Bigger tires
Discussion in 'Wheels & Tires' started by Junior4888, Sep 28, 2016.
  1. Sep 28, 2016 at 6:01 PM
    Junior4888
    Junior4888 [OP] 2007 Toyota Tundra Limited 4.7l
    Travis
    Moxee, WA
    2007 Toyota Tundra Limited Dbl Cab 4.7l
    My question is i want to fill the wheel wells a little better and maybe a little wider. looks like i have room to go to maybe a 33x12.5 but not sure.tmp_12310-20160924_1757041292320112.jpg tmp_12310-20160924_175728-105921686.jpg
  2. Sep 28, 2016 at 6:02 PM
    Junior4888
    Travis
    Moxee, WA
    But i don't want to change rims
  3. Sep 28, 2016 at 6:02 PM
    35" or :D
    R-C, Law323, Ardnut and 3 others like this.
  4. Sep 28, 2016 at 6:03 PM
    Junior4888
    Travis
    Moxee, WA
    lol i dont want to lift it any more. atleast not yet
  5. Sep 30, 2016 at 7:07 AM
    Junior4888
    Travis
    Moxee, WA
    looks like a 2 in level block in the front. My question is will 33x12.5's fit on these rims and not rub.
    bigoltater likes this.
  6. Sep 30, 2016 at 7:11 AM
    ToyotaTundraMike
    2015 Tundra
    Happen to know the specs on your rims? Offset etc.
    To run that wide of a tire more than likely all you will need is a cab mount chop, which isn't a huge deal. @Relentless sells them pretty cheap.
    I do know that the 275/70/18 fits perfectly and is taller than a 33 x 12.50, but not as wide.
  7. Sep 30, 2016 at 7:43 AM
    On a 2" level you should be able to clear 33". If not, it'll be minor trimming
  8. Sep 30, 2016 at 7:47 AM
    Junior4888
    Travis
    Moxee, WA
    not sure of the specs on the rim. It looks like thwy will fit as there is plenty of room.
  9. Sep 30, 2016 at 7:49 AM
    Junior4888
    Travis
    Moxee, WA
  10. Oct 7, 2016 at 8:52 PM
    Asutton
    Asutton New Member
    Andrew
    2008 Tundra Limited
    3" level in the front
    Put 35s on and make them fit if they rub. I have 35s with a 3" leveling kit and they fit fine
    Relentless and Junior4888[OP] like this.
  11. Oct 7, 2016 at 9:43 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    You could fit 275/70. To me those look great on a 2" lift and 295/70 to 35's look great on a 3" lift.
    Junior4888[OP] and jburson250 like this.
  12. Oct 12, 2016 at 6:18 AM
    Yotanoob
    Yotanoob New Member
    Luke
    2012 tundra 5.7l 4x4
    Nothing cool yet
    I've been thinking of throwing a 3" front 1" rear leveling kit on my 2nd gen. Are you saying I can fit 35's without trimming my fenders if I go with it?
  13. Oct 12, 2016 at 8:12 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    I've seen 34's go on with no trimming but 35's most likely will need it.
