Best tires for paved roads
Discussion in 'Wheels & Tires' started by Nflguy, Apr 4, 2024.
  1. Apr 4, 2024 at 8:28 AM
    Nflguy
    Nflguy [OP] New Member
    My TRD Pro is 2 yrs old. I never go offroading so all my driving is on paved roads. The ride quality has been comfortable. My truck came with Michelin LTX A/T 2 tires.
    I’m shopping for new tires at Costco and see the following options
    Michelin LTX A/T 2 (most expensive option at $352 per tire.
    Michelin Defender LTX M/S 2. Slightly cheaper at $288 per tire.
    Michelin Primacy XC. $286 per tire.
    I want the tire that will give the best/comfortable ride but also hopefully last at least 20k miles.
    I have seen some reccomend Nitto Grappler tires but don’t see those offered at a Costco. And I’m not sure about ride comfort for those on paved roads.
    Any reccomendations?
  2. Apr 4, 2024 at 8:37 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    M/S 2
    ejes, 17inferno, Nflguy[OP] and 2 others like this.
  3. Apr 4, 2024 at 8:45 AM
    Henfield
    Henfield New Member
    I recently replaced my tires with the Defender LTX MS2. Solid thumbs up for this tire. Its seen rain, snow and highways. Replaced factory before winter as they were getting slick on wet roads. Of course, we just haven't seen much snow at all in New England for the second year running.
    In fact the snow falling right now is possibly the most we've seen all year. I got them having had great experience with prior generations of the LTX tire
    That said, if you live in a warmer snow free zone. the Primacy would do fine for your needs.
    Nflguy[OP] likes this.
  4. Apr 4, 2024 at 8:48 AM
    2mchfun
    The Defender will deliver the best results.
    WILLINH and Nflguy[OP] like this.
  5. Apr 4, 2024 at 9:27 AM
    xround
    xround New Member
    2015 CM Limited OR
    I love my M/S2.
  6. Apr 4, 2024 at 9:44 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    Another M/S 2 vote here. I had some put on last fall and didn't even need chains for the snow/ice we had this winter.
  7. Apr 4, 2024 at 9:47 AM
    SR5BART
    SR5BART New Member
    Bart
    Chicago
    21 SR5 TRDOR
    M/S2
  8. Apr 4, 2024 at 9:50 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Vredestein Pinza AT. Can get in P or LT rating.
    P tires I put nothing but Vredestein for the past 5+ years. Quatracs were also good, but Pinza is newer, and they put a lot of research into it.
  9. Apr 4, 2024 at 9:56 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I put on the ms/2. No issues and a smooth ride
  10. Apr 4, 2024 at 9:59 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    We run Defenders on the Sequoia and they run quiet and smooth. Great tread wear and lifespan. I'll be puttin on a new set when these go.
    17inferno and Nflguy[OP] like this.
  11. Apr 4, 2024 at 10:51 AM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    1 size taller, 1 size narrower.
  12. Apr 4, 2024 at 11:52 AM
    ChesterTundra
    ChesterTundra New Member
    Central FL
    2020 Tundra SR5
    RCI Alum skids w/cat guards Leveled and AT Cooled SPD Performance exhaust Amsoil everywhere…
    Look at H/T tires. Some have aggressive sidewalls that look nice, but with highway oriented tread. Still all weather tires too. I’ve had good luck with cooper evo h/t and Falken h/t I’m running now are nice. 60k mileage warranty iirc.
  13. Apr 4, 2024 at 12:06 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I did 100k on michelins on a nissan titan before i was seeing steel. I know the cheap walmart goodyear wrangles are a 50k tire.
    my ltx m/s from '18 has a 800 treadwear, and basically have full life left. 38psi front 35psi rear. Not enough pressure to be noisy, but enough pressure to roll easy. Never tripped my abs, and cant do a dry burnout without brakes, but i can powerslide in the rain on asphalt pretty predictably with the weight of the cap on the back. Titan is factory sized 18's from a newer year, on cooper evo's, currently, but it's 1 wheel drive & spends its entire life on pavement & will get stuck in wet grass.
  14. Apr 4, 2024 at 12:15 PM
    Bammer
    Bammer I'm disinclined to acquiesce your request.
    Monroe, CT
    2019 Tundra SR5 TRD Crew Max 4x4
    My road Queen has Goodyear Steadfast , about 15k on them, great tire. Rode through a storm two weekends ago that featured snow,sleet and freezing rain, no issue ! 70,000 mile tread warranty
  15. Apr 4, 2024 at 1:45 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    The Defender is hands down the best truck/SUV that only sees pavement.
    Oey12 and WILLINH like this.
  16. Apr 4, 2024 at 5:43 PM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    On my truck the LTX seem to last 60 to 70k and I think they are good on road. Not good off road. I also don't hear much road noise.
  17. Apr 5, 2024 at 7:00 AM
    MeetJoe
    MeetJoe New Member
    Maryland
    2021 CrewMax SX
    OEM TRD Pro Led Headlights OEM LED Fog lights iHacker Harness OEM Tube Step OEM trifold hard tonneau OEM Driverside Grab Handle and Pillar OEM Exhaust tip Wireless CarPlay CarLinkit 3.0 Snack Crumbs
    Can you post pics? And what size did you decide on? I am in the same predicament. I have a 21 CM (SR5) SX and it came with 255/70/18 (my door panel says 255/70/18!).
    I wanted to get a little larger but don't want to sacrifice speedometer, odometer, MPGs with 275/70/18 so thinking of splitting the difference with 265/70/18.
  18. Apr 5, 2024 at 7:13 AM
    JohnWhicker
    JohnWhicker New Member
    My truck came with Michelin LTX A/T 2 and I absolutely LOVE them, buttery smooth and quiet. I am a KO2 guy but I think from now on I will sacrifice the look over the quality and stay with the Michelin LTX A/T 2
  19. Apr 7, 2024 at 3:41 PM
    osu1978
    osu1978 New Member
    For pavement, Defenders. There is nothing better.
    WILLINH likes this.
  20. May 29, 2024 at 11:02 AM
    Nflguy
    So I’m trying to order Michelin Defenders thru Costco. They are telling me it will take at least 3 weeks to get them as no nearby locations (in Dallas area) has them.
    This has me wondering if these tires are not needed for warm climates where we rarely see snow.
  21. May 29, 2024 at 11:30 AM
    Nflguy
    Costco rep told me that they sell Michelin XLT A/S 2 and they sell Michelin Defender LTX M/S2. He claims they are the same tire sold under different names but no difference between them. They have same load index, speed rating and warranty mileage.
    if I go with the XLT A/S 2 I don’t have to wait 3 weeks like I do with the Defender. They have XLT in stock.
  22. May 29, 2024 at 12:16 PM
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    I LOVE my ltx ms2's, but i'm gentle on tires. They did get me through sedona. And i kept my mudflaps. 265/70-16.
