Best Trailer Tires?
Discussion in 'Towing & Hauling' started by OBXTundra, Sep 4, 2020.
  1. Sep 4, 2020 at 11:42 AM
    OBXTundra
    OBXTundra [OP] Member
    Southeast USA
    2018 Nissan Armada, 4x4
    In need of a new set of tires for my Greywolf 26BH camper.
    Currently Load C, going to Load D.
    I have my eyes on the following:
    -Goodyear Endurance
    -Kenda Karrier
    -Maxxis M8008
    Anyone have real world experience with any of those tires?
    Anyone have a tried and true "best" trailer tire that they've actually used?
    The Endurance seems to get the highest marks in real world use and testing. Availability is slim-to-none right now though.
    And before anyone recommends LT instead of ST, politely no thank you. I'm not going down that road.
  2. Sep 4, 2020 at 6:11 PM
    SprinterAE86
    SprinterAE86 New Member
    Ian
    Charlottetown, PE, Canada
    2012 Toyota Sequoia Platinum
    OBXTundra[OP] likes this.
  3. Sep 4, 2020 at 7:17 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    What’s the deal with LT tires ? The reason I ask is because my TT came with LT tires.
    ColoradoTJ and OBXTundra[OP] like this.
  4. Sep 4, 2020 at 7:20 PM
    ARMYGREEN
    ARMYGREEN New Member
    2014 CrewMax MGM
    Stiffer but tougher and weighs more?
  5. Sep 4, 2020 at 7:28 PM
    OBXTundra
    Southeast USA
    They're not "bad" they're just not engineered for towing. You'll likely have no short-term issues and LTs are not prone to blowouts. ST generally favor very stiff sidewall and low rolling resistance. ST also favor harder rubber compound and lower traction.
    The reason for lower traction being the trailer tires are "scrubbing" for a good amount of their service life if they're on a 2 or 3 axle trailer. The reason for low rolling resistance being higher MPG.
    ColoradoTJ and jeremyd[QUOTED] like this.
  6. Sep 4, 2020 at 7:35 PM
    jeremyd
    NV
    2014 SR5 CM 4X4
    That makes sense, I’m pulling pretty light.
    OBXTundra[QUOTED][OP] likes this.
  7. Sep 4, 2020 at 7:35 PM
    Azblue
    The Dirty T ( ^_^)_且
    I've had the Goodyears on my trailer for a couple of years now. So far so good. Trailer rides good, treadwear good, etc.
  8. Sep 4, 2020 at 7:38 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    +1, on boat trailer. 5000 lb dual axle and no problems
    OBXTundra[OP] and Azblue[QUOTED] like this.
  9. Sep 5, 2020 at 2:36 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Bought my Goodyears 3 years ago about the time I found out they're made in America, so far,so good.0826171135a.jpg
  10. Sep 5, 2020 at 3:18 AM
    biebs96
    PA
    Following
  11. Sep 5, 2020 at 6:28 AM
    gdiep
    gdiep I like cookies
    Syracuse, New York
    2014 Red Tundra CM SR5
    Carlisle Radial HD - they have a higher speed rating than the run of the mill trailer tires. I’ve had them for about three years with no issues whatsoever and they are reasonably priced.
  12. Sep 5, 2020 at 7:37 AM
    pickupjason
    pickupjason New Member
    2019 Silver Crewmax TRD offroad 4x4
    I'd suggest asking the question on the trailer forum and you will receive a lot of comments on various tires! Some people believes in ST tires only while others like the LT tires better than anything else!
    I put on Goodyear Endurance on my trailer around 1000 miles ago, based on the many threads I read from the trailer forums as well as the reviews from tirerack/discounttire website. The only major difference I noticed is, compare with the old Goodyear Marathon on the trailer, Endurance doesn't loose air sitting couple months on my drive way between trips.
    Other than choosing the right tires, I also suggest getting a good tire pressure monitor system to monitor the pressure/temp on the trailer tires.
  13. Sep 5, 2020 at 7:55 AM
    Rabidllamas
    Rabidllamas New Member
    Phil
    WA
    2019 Cement Crewmax TRD OffRoad
    My build- https://www.tundras.com/threads/rabbidllamas-old-man-build.80802/
    We also went with Goodyear Endureance. I follow several TT sites and the overall recommendation was the endurance. Bought new 2 months ago and just finished a 1200 mile trip and no issues so far.
    runCMD and OBXTundra[OP] like this.
  14. Sep 5, 2020 at 9:06 AM
    Blue Thunder
    Washington
    Years ago on a trailer forum, one of the active members did a comparison between the testing standards for ST and LT tires. The LT tires were better in every way from what I remember. The article had links to all the data he found...wish I'd saved that link. STs are generally lower quality and made overseas. Goodyear seems to be the exception.
    When I had to put new tires on my 8,500lb Arctic Fox I went with higher load-rated ST tires from Goodyear. But this was a 6-7 years ago and the trailer is long gone, so I don't know how well they faired. I think up-sizing the load is very smart so the tires are not the weak link. Sounds like Goodyear are still the best around. Good luck
  15. Sep 5, 2020 at 10:52 AM
    OBXTundra
    Southeast USA
    Thanks everyone for the amount of responses.
    The Goodyear Endurance seem to rule the roost among ST's. That's also what I've come across in my research across all forums. I have a really good local shop trying to find 4 for me right now. Shortages on quality items in all markets seem to be the new norm.
    Anyone with direct experience with the Maxxis M8008? This is the only other tire I am considering. Same style tire, radial, 8 ply, excellent reviews across forums.
    ColoradoTJ likes this.
  16. Sep 5, 2020 at 10:55 AM
    I wish you had saved that link as well.
    Sometimes the math works out, other times it doesn't on LT vs ST tires.
    Let's take the OP's camper for instance, a Grey Wolf 26 BH TT.
    Here are the specs. For this conversation, gross trailer weight is matters. (7505 lbs)
    I couldn't find LT225/75/15 tires, so I had to move up to a 16" wheel. The owner would have to move up to a 16" wheel costing an additional 400-550.00. 16" wheel/Tire combo will weigh more.
    https://www.tirerack.com/tires/tire...5R6ACCV2&vehicleSearch=false&fromCompare1=yes
    Here are the specs:
    In this scenario, the math works. 2680 x 4= 10720 lbs. This is way over the campers gross weight rating.
    Now for the ST tire that you can find in 225/75/15. Now wheel swap and lighter combo.
    https://www.discounttire.com/buy-tires/hartland-st-radial/p/29485
    Now we need to find out what the load rating is on this tire. To the load index chart and look for 117.
    2833 x 4= 11332 lbs.
    ST tires also have stiffer sidewalls for minimizing sway, low traction for cornering, and handle the abuse of trailers a lot better. The only thing one is gaining by moving to a LT tire is speed rating, and if you buy the right ST tire you should have a speed rating of 75-89 mph. We don't need to go any faster towing than 75 mph.
    Where one starts getting into trouble with ST vs LT tires is load ranges outside of what a Tundra can handle (over 10000 lbs). So we really don't need to discuss it any further.
