Big SAG in Rear After hooking Travel Trailer
Discussion in 'Towing & Hauling' started by Seadawg1, Jul 1, 2020.
  1. Jul 1, 2020 at 2:06 PM
    Seadawg1
    Seadawg1 [OP] New Member
    Larry
    Northwest
    2017 Gray Toyota Tundra, DC, SR5, TRD PRO
    I tried to find this subject conversation but could locate it. I purchased a 2017 Tundra SR5, TRD Pro. I noticed that it was not level when connecting my travel trailer. SAG in the rear, Would Tembrems/Sumo Springs work at leveling or should I have air bags installed? I did not have this issue with my 2007 Tundra SR5.
  2. Jul 1, 2020 at 2:24 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    What size trailer and are you using a weight distribution hitch?
    Medic343 and GODZILLA like this.
  3. Jul 1, 2020 at 2:28 PM
    Seadawg1
    Larry
    Northwest
    I am towing a 28 ft. gross weight 7600 lbs. Though never near that weight. I never travel with my tanks empty. I use a Husky weight distribution system.
    ColoradoTJ and Medic343 like this.
  4. Jul 1, 2020 at 2:34 PM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    The Pro has no rake like the SR5 did due to the lift/level in the front.
    I'm not a huge fan of using airbags on a WDH but if you're not willing to do shackles in the rear to add a little rake, then bags would be the way to go. Make sure that the WDH is calibrated and adjusted for ride height with the bags inflated. Measure your ride height once inflated and always air up to that. You won't be able to use PSI as a gauge due to different loads.
  5. Jul 1, 2020 at 2:37 PM
    Seadawg1
    Larry
    Northwest
    Not to sound ignorant, though I am on these matters, what does rake mean?
  6. Jul 1, 2020 at 2:39 PM
    19TurdPro
    2019 Tundra TRD Pro
    The degree or amount at which the ass sits higher than the front. Your Pro is level. Your SR5 sat about 2.5 inches higher in the rear than it did the front.
  7. Jul 1, 2020 at 2:41 PM
    Seadawg1
    Larry
    Northwest
    Thanks for that info.
  8. Jul 1, 2020 at 2:56 PM
    Bad Cow
    Bad Cow GOD Bless The USA
    Georgia USA
    2019 TRD PRO - SUPER WHITE
    Leather Steering Wheel, +1.5" Shackles
    Yea man, the PRO's sit WAY too level for my taste. Fixed mine by installing +1.5" shackles, DONE. Now it has the perfect amount of rake, and sits almost level when towing. Shackles are the way to go, in my opinion. Rides same as before, smooth as silk.
    MTRock and Seadawg1[OP] like this.
  9. Jul 1, 2020 at 3:42 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    You probably need to check the set up on your WDH. A good WDH will neutralize any sag by transferring tongue weight to the front axle. Sounds like yours isn't doing anything. Measure the height of the rear bumper or rear wheel openings. Your objective should be no change in height.
    You should also determine your actual tongue weight with the RV loaded as you use it; how the trailer is loaded can drastically affect the tongue weight.
    Buckaroo likes this.
  10. Jul 1, 2020 at 5:38 PM
    palehorse
    palehorse @grey_ghost_trdpro
    Mount Pleasant, SC
    2020 TRD PRO
    I've never heard of an SR5 Trd Pro.
  11. Jul 1, 2020 at 5:44 PM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    Never mind, I looked at your pic. You do not have a Trd Pro therefore do not have the Pro suspension that is softer. Your truck should also have the standard rake.
    Regardless, 7600# is pretty damn heavy but it comes down to tongue weight.
    BravoDeltaRomeo likes this.
  12. Jul 1, 2020 at 5:51 PM
  13. Jul 1, 2020 at 7:11 PM
    Seadawg1
    Larry
    Northwest
  14. Jul 1, 2020 at 7:13 PM
    Seadawg1
    Larry
    Northwest
    I hate to break it to you but it is a SR5 with the TRD Pro package. The sales paper say it, the side of the truck it has both SR5 and TRD emblem.
  15. Jul 1, 2020 at 7:19 PM
    Seadawg1
    Larry
    Northwest
    It is a SR5 with a TRD Pro it is on the original manifest and also the dealership sales paperwork. There is a SR5 and TRD Badge. I usually am in the 6600 lbs range when I tow my trailer. It is 5600 lbs dry weight.
    Cpl_Punishment likes this.
  16. Jul 1, 2020 at 7:23 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    OP is right, the TRD Pro is just a dressed up SR5.
    BravoDeltaRomeo, Bad Cow and landphil like this.
  17. Jul 1, 2020 at 7:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    If you don’t have the “TRD PRO” stamped into the sides of the bed, you don’t have a Pro. I don’t care what your ‘sales paper’ says.
    palehorse likes this.
  18. Jul 1, 2020 at 7:26 PM
    AZBoatHauler
    So.Arizona
    I think he is in Canada and trim options may be different north of the border.
  19. Jul 1, 2020 at 7:28 PM
    JimboSlice413
    JimboSlice413 Super Nice Guy
    Bakersfield
    2016 Limited 4x4, 2003 Sequoia
    Bilstein 5100/5160 Toyo at2 295/70r18 Ray10 GunMetal
    What he means to say is you have the trd package. A PRO is not a package you can add, it is the trim of the truck
  20. Jul 1, 2020 at 7:36 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
  21. Jul 1, 2020 at 7:48 PM
    JimboSlice413
    Bakersfield
    I see what you're saying. I checked out the Canadian Toyota site. Still though, adding the TRD Pro completely dresses the tundra like the PRO we see here in the states, FOX shocks and all. Clearly OP does not have that option.
  22. Jul 1, 2020 at 7:55 PM
    19TurdPro
    2019 Tundra TRD Pro
    I should have looked at the pic. Looks like he has a TRD off road. In that case, unless the front end is leveled you should have some rake. If it's sagging a lot without a level up front, I'd check the setup of the WDH. You may not have the right torsion bars or tension in them for your setup.
  23. Jul 1, 2020 at 7:57 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    How can you tell?
  24. Jul 1, 2020 at 7:58 PM
    JimboSlice413
    Bakersfield
    +1 on checking the WDH, shouldn't have too much sag issues with that weight if its properly distributed
  25. Jul 1, 2020 at 7:59 PM
    JimboSlice413
    Bakersfield
    The wheels, the rake, no stamp, no blacked out emblems, chrome rear bumper, chrome front bumper
  26. Jul 1, 2020 at 8:43 PM
    Depending on what Husky WDH you have could make a difference (what weight is your bars?). Also, what year, make/model travel trailer do you have? This would help a lot.
    At ~10% tongue weight, you will already be at 760 lbs.
  27. Jul 2, 2020 at 5:33 AM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    Wrong.
  28. Jul 2, 2020 at 5:34 AM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    Wrong.
    Maybe TRD Offroad, maybe TRD Sport, but def NOT TRD PRO.
    Pro's don't have an "emblem" or a sticker. They have TRD PRO stamped in the steel on the side of the bed. They also don't have any chrome.
    Olson likes this.
  29. Jul 2, 2020 at 7:52 AM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    So what interior features does it have that you can't get on other SR5 trims? 20200701_203543.jpg
  30. Jul 2, 2020 at 7:56 AM
    palehorse
    Mount Pleasant, SC
    2020 TRD PRO
    TRD PRO leather interior and emblems.
    A trd pro is not a "dressed up" SR5 no more than a Platinum is a dressed up SR5.
    Sorry, but that screenshot you have is misleading. TRD PRO is not an add on package much like 1794 isn't an add on package. Completely different truck made in limited numbers.
    Primary reason I chimed in is bc the Pro has a different suspension that the SR5. It's softer and has more articulation, and have a near zero rake, both of which makes it squat more when towing.
    https://www.toyota.com/trdpro/
    Olson likes this.
