Best way to install bed drains?
Discussion in 'General Tundra Discussion' started by Worriedman50, Jan 6, 2019.
  1. Jan 6, 2019 at 12:57 PM
    Worriedman50
    Worriedman50 [OP] New Member
    Richard
    West TN
    2015 Tundra Crewmax
    TRD Rear Sway Bar , 6112 front 5160 rear shocks, Retrofit Projector Headlights, Rear LED bumper lights lights, FRAC harness and front camera, TRD Pro Grill and color matched hood bulge.
    Still have a little rake, and would like to be able to drain my bed at the front without just hauling off and drilling holes. Bet I am not the only person that has wanted to do this.
    Suggestions?
  2. Jan 6, 2019 at 1:31 PM
    Professional Hand Model
    Hand Protectors
    Not sure how your 2015 is set up, but underneath the 02’ factory plastic liner is a rubber gasket. I crawled under the bed and removed the gasket. Then, drilled a hole in the liner from above lining up over the factory bed hole (minus removed gasket). Inserted an electrical bushing in the hole.
    Drains perfectly. Its removeable to clean and snaps back in for reinstall.
    doggiecareman likes this.
