Best Way to Read Coolant/Trans Temps Real Time?
Discussion in '2.5 Gen Tundras (2014-2021)' started by WrongWayDave, Oct 26, 2022.
  1. Oct 26, 2022 at 1:49 AM
    WrongWayDave
    WrongWayDave [OP] New Member
    Thank you SaltyHero13, I got the SG3 and it is an amazing piece of kit!
    Within minutes, have it set up temps to monitor for:
    Coolant
    Trans Oil 1-2
    Cats 1-4
    Tires 1-4
    HP
    TQ
    Load
    Intake Air Temp
    WWD
  2. Oct 26, 2022 at 2:11 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Scangauge 3 is an option as well. It will automagically scan for things to monitor. It is customizable as well.
  3. Oct 26, 2022 at 2:33 AM
    WrongWayDave
    Thank you SaltyH! Was looking for someting better than SG2, and SG3 was the exact answer! Just wish the wire was more discreet, but I need to know what is going on more than if it is pretty.
    Saltyhero13 likes this.
  4. Oct 26, 2022 at 4:05 AM
    Which OBD adapter do you have? A few of us use OBD Fusion.
    Wallygator, mountainpete and LS3 like this.
  5. Oct 26, 2022 at 4:09 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    2021 White Tundra SR5 CM TRD Sport
    same, I use OBD Fusion on my iPhone/iPad paired with a bluetooth OBD adapter
    Johnmatrix, Wallygator and LS3 like this.
  6. Oct 26, 2022 at 4:10 AM
    pursuit2550
    pursuit2550 New Member
    I have the OBDLink MX+. The app is free and the Toyota specific pids are also free. Very customizable. Easy to use and don’t need to enter pid calculations to make a gauge work.
    jhinderliter and Myhobbes25 like this.
  7. Jan 19, 2023 at 9:15 AM
    Rocko9999
    Rocko9999 New Member
    What specific adapter did you get?
  8. Jan 19, 2023 at 9:31 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Techcaristagauge
  9. Jan 19, 2023 at 9:32 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
  10. Jan 19, 2023 at 9:42 AM
    Asimov2025
    Asimov2025 Not Sure
    Trent Woods, NC
    2019 TRD 4x4 Sport
    Non-stop mods
    With or without a trans cooler?
  11. Jan 19, 2023 at 9:44 AM
    mountainpete
    mountainpete Explore more
    2018 Cement Crewmax TRD
    Function before sparkle.
    OBD Fusion on iOS with the Veepeak Bluetooth adapter for me. It tends to lock up once every few hours on a long trip, but for the price it's a great combination.
    Wallygator likes this.
  12. Jan 19, 2023 at 9:48 AM
    Rocko9999
  13. Jan 19, 2023 at 9:55 AM
    mountainpete
  14. Jan 19, 2023 at 10:08 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Purchase the Enhanced Diagnostics for your vehicle and it'll have the PIDs you need for monitoring your trans and torque converter temps.
    Rocko9999[QUOTED] likes this.
  15. Jan 19, 2023 at 10:12 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    This is my current dashboard I have setup in OBD Fusion
  16. Jan 19, 2023 at 10:38 AM
    mountainpete
    That is a beautiful dashboard.
    Gaston[QUOTED] and Neo258 like this.
  17. Jan 19, 2023 at 10:55 AM
    Rocko9999
    Perfect. Thanks
    Gaston[QUOTED] likes this.
  18. Jan 19, 2023 at 12:14 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Thank you, took me a while to get it set haha
    Galladanb likes this.
  19. Jan 19, 2023 at 12:14 PM
    Gaston
    Gaston New Member
    Gary
    SE MI
    You're welcome
  20. Jan 19, 2023 at 4:33 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
  21. Jan 20, 2023 at 3:32 PM
    Avi8or
    Avi8or New Member
    Johann
    MO
    2020 Limited Crewmax
    Im a little surprised you can get engine oil temp out of the computer. Does it seem to be accurate? Had a Subaru that showed oil temp and it warmed much slower than coolant and even transmission fluid (sometimes).
  22. Jan 21, 2023 at 1:02 PM
    Kbo
    Kbo New Member
    British Columbia
    2019 Double cab
    A bit of a lift, compressor, bags
    991C981D-BC92-42E5-9D17-9BD616DC462B.jpg I use fusion with the veepeak scanner and it’s been great. I place my phone down sideways by the shifter so I can read the gauges better. I made the tranny info bigger because that’s what I’m more concerned with. Like other people the button around the gear selection lights up when the tc is locked.
    Galladanb and mountainpete like this.
  23. Jan 23, 2023 at 6:02 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Honestly I'm not sure, seems about right but I don't have an external sensor/gauge to verify.
  24. Jan 23, 2023 at 10:18 AM
    Rocko9999
    Did you buy the $9.99 enhanced diagnostic pack to see the trans temp? I don't see it listed under the SAE options.
  25. Jan 23, 2023 at 11:35 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    yes, you will need the Enhanced Diagnostic pack for your vehicle to see the trans temp
    Galladanb and Rocko9999[QUOTED] like this.
  26. Jan 23, 2023 at 11:45 AM
    Rocko9999
    Thanks.
  27. Jul 17, 2023 at 5:10 PM
    2TunGet1
    2TunGet1 Tundra owner since 2000
    2020 Limited 4x4 CM QS / 2000 Limited 4x2 AC Black
    What is the torque converter listed under in the enhanced version of OBD Fusion? Which is the ATF Pan temp - A/T oil temperature 1 or 2?
  28. Jul 18, 2023 at 8:09 AM
    Gaston
    Gaston New Member
    Gary
    SE MI
    Pan is A/T Oil Temperature 1 and the Torque Converter is A/T Oil Temperature 2
    dundunDUN likes this.
  29. Jul 18, 2023 at 8:43 AM
    2TunGet1
    Awesome, thank you.
    Do you know if there is an alternator output and battery voltage meter in OBD Fusion? I see a couple that might be it but not sure exactly what it is monitoring. The “status of the battery voltage” reads 13.1 consistently for me.
  30. Jul 18, 2023 at 9:09 AM
    SD Surfer
    Bruce
    So Cal
    Holy smoke, that's cool.
    So silly question... this is all Bluetooth from the scanner, correct? So an old phone that's not activated on an account could download the app on wifi and then be dedicated to just be a BT monitor for this?
    How difficult was is to get your set up and formatted for this?
    That's basically all the same info I'd want. TC and Pan temps mostly, given I have a '19 with no external cooler and tow a travel trailer... Anything beyond that, gear, TC lockup, oil and coolant temps, etc. would all be a bonus.
