Best way to disable power windows after window tint?
Discussion in '2.5 Gen Tundras (2014-2021)' started by hkspwrsche, Nov 22, 2020.
  1. Nov 22, 2020 at 6:28 AM
    hkspwrsche
    hkspwrsche [OP] Old guy with lots of car toys
    Harold
    Richmond, VA
    2014 Tundra limited TRD CrewMax
    Working on it
    Pulling a particular fuse or relay? Just curious if someone has a “best” option or I’ll dig into the relay box myself later. I just had ceramic tint done and picked it up last night. The dry time is much longer for ceramic I’m told. 10 days recommended instead of 2-3 days. Because of that I’m concerned I’ll forget.
  2. Nov 22, 2020 at 6:29 AM
    Tundra-in-Cement
    Tundra-in-Cement Truck Chump
    David
    2021 Tundra CM-OR
    Scanguage-II, Decked Systems, Leitner Rack, CaliLED lights, Firestone Air Bags, Trans-cooler kit, 2017 Pro grille and bulge, S-Tech 6 way switch, Corse Evo Darks w/ Stock Tires, 17-inch Alpha Equip Delta w/ Wildpeaks, Falcon Suspension, Coachbuilder +1 Shackle, Valhalla Cat Protectors.
    Just put some tape over the switches.
  3. Nov 22, 2020 at 6:31 AM
    hkspwrsche
    Harold
    Richmond, VA
    Working on it
    I have tape over them now but, seems painters tape I could push through if I’m not thinking or on auto pilot.
  4. Nov 22, 2020 at 6:32 AM
    Tundra-in-Cement
    David
    2021 Tundra CM-OR
    .....in that case, add armed mouse trap. That will remind you!
  5. Nov 22, 2020 at 6:33 AM
    hkspwrsche
    Harold
    Richmond, VA
    Working on it
    That would do it!
  6. Nov 22, 2020 at 6:34 AM
    Tundra-in-Cement
    David
    2021 Tundra CM-OR
    Engine compartment fuse box: #7 & #8.
    Saltyhero13 and hkspwrsche[OP] like this.
  7. Nov 22, 2020 at 8:50 AM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    I had ceramic done and it was fine in 2 days.
    window lock or don’t drive, if you have another vehicle
  8. Nov 22, 2020 at 9:06 AM
    RainMan_PNW
    Casey
    Clark County, WA
    2021 Lunar Rock TRD Pro CM
    Why not just use the window lock button?
    Tundyfundy and NewImprovedRon like this.
  9. Nov 22, 2020 at 9:10 AM
    hkspwrsche
    Harold
    Richmond, VA
    Working on it
    That doesn’t lock the drivers side, correct? Or does it lock them all? I’m more worried I’ll forget, not the passengers and I did lock those. I assume the master switch still works.
  10. Nov 22, 2020 at 9:12 AM
    hkspwrsche
    Harold
    Richmond, VA
    Working on it
    We have other vehicles. It’ll probably just be off limits for the most part. I had pulled the main window relay on my wife’s car in the past so that seems like the way to go.
  11. Nov 22, 2020 at 9:20 AM
    RainMan_PNW
    Casey
    Clark County, WA
    well shit, now I gotta go test it because I’m not sure. o_O
  12. Nov 22, 2020 at 9:49 AM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    LOL, that is correct, window lock only locks the passenger side and back windows not the driver side...
    RainMan_PNW likes this.
  13. Nov 22, 2020 at 3:10 PM
    netranger6
    netranger6 New Member
    Jeremy
    2021 Crewmax. 4x4, SR5, Blacked Out package
    None. Keeping this one stock.
    Had ceramic done Wednesday. Not touching until I'm off Friday. But did slap in tuf skinz today.
  14. Nov 22, 2020 at 4:27 PM
    Yep, unless you add Autoloc modules like I did, then the lock doesn't work on any of them.
    blackdemon_tt[QUOTED] likes this.
  15. Nov 23, 2020 at 2:08 PM
    2008tundrablue
    2008tundrablue New Member
    My ceramic 35% I waited about a week and the guy put neon green tape over the switches
  16. Nov 23, 2020 at 3:46 PM
    Speed_dmon
    Speed_dmon New Member
    2020 TRD Pro Hulk
    I just taped a piece of cardboard over the switches when I had mine done
    NewImprovedRon and RobertD like this.
  17. Nov 23, 2020 at 4:00 PM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    I don't wanna be "that guy", but this is probably the best way to go. Pulling a fuse or really disabling them could be a potential safety issue....ya never know.
  18. Nov 23, 2020 at 4:04 PM
    RobertD
    Robert
    DFW, Texas
    When my tint was done they had a piece of hard plastic taped over the buttons with the date of installation on it. Tape a piece of cardboard or plastic over the switches so you can't hit them, but when it's time you just pull up the tape and call it a day.
  19. Nov 24, 2020 at 10:45 AM
    Tisoy281
    Tisoy281 New Member
    10 days? Mine was good to go in 3.
  20. Nov 24, 2020 at 1:55 PM
    clarkritchie
    clarkritchie New Member
    My 13 yo peeled the tape off to roll the passenger window down ~6 hours post-tint! :mad:
  21. Nov 24, 2020 at 2:02 PM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    Tape over the switch or pull the fuse.
  22. Nov 24, 2020 at 2:37 PM
    801Tundra
    801Tundra New Member
    UTAH
    2019 Crewmax Limited
    LOL not true! The adhesive on ceramic film is really no different than a standard dyed film.
    Couple of days and you'll be fine. Honestly the way I install, and most others, you can roll them down in an hour and be fine. (although I never recommend this to customers)
