Best wheel material? Forged, steel or alloy.
Discussion in 'Wheels & Tires' started by Hi06silver, Jul 22, 2022.
  1. Jul 22, 2022 at 5:18 AM
    Hi06silver
    Hi06silver [OP] Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    Looking around at getting new wheels. I love the look of the trd pros and rumor has it that they are strong and light (according to toyota). Not really wanting to use spacers if it can be avoided. Do we have a thread on what is a superior material for wheels? I'm sure there are trade offs to every type just wanna here what ya'll think.
  2. Jul 22, 2022 at 6:57 AM
    Kur
    Kur New Member
    Mesa, AZ
    08, 5.7, Double Cab Tundra, White
    Steel is cool and all. If it gets bent you can usually bend it back and keep rolling. But literally every set of steel wheels I've had has gone out of round and made balancing impossible.
    Alloy is basically just cast aluminum. Great for most every day use, and most light to medium off-roading. But if it does get damaged/bent, is is pretty much done. Needs to be replaced.
    Forged is aluminum that has been, well, forged. Meaning it was hit with a big hammer which aligns the grain structure, increases density, some other nifty metallurgical things, and makes it stronger. Being a stronger material, you can use less of it, making forged wheels lighter, but not necessarily stronger than an alloy wheel. Of course, you can also get forged wheels that are stronger than alloy, but they will usually be heavier as well, unless some very clever geometry is used.
    At the end of the day you just need to decide what you want out of a wheel and pick what best matches your needs.
    snivilous, Sumo91 and Sierradevil like this.
  3. Jul 24, 2022 at 1:12 PM
    Sumo91
    Sumo91 Busy with projects
    TN
    2014 MGM Tundra Platinum 4x4
    I haven't read of am aftermarket wheel failure yet. Just pick what you like. I've been running Level8 MK6 wheels for 2.5 years now, heavy towing (near max towing capacity) and hard offroading. Also ramped my truck once (long story) they've been great.
    FrenchToasty likes this.
  4. Jul 24, 2022 at 2:12 PM
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    If you want to go exotic try these:
    Titanium - strong as steel half the weight, super expensive
    Carbon Fiber - super strong and rigid, good for racing, brittle so may be an issue on potholed streets
    Magnesium - exotic race wheel stuff of the 60s. Flammable as seen at LeMans. Alloys not so flammable but Mg is reactive and corrodes so wheel have a shelf life
    Forged Al alloys - great choice but expensive
    Cast Al alloys - OEM material of nearly all cars. Perfectly adequate for normal driving
