Bigger gas tank ??
Discussion in '2.5 Gen Tundras (2014-2021)' started by MillsTRD14, Aug 27, 2016.
  1. Aug 27, 2016 at 8:46 PM
    MillsTRD14
    MillsTRD14 [OP] New Member
    Aaron
    2014 Tundra TRD
    Ba mufflers 7 inch, Bilstein 5100 TRD strut bar, Firestone adjustable ride rite airbags, tow mirrors , BFGoodrich ta ko2 33s, TRD shift knob, blacked out emblems, tundra Pro grill......
    Anyone got any ideas on a cheaper bigger gas tank ? I have the 2014 , only thing I don't like is small tank going on long trips . What's my options , would the new 2016 tanks fit on it ?????
  2. Aug 27, 2016 at 8:53 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Not cheap but you can get 46 gallon transfer flow tank.
    Relentless and SouthBoundSteve like this.
  3. Aug 27, 2016 at 9:08 PM
    The new tanks will fit, but you gonna shit yourself when the cost is seen.
    Your best option is the 46 gallon Titan tank.
    I tried to get around that issue with in bed mounted tanks that gravity fed into my factory one and I could not find a safe legal way without buying an external pump. That cost was more than the Titan tank.
    SouthBoundSteve likes this.
  4. Aug 27, 2016 at 9:25 PM
    Back in the day it was easy to get a bed mounted gas tank. 70's. I think I paid $150 for everything. 50 gallons. 1975 actually. Not now. No custom made anymore. Liability/legal issues. Titan tank^^^^^ as mentioned above or save a lot $$ and get some RotoPax fuel/water containers.
  5. Aug 31, 2016 at 1:46 PM
    Shawn850
    Shawn850 New Member
    Shawn
    Ontario, Canada
    2016 Tundra TRD Pro
    Custom Rock rails, ARE truck cap with Rhino-lining
    Toyota makes a 36 or 38 gallon for the 2016 Tundra. I don't see how it could be a problem for you to get one installed from them.
  6. Aug 31, 2016 at 3:39 PM
    bandit
    bandit New Member
    2011 Supercharged Mazzulla Long Travel Rock Warrior
    Duh Tundra
    This, I'm interested in. lol
  7. Sep 1, 2016 at 10:58 AM
    Shawn850
    Shawn850 New Member
    Shawn
    Ontario, Canada
    2016 Tundra TRD Pro
    The 2016 trucks have a 38 gallon tank as standard, I don't see how they won't install one for you after you buy it, although they would likely charge for labour.
  8. Sep 1, 2016 at 12:11 PM
    tundraplatinum2015
    tundraplatinum2015 New Member
    2015 Toyota Tundra Platinum Crewmax
    My '15 CM, fill up every 4 days, wish i have bigger tank.
  9. Sep 3, 2016 at 5:21 AM
    shreveporttundra
    shreveporttundra New Member
    Don't forget though, You still have 5 gallons when it says "zero miles to empty"
  10. Sep 3, 2016 at 5:48 AM
    jburson250
    jburson250 Pensioner
    Newmarket, NH
    14 Limited TRD Crew Max
    TRD Pro Suspension, Custom Audio System.
    Here's a TF tank for a '16 CM 4wd. You can select other configurations. If you live in CA, you can't buy it.
    https://www.transferflow.com/shop/product/0800114225?p=1&c=10&s=p-
    I've seen a couple members on TundraTalk post about installing - maybe here, too. Try a search.
    I doubt it's a driveway job.
  11. Sep 6, 2016 at 1:10 PM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    Have you remedied this? I have the same issue. I just relocated to Southern California and if I drive my truck to work, it's 72miles one way :facepalm::help:
  12. Sep 6, 2016 at 1:20 PM
    Relentless
    Relentless Eric @Relentless Fab Vendor
    Eric
    East of the Sierras(Reno), Nevada
    '14 Crewmax TRD 4x4> '15 Duramax SLT
    Just a few, more to come
    Running the 46 Gallon TranferFlow tank and havent looked back. Good investment of $1200 IMO, especially if you do it when the truck is new and keep it a while and drive a lot.
    When towing and getting 8mpg the stock 26gallon (20 gal to fuel light) tank goes by way too fast, especially in rural areas like out here crossing NV to UT or AZ. My 46 gallon tank has impressed with range when towing and even better when empty. Fuel light comes on around 39 gallons, multiply by my 8mpg towing and my 16 cruising empty(lifted on 35's) and I get 312 and 624 miles. Pretty respectable range
