BFG KO2 Tire size
Discussion in 'Wheels & Tires' started by mbcross, Oct 22, 2017.
  1. Oct 22, 2017 at 4:56 PM
    mbcross
    mbcross [OP] New Member
    2017 CrewMax
    What size KO2s are you guys running? Wanting to upgrade my stock tires on my 17 CM.
    Rica25 likes this.
  2. Oct 22, 2017 at 5:00 PM
    MotoTundra
    MotoTundra The Ocho
    Don
  3. Oct 22, 2017 at 5:14 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
  4. Oct 22, 2017 at 5:37 PM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    I’m running 35x12.5x18
    Rica25 likes this.
  5. Oct 22, 2017 at 5:49 PM
    mbcross
    2017 CrewMax
    Looks like my only option is going to be 275/70/18 and keep the stock wheels. At least It'll be a little taller!
    Rica25 and PermaFrostTRD like this.
  6. Oct 22, 2017 at 5:54 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    25,000 miles on 285/55/20 and i wish i would have gone a little taller. likely will next set.
    NewImprovedRon and Rica25 like this.
  7. Oct 22, 2017 at 8:03 PM
    Beaverscott1
    Beaverscott1 New Member
    Scott
    Renton Highlands
    2017 tundra trd pro
    Nothing wrong with the 275/70/18E127B8D1-0BD3-4A42-A6BB-2A0B7C457B3F.jpg
    Hbjeff, Rica25, Tundra805 and 6 others like this.
  8. Oct 22, 2017 at 8:05 PM
    mbcross
    2017 CrewMax
    Thanks! That's what I'm looking for. They look really good on yours. Any fitment issues?
    Beaverscott1[QUOTED] likes this.
  9. Oct 22, 2017 at 8:11 PM
    Beaverscott1
    Scott
    Renton Highlands
    2017 tundra trd pro
    There was just a slight bit of rubbing on the front mud flaps when backing up while turning sharp. I just removed the two front mud flaps via 2 screws each and problem solved. My wheels do have less offset though. Stock wheels at +60 offset are said to have zero rubbing while my aftermarket wheels are at +25 offset. You can see in the picture how close the front tires are to the front bumper and those little front mud flaps that hang fron the front bumper. That pic was taken before I removed those front flaps.
  10. Oct 22, 2017 at 8:14 PM
    mbcross
    2017 CrewMax
    Yea I figured I'd have to remove the front mudflaps. No big deal though
  11. Oct 22, 2017 at 8:47 PM
    BOBONTUESDAY
    BOBONTUESDAY Grocery Getter
    2016 Limited Trd
    275/70r18 ko2s
    Fit with no mods on trd off-road wheels.
    In that pic I've got a little lift.
    Tundra805 likes this.
  12. Oct 23, 2017 at 2:54 AM
    nick2010tundra
    nick2010tundra New Member
    Nick
    New Brunswick Canada
    2017 Tundra trd crewmax White ( My dream truck )
    275/70/18
  13. Oct 23, 2017 at 4:27 AM
    Borgs
    Borgs New Member
    PA
    IMG_6757.jpg 275/65/18
  14. Oct 23, 2017 at 4:41 AM
    easleycrawler
    Travis
    Easley, South Carolina
    17 Tundra SR5 DC Black 5.7
    285/55r20 ko2's.
    NewImprovedRon and JGDarcy like this.
  15. Oct 23, 2017 at 5:38 AM
    mbcross
    2017 CrewMax
    Love the Red TRD caps! Where'd you get those?
  16. Oct 23, 2017 at 7:48 AM
    Borgs
    Borgs New Member
    PA
    Ebay. I believe @Roman has them too.
    Roman likes this.
  17. Oct 23, 2017 at 8:24 AM
    mbcross
    2017 CrewMax
    I'll check into that, thanks!
  18. Oct 23, 2017 at 8:40 AM
    PermaFrostTRD
    Northern NY
    Look at
    305/65r18. ½” more diameter and 1.2” wider (won’t be that much wider on a stock rim).
    I have the 275/70r18 and wish I did the 305’s. 2-3% of the time that I look at my truck my tires just seem too skinny. But the rest of the time I’m happy with them.
    I have zero rub with my current setup (stock trd off road suspension). No mudflap or liner adjustment. I’d expect a little of adjustment with 305’s but not much)
  19. Oct 23, 2017 at 8:46 AM
    mbcross
    2017 CrewMax
    I thought about 305's but theres just really not enough of a difference other than width. Wish they made a 295 in the KO2!
  20. Oct 23, 2017 at 8:47 AM
    PermaFrostTRD
    Northern NY
    Yeah. That’s why I like them with a stock suspension. Toytec makes urinal cake spacers that give you ½”-¾” lift. Might run those if the 305’s rub.
  21. Oct 23, 2017 at 11:47 AM
    Flyinryank
    Flyinryank New Member
    Ryan
    Las Vegas, NV
    White 2015 CM 4x4
    305/65R18s on Method NVs
  22. Nov 3, 2017 at 6:21 PM
    MarkM0369
    MarkM0369 New Member
    Mark
    2017 Tundra SR5 4x4
    275/70 KO2, Pro Hood Bulge and grille, OEM fender flares, Fox rear shocks
    275/70/18 no lift. It was funny though, pricing them out, this actually was one of the cheaper sizes, one or two sizes different was a pretty good price jump
  23. Jul 10, 2020 at 1:31 PM
    Scavezze1971
    Scavezze1971 New Member
    Greg
    2018 SR5 Plus TRD Off-road (Canadian)
    I would love this setup. I am looking at doing a Readylift 3/2 leveling kit. Would I need a body mount chop to get them to fit? Man, I wish they made a 295/70/18....
  24. Oct 31, 2020 at 9:56 PM
    Konrad2004
    Konrad2004 New Member
    What is the max fitting KO2 tire for stock lower tier SR5 ? (No lift)
    Factory tire size 255/70/R18
  25. Oct 31, 2020 at 10:22 PM
    Maple85
    Maple85 New Member
    275/70/18. Might have to bend skid plate just a tad. Took me about 10 seconds. Everything else clears perfect.
    Konrad2004[QUOTED] likes this.
  26. Nov 1, 2020 at 1:07 AM
    Doxiedad
    Doxiedad Distinguished Member
    James
    Charleston, SC
    2020 Tundra SR5 TRD Off Road Cavalry Blue
    I stayed stock 275/65/18. Didn't want to have to worry about clearance. No plans for a lift
  27. Nov 1, 2020 at 1:17 AM
    the ER kid
    the ER kid New Member
    2020 Platinum Crewmax
    285/60R20 with leveling kit
  28. Nov 1, 2020 at 2:35 AM
    Haggis777
    Haggis777 I.L.J.C.M.L.
    SW Michigan
    2015 Silver SR5 TRD Tundra Canadian Model
    LEDs interior & exterior, stubby antenna, Bak-Flip cover, 285's, AGM battery, block heater, Pine tree air freshener
    285/65R18, no lift.
    I bought my 2015 previously-owned in 2018 with 19,700 miles, pretty sure these have been on the truck since 2015 looking at the dates of the tires. ~33,000 miles now.
    They look tough as nails which I like, but I agree with @treihing.
    Loud road noise and stiff ride. Not a lot of traction on wet roads either.
    I bought a Sierra back in 2003 that had them also. Replaced them with Mastercrafts after they wore down. No regrets in not going back to KO2s.
    I don't off-road, but need snow-ready traction in the winter here in Michigan. Am thinking of going down to 255's in Pathfinders, Wildpeaks or Grapplers in 2021.
    Am open to comments/opinions on any of these three! Thanks!
  29. Nov 16, 2021 at 2:57 PM
    myGreenMachine
    myGreenMachine DeChromed
    scott
    Bend, Oregon
    2021 Tundra Limited
    looking here for ideas and instruction...
    been over a year since anyone has responded to this thread..... wondering if 35 12.5 18 would fit on the TRD BBS rims on a 2021 Limited that is lifted 2.5".... anyone have any experience? Thanks!
