BF Goodrich Tire size for 2019 TRD PRO
Discussion in 'Wheels & Tires' started by BryanJones365, May 8, 2023.
  1. May 8, 2023 at 5:11 AM
    BryanJones365
    BryanJones365 [OP] New Member
    2019 Toyota Tundra TRD PRO
    I just picked up a 2019 Tundra TRD PRO and it came with P275/65R18's on her. I plan on using the truck to tow a boat and need a more aggressive tire to adapt to the conditions here in Puerto Rico( i.e. sand, rock and on occasion, standing water. The boat ramp I will be using is actually just a beach so although there is rock underneath the sand, it still can get soft at times. Thank you in advance for any input. Cheers!
    iHacker likes this.
  2. May 8, 2023 at 6:23 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    So are you looking to upsize your tire and want to see the sizes you can get? BFGs are good for you since there isnt any ice and they do well in sand. You can get 275/70/18 no problem in load E and not worry about any fitment. You could go 295/70/18 and might have to run spacers and/or trim some plastic. Any bigger than that and its a crap shoot. You might be ok with 35s out the gate, but more than likely you will have to trim, get spacers if you are on stock wheels, dial in your UCA or get a new one entirely.
    bulldog93 likes this.
  3. May 8, 2023 at 6:33 AM
  4. May 8, 2023 at 6:50 AM
    bulldog93
    bulldog93 Usually tired...
    Jeff
    Santa Rosa, California
    2020 Super White CM Tundra TRD Pro
    285s with no shimming, rubbing, cutting, etc.
    iHacker and Luckydog like this.
  5. May 9, 2023 at 5:41 AM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    Stay with 285/70/18 on your Pro. That’s what I have and you won’t kill your power and gas mileage.
    Sierradevil and Luckydog like this.
