Best value tire
Discussion in 'Wheels & Tires' started by Chadwicktr, Dec 27, 2022.
  1. Dec 27, 2022 at 10:12 PM
    Chadwicktr
    Chadwicktr [OP] ‘08 DC X-SP 5.7
    Raleigh
    Hey! I just purchased a ‘08 tundra X-SP. Tires have some tread left but will need to be replaced.
    the X-SP package came with 305 50 R20 and they are hankook all terrain tires right now.
    I’d like to switch over to a road tire. I only drive 2,000 miles a year. So weather checking will probably wear the tires down first before mileage ever will. South east region—no snow.
    what’s the best bang for the buck given the above?
  2. Dec 29, 2022 at 5:55 AM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    OEM take-offs should be the least expensive way to get into new rubber. You’ve already got the 20” wheels, and OEM size is 275/55-20.
    They’ll be the same diameter as the 305/50-20 you have, but a little over an inch narrower.
    You’re currently a 32” x 12” tire. OEM is 32” x 10.8”.
    Chadwicktr[OP] likes this.
  3. Dec 29, 2022 at 8:12 AM
    The 305/50/20 is a 33.2" or so tire. The factory size 275/55/20 is more like 32.9". They are very close but the 305 one is a little taller and definitely a bit wider. 275/55/20's are some of the cheapest tires available even new as they are the most popular 20" tire size across all truck brands. Take-offs are a great way to score some cheap, but they will normally be the cheaper OEM version of whatever tire you get.
  4. Dec 29, 2022 at 8:21 AM
    Chadwicktr
    Raleigh
    Sounds good. Thanks for the input. I’ve seen a few take offs come up on marketplace already this week.
    The more I look at the 305s with AT tread the more I may want to keep that style though . I’ve seen a few people selling some used with a lot of tread left so that may be an option too.
    It’s basically a truck for HD runs, and something to pull a double axle trailer and equipment around a handful of times in the summer. Was tired of having to borrow trucks or be limited to 3k # with a SUV. So the price of the new (and top) AT tire brands is probably more than I need.
    Appreciate it!
  5. Dec 29, 2022 at 8:23 AM
    JeremyTRD
    JeremyTRD New Member
    Jeremy
    Upstate, NY
    2016 Black Tundra CM TRD OR
    ChadwickTR. You wouldn't happen have any relatives in Upstate NY would you?
  6. Dec 29, 2022 at 8:25 AM
    Chadwicktr
    Raleigh
    Not that I know of…why?
  7. Dec 29, 2022 at 8:27 AM
    JeremyTRD
    Jeremy
    Upstate, NY
    Mothers Maiden name.. we have family down south. Just don't see a lot of Chadwick's.
