Bigger Tire Size for current TRD Pro Rims 2019
Discussion in 'Wheels & Tires' started by Dtran, Feb 21, 2024.
  1. Feb 21, 2024 at 7:13 AM
    Dtran
    Dtran [OP] New Member
    2019 White Toyota Tundra TRD PRO
    Hello,
    Currently running stock tires and wheels for 2019 tundra trd pro. Wanting to go bigger tire size (possibly 35's) with current rim but not sure if I need a new upper control arm or what will be best feasible for this situation. Will this affect offset?
    I am planning to raise maybe 2 inches. Any suggestions? Thanks
  2. Feb 21, 2024 at 8:32 AM
    b6graham
    b6graham New Member
    2020 Voodoo 1794 RW Wheels 315/70
    Bob likes this.
  3. Feb 21, 2024 at 8:57 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    Ditto- 285/75-18 on stock wheels work great and are much easier to fit vs a 1250 tire. No UCA change, still as tall as 35s, but lighter and wont hit performance and MPG as bad as 35x1250.
    351250 will require different wheels with less offset or spacers, probably need UCAs, front bumper spacer, removal of mud flaps and maybe BMC depending on offset.
  4. Feb 21, 2024 at 12:19 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    x3 on the 285/75s...
    Additional areas to watch/test for rubbing (skid plate or sway bar in reverse at full lock) if you decide to go wider than the 285/75s
    Also, some tire brands are larger or more true to specified measurements than others, such as Mickey Thompsons, just FYI...
