Better Braking Brakes! Easy!!!
Discussion in '1st Gen Tundras (2000-2006)' started by Professional Hand Model, Oct 18, 2018.
  1. Oct 18, 2018 at 4:17 PM
    Professional Hand Model [OP] A.K.A ‘Golden Hands’
    Hand Protectors
    Find your Load Sensing Proportional Valve (LSPV) adjust it up about 3/4” and it will shift your braking bias to your rear breaks. My 02’ adjustment was bottomed out (from factory) and the rear pads never wore down. Probably because the bias was towards front.
    Simple adjustment that requires loosening two nuts and raising the lever on the valve up. In my case, I adjusted UP 3/4” from absolute bottom. Now my braking distances have shortened. Truck squats a bit more in stopping versus diving/tipping.
    Thanks to @jberry813 for the tip!
    Here is a picture of the LSVP he posted in another thread.
  2. Oct 18, 2018 at 4:18 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  3. Oct 18, 2018 at 4:18 PM
    Hand Protectors
  4. Oct 18, 2018 at 4:19 PM
    Hand Protectors
    You beat me to it.
  5. Oct 18, 2018 at 5:10 PM
    jberry813
    jberry813 The Mad Scientist Staff Member
    Lake Tahoe
    2015 Tundra Platinum, 2012 Tacoma, 2007 T4R
    Metric shit ton of parts
    Nice! Glad it helped out @Professional Hand Model.
    Now that the bias is farther back, you'll be less likely to warp the front rotors too (which are frankly undersized for the first gens).
  6. Oct 18, 2018 at 6:08 PM
    15whtrd
    15whtrd Mr. Blonde
    0D2B7124-FC14-430A-A030-A30F35376846.jpg This nut? I wonder if this would work on my 03 sequoia. I have rotors not drums.
    NewImprovedRon likes this.
  7. Oct 18, 2018 at 6:10 PM
    Hand Protectors
    Yep. Check your manual, or look under the rear bumper for it located on the rear axle.
    15whtrd[QUOTED] likes this.
  8. Oct 18, 2018 at 6:14 PM
    jberry813
    Lake Tahoe
    I'm 99% sure there isn't one on the Sequoia. The brake bias is built into the master cylinder specifically cause it has calipers in the rear instead of wheel cylinders.
  9. Oct 18, 2018 at 6:25 PM
    15whtrd
    15whtrd Mr. Blonde
    Yep I just looked I don’t have one. Mine stops pretty good now that I’ve done all the brake work and upgraded the front brake hoses along with the new master cylinder.
  10. Oct 24, 2018 at 7:49 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I just checked my ‘05 DC with drums in the rear and didn’t see anything. What gives?
  11. Oct 25, 2018 at 4:07 AM
    Hand Protectors
    Looks like the bracket mount is still there? Where is the rest?
    jberry813 likes this.
  12. Oct 25, 2018 at 4:04 PM
    jberry813
    Lake Tahoe
    That's definitely a tundra axle based on the e-brake. But weird there is no bracket. Chase the soft line up to the driver's side frame rail. It should connect to a hard line. Hard line normally connects to the LSPV and two hard lines that run to the master. Even my 06 DC had it so I'm not sure why yours wouldn't.
  13. Oct 25, 2018 at 4:20 PM
    jberry813
    Lake Tahoe
    Wait a fucking second.
    With that zoom in I can see the bracket welded to the axle with this pic. I also see that you have some rather large blocks. A lot of guys that do drop brackets with massive lift blocks in the rear cut off the whole LSPV arm and zip tie the up to the frame so the arm is maxed out and get max rear brake pressure bias. You had a LSPV at one point.
  14. Oct 25, 2018 at 4:25 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    The truck has a 6" lift from RCD on it. I wonder if that messed with geometry and reach of the hardware/system and it required being moved. I'll post an update when I crawl under and have a closer look.
  15. Oct 25, 2018 at 4:31 PM
    jberry813
    Lake Tahoe
    That explains it to me.
    Definitely chase the soft line up and see if the LSPV is still there. Doubt they removed it, but you can remove the whole thing if you remove the return bias line and cap the T fitting that feeds the return bias line to the front brakes. That's what I did with my first gen taco and ran a Willwood proportioning valve for the rear bias on the pressure line.
  16. Oct 27, 2018 at 6:58 PM
    Outbound
    Aaron
    Northern Alberta
    I checked my '05 DC today and I have it. Someone stole yours.
    Casper421 likes this.
  17. Oct 30, 2018 at 11:52 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    I took a quick look late last night and didn’t see anything.:confused:
  18. Oct 30, 2018 at 1:22 PM
    MOTORHEAD
    MOTORHEAD New Member
    DAVID
    LOS ANGELES CA
    2002 Toyota Tundra SR5 V-8 4.7L WHITE
    RCD 6" SUSPENSION LIFT,ICON EXTENDED FRONT COILOVERS,3" BODY LIFT,CAMBURG UPPER CONTROL ARMS.REAR DISK BRAKE CONVERSION,BIG BRAKE FRONT CONVERSION, AND MANY MORE
    This is what it should look like . I have an RCD lift kit, and the extended bracket comes in the kit.
    NUDRAT and Brown Bear like this.
  19. Oct 30, 2018 at 1:59 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    It's interesting you have a T in your brake line and I've got two separate lines to the frame then to the front of the truck. I was wondering if anyone recognizes the block my brake lines run to in the upper left corner of my picture. The placement of the hard lines and holding brackets that run along the top of the cross member make everything look OEM.
  20. Oct 30, 2018 at 4:44 PM
    Hand Protectors
    Looks like the 05’ has two separate sub systems per manual. No mention of LSBP Valve.
  21. Oct 30, 2018 at 4:47 PM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    :notsure:
  22. Oct 31, 2018 at 4:32 AM
    Hand Protectors
    Thats the best I could do bud.
  23. Nov 5, 2018 at 9:29 AM
    Brown Bear
    Brown Bear New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    It's great to see a few other guys with the rcd 6 inch lift. Did you guys put on the lift after buying the truck or did you get the truck that way?
  24. Nov 5, 2018 at 9:30 AM
    Baller
    Baller New Member
    '05 Tundra SR5 DC
    My Tundra came with the lift already installed.
  25. Nov 5, 2018 at 9:37 AM
    Brown Bear
    Nor cal
    03 TRD offroad
    It's a great lift kit. That's a good find to get one already on the truck. What size tires are you running?
  26. Nov 5, 2018 at 4:48 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    No, I installed the rcd 6” lift kit myself and also replaced rear drum brakes with disk brakes. Way better
    Kevbev 7 and BestGen like this.
  27. Nov 5, 2018 at 5:17 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    What parts are needed(besides rotors,calipers)to complete the swap? Any pics? :thumbsup:
  28. Nov 5, 2018 at 5:26 PM
    MOTORHEAD
    DAVID
    LOS ANGELES CA
    MY PARTS ARE FROM A 2005 TOYOTA SEQUOIA. BRAKE ROTORS,PADS, BRAKE CALIPER BRACKETS AND HARDWARE. I INSTALLED DRILLED/SLOTTED ROTORS,CALIPERS WITHOUT PARKING BRAKE OPTION. I DONT REALLY NEED A PARKING BRAKE,SO I REMOVED IT. REALLY EASY TO DO . I GOT SOME CUSTOM MADE FLEXIBLE STEEL BRAIDED BRAKE LINE INSTEAD OF BENDING MY OWN STEEL ONES.
  29. Nov 7, 2018 at 6:10 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    WHY ARE YOU YELLING AT US? :D
    Tundra2, onesojourner, Sas and 2 others like this.
  30. Nov 8, 2018 at 3:57 AM
    Hand Protectors
    I WAS WONDERING THE SAME THING.
    Tundra2, onesojourner, Sas and 4 others like this.
