Best way to seal forward upper corners of bed
Discussion in '3rd Gen Tundras (2022+)' started by Rbtundra01, Apr 14, 2024.
  1. Apr 14, 2024 at 9:40 AM
    Rbtundra01
    Rbtundra01 [OP] New Member
    2023 tundra crewmax 4x4 sr
    Hi there, so I put a hard, foldable cover on the bed. Works fine and has a decent seal on it. When looking forward under the cover I can see some daylight in the front upper corners. Not between the cover and the bed, the corners of the bed body.
    Any thoughts on what material to use to seal?
    Thanks
  2. Apr 14, 2024 at 2:42 PM
    NoHater
    NoHater New Member
    Not exactly what you are referring to but there are small drain holes in the corners of the bed.
  3. Apr 14, 2024 at 2:52 PM
    SM Tundra
    SM Tundra New Member
    Cody
    2024 Limited Smoked Mesquite Tundra
    Butyl tape works very well for applications like this. It’s used a lot in marine applications so very good at keeping water out.
    dccrens likes this.
  4. Apr 14, 2024 at 2:57 PM
    JMB
    Chesapeake, VA
    2013 Super White Tundra DC
    Are you talking about the top of the tailgate?
    If so I found something recommended on here. I'll try to find out what it is.
  5. Apr 14, 2024 at 3:07 PM
    JMB
    Chesapeake, VA
  6. Apr 14, 2024 at 5:12 PM
    Rbtundra01
    Fixed to say front upper corners
