Inquiringone[OP] likes this.
  4. Apr 19, 2020 at 9:13 PM
    jre5490
    jre5490 Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    Has anyone had this installed on a truck with a TRD or RCI skid plate with the oil filter removal door? Does it fit through the little door just fine?
  5. Apr 19, 2020 at 10:21 PM
    Inquiringone
    Ter
    NorCal 408
    brian@jowettperformance.com
    I’ve now had both, but at separate times on my trucks history, weird how that worked out.
    I’m pretty sure that the Jowett filter housing will fit through the RCI or TRD skid plates I’d bet the opening is 3.0 to 4.0 inches wide
    I can tell you this it’s 2 1/2 inch socket to install/remove.
    I can call tomorrow to verify with RCI and I can measure jowetts housing. How about that.
  6. Apr 19, 2020 at 10:33 PM
    Inquiringone
    Ter
    NorCal 408
    there may be complications during the pandemic. :notsure: But it’s worth the wait. That’s my opinion sir.:oldglory:
    Prostar 190 likes this.
  7. Apr 20, 2020 at 5:45 AM
    jre5490
    jre5490 Rane
    Rane
    MS Gulf Coast
    2019 Tundra SR5 TSS
    Thanks! No need to call. The Jowett website was down last time I tried to look to see the size. I’m going to order a RCI skid plate but it will be next year before I do it. I just got this truck 2 months ago and I have 4 free oil changes from the dealership. Once those are used up then I’ll put the skid plate and the new cover on.
  8. Apr 20, 2020 at 8:11 AM
    Inquiringone
    Ter
    NorCal 408
    thanks :hattip:
  9. Apr 20, 2020 at 9:00 AM
    Inquiringone
    Ter
    NorCal 408
    For all skid plate owners;
    I’ve talked to RCI today about the inspection opening for oil filter.
    It’s 4 3/8W X 5 3/8L plenty of room for Jowett performance billet oil filter housing to move through that opening.
    As far as TRD skid plate opening,
    Can someone who owns one post the inspection plate hole size.
    I’m betting is very similar in size.
    Thanks in advance. :hattip:
  10. Apr 21, 2020 at 4:15 AM
    Philogynist
    Philogynist New Member
    NY
    To the OP, thanks for sharing this info. Nicely detailed.
    In the small plastic bag, taped to the cardboard, in the 1st post, there are three items.
    One is the DC-001 cap. The other is a H-001 Straight Hose End for 3/8" tubing.
    What is the third piece?
    Does it have an identifying part number printed on it?
  11. Apr 21, 2020 at 6:42 AM
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Yes, I have this exact setup with the RCI skid plate. It works great.
    I'm to the point I don't even lay old newspapers under my truck when I change the oil. I hardly drop any oil on the floor.
  12. Apr 21, 2020 at 8:23 AM
    Inquiringone
    Ter
    NorCal 408
    @Philogynist
    If the Fomoto valve is not used you can use the magnetic plug and crush gasket in place of it. 3/8 Allen wrench is used for tighten/ removal. The plastic nipple that comes with a new oil filter can be placed in the hole, same as the stock set up for oil drainage.
    The magnetic part is fairly strong to attract metal particles, that’s the crush gasket clinging to it. Great question.
    Cypher likes this.
  13. Apr 21, 2020 at 4:18 PM
    Philogynist
    NY
    Thanks for the prompt reply. I purchased the "Jowett" many moons ago but it's still sitting on my bench. Like others, I'm going to use my last dealer oil change then do the installation. I didn't get the fancy DC-001 cap or the H-001 Straight Hose End with my purchase as he was selling some "blems" at a discount. It did come with the EZ-105 drain valve and a suitable plastic cap.
    Again, great write up!
  14. Apr 22, 2020 at 10:38 AM
    Inquiringone
    Ter
    NorCal 408
    Thanks @Philogynist :hattip:
    Yep I was rewarded by my OCD.
    I’m now working on modifying my stock skid plate to create an inspection/service hole that mimics the TRD/RCI skid plate.
    I’ll post a picture of my mod.
    Dust off your trophy ( Billet oil filter housing) and look at it again. :fistbump::boink::rofl: Be safe out there Sir.
    Philogynist[QUOTED] likes this.
  15. Apr 25, 2020 at 5:00 PM
    rmvcard0303
    rmvcard0303 New Member
    Ray
    San Gabriel Valley, CA
    2019 White Tundra TRD Sport CM
    I’d rather not list. My wife might see it.
    Thanks for sharing! Will definitely add to the mod list since I’m not keen with Toyota’s 10k oil change schedule.
  16. Mar 7, 2021 at 9:14 AM
    Inquiringone
    Ter
    NorCal 408
    In case there’s questions on the Fomoto valve and the small nipple with O ring, IE: third piece in plastic parts screws in to outlet of Fomoto valve. When finishing remove and install black cap w/ O ring. Wa La... completed.
  17. Mar 7, 2021 at 10:11 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I wonder when Brian will be getting back to making these again. I have the metal housing from Toyota but those Jowett ones look pretty damn sweet.
  18. Mar 7, 2021 at 5:22 PM
    JMB711
    JMB711 New Member
    2020 Trunda SR5 Crewmax TDR offroad
    Running boards. Shaved vehicle emblems. TruXcedo low profile tonneau cover. LED interior lights along with cargo bay and reverse lights.
    Why, it looks great and its under the truck. Stamp TRD on er and spend the money on something else.
  19. Mar 8, 2021 at 4:56 AM
    mech_engineer09
    mech_engineer09 Tundra Enthusiast
    Ohio/Pennsylvania
    2020 MGM Platinum
    Ceramic Pro, XPEL Ultimate Plus, Woolwax Undercoating, Diamondback HD, TRD Air Intake, TRD Skid Plate, TRD Front & Rear Sway Bar
    I had the metal toyota one as well, but ordered the jowett performance one for my next oil change. The metal one is much better than the plastic pos that comes with the truck and mine was on for 20k miles no issues, but the jowett will just make changing the oil that much easier with about 0 chance of spilling any oil when you add this and the drain pan valve.
  20. Mar 8, 2021 at 8:04 AM
    CaptainGrumpus
    Maine
    That’s the same thing I’m thinking as well.
  21. Mar 8, 2021 at 8:14 AM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    Just installed mine this past weekend, it's been a pending item for a while for me -- I ordered mine a few months ago.
    After seeing how well the aluminum cap fit onto the end of the cap, I decided to place a second order, this time for the drain plug replacement (and an extra threaded nipple and 2 aluminum caps in case I lose one), and Brian actually refunded me a little bit because he was able to fit everything into a smaller package and get it to me via USPS Priority Mail!
    All in all, super solid product, and very happy with the fit and finish. Looking forward to not splashing this "black water" they call oil all over my tire when I pull the plug...
    CaptainGrumpus likes this.
  22. Mar 25, 2021 at 10:10 AM
    HONEYBADGER
    HONEYBADGER New Member
    Fox Coils Camburk Kinetik Uppers Stealth Customs Cooper AT3
    very nice
  23. Jan 6, 2022 at 11:33 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    2020 Tundra SR5 Extended Cab TRD Offroad Package 8ft. Bed
    Bilsten 6112's with 2.5" Front Lift w/Bilstein 5160 Rear Shocks
    Does anyone know if they still make these? I want to order one but it looks like they are out of stock and I emailed them 3 weeks ago and haven't gotten any response......
  24. Jan 6, 2022 at 11:48 AM
    2mchfun
    Might need to try and call them, been thinking it over myself since I also tried the site 2 days ago.
    Moe2o4[QUOTED] likes this.
  25. Jan 6, 2022 at 11:48 AM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    They have been out of stock since the summer.
    Moe2o4[QUOTED] and 2mchfun like this.
  26. Jan 6, 2022 at 11:49 AM
    Moe2o4
    Moe2o4 New Member
    Corey
    Got a phone number because I can't find any.....
  27. Jan 6, 2022 at 12:01 PM
    2mchfun
    Nope, unfortunate that it isn't listed on the site. I guess too many dumb question calls. Dude might be sick or dead, who knows. No worries, I have hand cleaner and a garage sink.
  28. Jan 6, 2022 at 12:04 PM
    Moe2o4
    Moe2o4 New Member
    Corey
    I agree but it would just be so much cleaner for a oil change. I just put on my fumoto valve the other day when I did my first change and also replaced that plastic filter housing with a metal one as well for now!
    2mchfun[QUOTED] likes this.
  29. Jan 6, 2022 at 12:09 PM
    jhardy1979
    jhardy1979 New Member
    Justin
    MGM 2015 Tundra Crewmax Limited 4x4
  30. Jan 6, 2022 at 1:01 PM
    Oats87
    Oats87 Dirt Rider
    Sunnyvale, CA
    A Non-Toyota
    I have the one from my old truck that I am planning on selling when I get around to it....
    To be honest, the MotivX kit that was linked is just as tidy at draining the filter housing (I also have and have used one of those kits). It has a clever screw mechanism for the filter drain so you aren't fumbling with the plastic drain nipple that comes w/ the new oil filters. I think a metal Toyota housing (I don't remember the part number) + the Motivx kit is pretty much just as good.
