BFG KO2 or Toyo AT2 275/70r18?
Discussion in 'Wheels & Tires' started by 14TundraSR, May 1, 2019.
  1. May 1, 2019 at 11:45 AM
    14TundraSR
    14TundraSR [OP] New Member
    Kevin
    2014 Tundra Double Cab SR
    Looking for input on my next tire purchase. Currently I’m running 275/70r18 BFG All Terrain KO2’s. This is probably the 8th set I’ve run in my lifetime. Great tires, however this set seems to be wearing more unevenly than some of my previous sets. I’m driving a 2014 SR Double Cab 4x4 currently at stock height but plan on adding Bilstein 5100’s with front at middle setting. I’d love to go up to a 34” tire, but feel like with the 4.6L I’ll be better of sticking with the 33” tires. I’m debating about staying with the BFG’s or trying the Toyo AT2’s. Specs are nearly the same except the BFG weigh 57.41 lbs per tire and the Toyo’s weigh 51lbs per tire. Wondering if that might help with power and MPG’s. Would love to hear input and see pics of similar setups. Thanks!
  2. May 1, 2019 at 11:50 AM
    taco supreme
    taco supreme New Member
    16 white CM 1794
    i had toyo at2 on my tacoma in the past. after 30k in, the wet traction was butt puckering.
  3. May 2, 2019 at 4:15 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    I would probably go with the KO2's, I think they look better.
