BFG KO2 275/70R18 on stock TRD Package Wheels
Discussion in 'Wheels & Tires' started by oul, Jan 7, 2017.
  1. Jan 7, 2017 at 5:48 PM
    oul
    oul [OP] Old New Member
    Larry
    Huntington Beach, CA
    2017 Tundra White SR5 TRD Off Road CM
    Is anyone running this set up? I looked at the tires today and compared them to my stock 275/65R18 and they are taller and a bit wider. I think they will be good for me. I would appreciate any thoughts.
  2. Jan 7, 2017 at 8:10 PM
    PermaFrostTRD
    Northern NY
    equin, Stroke250, 757TUNDRA and 4 others like this.
  3. Jan 7, 2017 at 9:08 PM
    SiLV3R
    SiLV3R New Member
    17 Silver Tundra
    Undercover Flex, Bedrug Liner, ESP Aluminum Storage Unit, Method NVs.
    Are you running them on stock suspension? Any rubbing or issues?
  4. Jan 8, 2017 at 1:39 AM
    PermaFrostTRD
    Northern NY
    Yes
    None so far.
  5. Jan 8, 2017 at 5:32 AM
    oul
    Larry
    Thanks for the reply. That is what I wanted to see. It looks like you have raised the front a bit? Truck looks good.
    PermaFrostTRD[QUOTED] likes this.
  6. Jan 8, 2017 at 9:11 AM
    PermaFrostTRD
    Northern NY
    Thanks man I appreciate it.
    The suspension is the stock/OEM trd off road package suspension. So no lift or level.
    IndianaGeologist likes this.
  7. Jan 8, 2017 at 1:57 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    I have them. 6112's on top setting up front. The stock TRD OR skid plate did rub at full lock both forward and reverse but I bent the ears and cleared the rub.. TRD Pro skid plate has no rub at all.20160507_113951.jpg 20161030_101546.jpg .
  8. Jan 8, 2017 at 2:54 PM
    oul
    Larry
    Thanks, I'm taking it all in for the final decision. Your truck looks good.
  9. Jan 8, 2017 at 4:17 PM
    dandailey
    Dan D
    Newport News Va.
    Thanks. I do love these tires.
  10. Jan 9, 2017 at 2:30 AM
    PermaFrostTRD
    Northern NY
    You have spacers?
  11. Jan 9, 2017 at 7:22 AM
    dandailey
    Dan D
    Newport News Va.
    Wouldn't ever run spacers.
    PermaFrostTRD likes this.
  12. Jan 9, 2017 at 7:51 AM
    Oregon Tundra
    Oregon Tundra New Member
    Michael
    Eugene, OR
    2016 Blue Pearl CM TRD 4x4
    Not quite the same set up, but pretty close. I'm running the cooper stt pro in that size. I also do have the truck lifted 2.5 up front and 1.5 in the back. I have slight rub at full lock on the skid plate. Easy fix though. So far I'm loving the setup. I've only had it for a week.
    Trstno1, BajaTurd, equin and 5 others like this.
  13. Apr 18, 2018 at 9:13 AM
    Mxhockey140
    Mxhockey140 New Member
    Anyone know if a SR5 w/out the TRD package will fit 275/70/18's with no lift or level?
    Y0TA PR0 likes this.
  14. Apr 18, 2018 at 9:23 AM
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Welcome!
    Mxhockey140[QUOTED] likes this.
  15. Apr 18, 2018 at 9:40 AM
    Borgs
    Borgs New Member
    PA
    Not your question but I have BFG KO2's in 275/65R18 (stock size). TRD off road, stock set up. Love the tires. I think @MotoTundra has the 275/65R18 as well.
    MotoTundra likes this.
  16. Apr 18, 2018 at 9:59 AM
    Mxhockey140
    Thanks ! Do you have any pics? Mine came stock with 255/70/18 so I think the 275/65/18 Will be a good upgrade and all it will probably handle.
  17. Apr 18, 2018 at 10:16 AM
    Borgs
    Borgs New Member
    PA
    MotoTundra and 757TUNDRA like this.
  18. Apr 18, 2018 at 10:40 AM
    Mxhockey140
    Thank you! Definitely pulling the trigger on 275/65/18.
  19. Apr 18, 2018 at 11:13 AM
    Borgs
    Borgs New Member
    PA
    Awesome. Just to be clear, lots of guys did 275/70/18 on here and love them. I decided to keep stock size 275/65/18, which are a little smaller, but love mine as well.
  20. Apr 18, 2018 at 7:34 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    @Borgs and I are almost twinning it....
  21. Apr 18, 2018 at 7:52 PM
    Borgs
    Borgs New Member
    PA
    Moto, you have exquisite taste in trucks.
    MotoTundra[QUOTED] likes this.
  22. Apr 18, 2018 at 8:26 PM
    equin
    equin Texarican Tundra
    Ed
    DFW, TX
    That's what I run. When I first got them, they rubbed bad on the forward front mud flaps at full lock in reverse. As the tread wore down, the rubbing became less. I've since removed the forward flaps and have no rubbing now. I also have aftermarket wheels (MB 352s) with +25 offset. So that might have contributed to the rubbing. I've heard of others with the same size tires on stock wheels at stock height with no rubbing, though.
  23. Apr 18, 2018 at 8:45 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    :rofl:as do you Sir!
  24. Apr 19, 2018 at 7:16 AM
    Jk78Limited
    Jk78Limited New Member
    2018 Limited Crewmax
    275 65 18s on stock suspension and wheels. Hope to do a level in the future E56F321A-EF5A-4BCE-846D-DDFB50CB5811.jpg
  25. Apr 19, 2018 at 8:02 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    275/70 18 Goodyear DuraTrac. Removed front mud flap, absolutely love them!!
    equin likes this.
  26. Apr 19, 2018 at 8:06 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Are those pro wheels or did you powderoat the trd's?
  27. Apr 19, 2018 at 8:08 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    yes, no change in ride height vs. the regular TRD package
  28. Apr 19, 2018 at 10:22 AM
    Borgs
    Borgs New Member
    PA
    PC. I did mine matte. @MotoTundra did his gloss black.
  29. Apr 19, 2018 at 4:31 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    Gloss black PC and TRD Pro center caps. I rocked Plastidip for a while and getting them PC'd was a great decision, I love the look now.
    Matte, semi gloss, or gloss all look great IMHO.
