Best way to remove spare tire guide tabs?
Discussion in 'Wheels & Tires' started by silverhack, Jun 17, 2020.
  1. Jun 17, 2020 at 3:53 PM
    silverhack
    silverhack [OP] New Member
    Sacramento, CA
    2018 CrewMax Inferno
    What are the recommended ways to remove the spare tire guide tabs?
    I've seen a few posts mention:
    1) Cutting them flat using a sawzall or angle grinder cutting wheel
    2) Drill out the rivets the remove the entire tab
    Any other options or recommendations?
    I like the idea of #2 but I'm guessing it would be fairly difficult to drill through the rivets using just a battery/hand drill. Unless they are aluminum rivets, but I doubt it.
    GodlessPro likes this.
  2. Jun 17, 2020 at 4:25 PM
    What size spare are you trying to mount? I think some guys were able to bend the tabs a little. There is a thread on here somewhere about it.
    Pinay likes this.
  3. Jun 17, 2020 at 4:25 PM
    silverhack
    Sacramento, CA
    I have 295/70/18
  4. Jun 17, 2020 at 4:27 PM
    I'll keep looking for the thread.
  5. Jun 17, 2020 at 4:28 PM
    silverhack
    Sacramento, CA
    I saw the thread about bending it, but I think removing it might be a batter option. Just curious on the best way to remove them.
  6. Jun 17, 2020 at 4:28 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Try drilling them out
  7. Jun 17, 2020 at 4:29 PM
  8. Jun 17, 2020 at 4:30 PM
    silverhack
    Sacramento, CA
    Have you done it? How hard is it to drill the rivers? Just from looking at the size of them, I’d imagine there’s a good chance of destroying my wrist in the process :D
  9. Jun 17, 2020 at 4:31 PM
    silverhack
    Sacramento, CA
  10. Jun 17, 2020 at 4:32 PM
    GodlessPro
    GodlessPro Bougie BASTRD
    Matthew
    NorCal
    2018 Cement CM Limited
    I tried #2 and gave up before I made it through the first rivet and went with #1.
    Black Wolf, joonbug, Pinay and 2 others like this.
  11. Jun 17, 2020 at 4:34 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    No but I dont use that space and I've thought about it but right now I'm still in the maybe phase lol
  12. Jun 17, 2020 at 4:47 PM
    GodlessPro
    Matthew
    NorCal
    I'll give you a #3 just for fun.
    Box and brace your frame.
    W3agle, Black Wolf, joonbug and 2 others like this.
  13. Jun 17, 2020 at 4:48 PM
    EDDO
    EDDO                         
    Eric
    San Jose, CA
    19 OR MGM 5.7
    I drilled mine out and relocated. The drilling was as bad as people say. Quality drill bits and cutting oil. And a face shield. Still bad. But worth doing.
  14. Jun 17, 2020 at 4:48 PM
    silverhack
    Sacramento, CA
    Thanks for the real-world experience. I figured it would be a huge pain in the ass. I will probably just cut them off as well.
    ...I considered using a grinding disc to grind off the bottom of the rivet. That might work?
    GodlessPro[QUOTED] likes this.
  15. Jun 17, 2020 at 4:49 PM
    silverhack
    Sacramento, CA
    On one hand... I like your style. On the other.... oh god.
  16. Jun 17, 2020 at 4:49 PM
    TemujinNomad
    TemujinNomad New Member
    I cut them off with a dremel, smoothed down the sharp edges, and then applied spray paint.
    Black Wolf and silverhack[OP] like this.
  17. Jun 17, 2020 at 4:52 PM
    silverhack
    Sacramento, CA
    thanks, that’s good to know. I don’t think I’m convinced it’s “worth doing” :D
    If I ever get to that point, I’ll take it to a fab shop and have them drill it out and make a new bracket to install
    :spending:
    EDDO[QUOTED] likes this.
  18. Jun 17, 2020 at 4:52 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Bend them with a jack
    CaptRussia253 and silverhack[OP] like this.
  19. Jun 17, 2020 at 4:53 PM
    silverhack
    Sacramento, CA
    Oooo. The lazy turd in me likes the sound of that!
  20. Jun 17, 2020 at 4:54 PM
    GodlessPro
    Matthew
    NorCal
    Kind of defeats the purpose or your questions, since you'll have to put your spare in the bed, but come on all the cool kids are doing it.
    From @joonbug
    With the angle grinder that I have, it was difficult to get a good position. If you are able to get the disk in there it might be worth a shot.
  21. Jun 17, 2020 at 4:59 PM
    silverhack
    Sacramento, CA
    I’ve seen all the posts from Joon & Warren, and while I’m jealous, I also don’t have that kind of time or money. ...and also my wife would probably leave me
  22. Jun 17, 2020 at 5:02 PM
    GodlessPro
    Matthew
    NorCal
    Well fine then, have fun with your drill :rofl:
  23. Jun 18, 2020 at 7:44 AM
    mossmanfj40
    mossmanfj40 New Member
    Craig
    Pittsburgh, PA
    2014 Tundra CM 1794 version
    Toytec/Eibach 3/1, Vector 5 wheels with 295/70/17 Coopers
    Drop the spare, get a 5 pound hand held sledge and bang those brackets. Easy as hell and they still exist if you want to reverse the modification.
    W3agle and silverhack[OP] like this.
  24. Jun 20, 2020 at 7:23 AM
    Peteway
    Peteway New Member
    2019 5.7 CrewMax 4x4
    One thing to note is that if you have the TRD dual exhaust you WILL rub on the exhaust with the 295/70/r18's. Found that out the hard way just two days ago. I don't see a way around it with dual exhaust.
  25. Jun 20, 2020 at 7:45 AM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    I’ve been wanting to do this but those rivets are a pain. If they’re like the ones for the rear bump stops, I cut x’s on the heads and used an air chisel to knock them off. Then an air hammer to pop the rivet out.
    I think I might try this route since I have a dremel but no angle grinder.
  26. Jun 20, 2020 at 7:49 AM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    I haven’t had an issue with my 295 spare rubbing the exhaust. I guess I might if I finally cut those guide tabs off :notsure:
  27. Jun 20, 2020 at 8:31 AM
    Peteway
    Peteway New Member
    hmmm. Maybe I'll have to go check it out again and make sure I didn't do something stupid because mine wasn't even close. It hit the tabs and the exhaust at the same time with no wiggle room.
  28. Jun 21, 2020 at 6:31 AM
    Stig
    Stig New Member
    There was no way my 295 spare was fitting with the tabs in place.
    I drilled out the rivets. It's a pain but doable.
  29. Jun 21, 2020 at 12:58 PM
    silverhack
    Sacramento, CA
    I started grinding the rivets.... got impatient and just cut the tabs off with the sawzall. That was much quicker! :thumbsup:
    agunday21, GodlessPro and EDDO like this.
  30. Apr 22, 2022 at 5:13 PM
    matthaias
    matthaias New Member
    I have a hard learned respect for angle grinders and it didn’t look I could make a clean cut with a sawzall. I Decided to drill out the heads with a 1/4” bit, then chisel the heads off with a $10 harbor freight air hammer. After that I used the air hammer to punch the rivets out. It was really fast and I don’t have to superglue and major lacerations on my hand. It’s not that loud with earplugs under earmuffs :)
