Best way to run lightbar wires?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Airbagged, Jan 9, 2016.
  1. Jan 9, 2016 at 5:57 AM
    Airbagged
    Airbagged [OP] New Member
    2015 Toyota Tundra TRD off road DC
    Camburg UCA Fox 2.5 front Fox 2.0 rear Timbren bump stops 20" wheels Coachbuilders shackles Coachbuilders tie rod ends 46 gallon transfer flow tank Flush bed cover Billet grill LED light bar front Led reverse lights TRD sway bar rear TRD cold air intake Locker down consol safe Towing mirrors Fender flares Magnaflow exhaust TRD shift knob Magnum running boards Paracord wrapped grab handles And more
    Recently installed a roof mounted light bar, still debating on the best way to run the wires.
    Down the windshield, or drill a hole in the roof ?
  2. Jan 9, 2016 at 7:14 AM
    TNTundra08
    TNTundra08 New Member
    Blake
    2008 DC 4x4
    3/1 lift. 20x9 Method standards, machine face. 305/55/20 nitto trail grapplers
    My first roof lightbar I was able to split the power wore insulation and I ran the red wire behind the water channel and the black wire inside. This hide the red color and made the black wire small enough to tuck inside it nicely and you couldn't see it at all.
    That one turned to crap, bought a new one and I didn't want to cut the insulation so I just put a huge amount of silicon inside the channel and pressed it the best I could in there. You would never really notice it unless you're trying to see it. It's definitely there but the channel and wore being black it blends well for my liking. I need to clean up my extra silicon but it's working as far as I'm concerned.
    I didn't want to drill more holes in my roof for my wiring, not to mention the plug on mine is so big I'd have to cut the wires and splice them back together inside the vehicle.
  3. Jan 9, 2016 at 7:16 AM
    TNTundra08
    Blake
    2008 DC 4x4
    So many iPhone auto correct mistakes but you get the idea, lol.
  4. Jan 9, 2016 at 7:22 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    I always wondered how people ran that wire. I would probably do the small hole and cut wires/splice together to get the cleanest look.
  5. Jan 9, 2016 at 7:49 AM
    Airbagged
    For now I have it attached with pads and tie raps, I have a couple water tight pass through fittings, just haven't brought myself to drilling a hole in the roof just yet.
    Black Wolf likes this.
  6. Jan 9, 2016 at 7:56 AM
    I was kinda wondering what was up. heh heh. Hate spell "correction"
  7. Jan 9, 2016 at 1:51 PM
    csuviper
    Broomfield, CO
    Saw someone today that just tucked it in the door and trimmed the weatherstripping where it sits. Inside it goes into the plastic on the column. Was on a 4Runner
    dcsleeper408 likes this.
  8. Jan 11, 2016 at 10:05 AM
    Airbagged
    This was my initial wiring setup to test the light and just keep the wire in place.
  9. Jan 11, 2016 at 10:08 AM
    Airbagged
    Now that I have the light all dialed in, I decided to finalize the wiring, and make peace with having to drill a hole in the roof of a brand new truck. I used a Marine cable pass through that has a water tight grip on the wire, and put a bead of sealant between the base of the fitting and the roof. The fitting is chrome plated brass, and I used rivets to tighten it down and keep it from vibrating loose.
    Halfjap, TruckLife900 and TNTundra08 like this.
  10. Jan 11, 2016 at 7:41 PM
    csuviper
    Broomfield, CO
    Nice. Much much much cleaner than the zip tie mounts.
