Best subwoofer setup for 2006 double cab?
Discussion in '1st Gen Tundras (2000-2006)' started by rowennntheboat, Aug 2, 2022.
  1. Aug 2, 2022 at 3:23 PM
    rowennntheboat
    rowennntheboat [OP] New Member
    Rowen
    2006 Tundra Double Cab SR5
    I have a 2006 Double cab sr5 and there appears to be literally nowhere i could put any subs without sacrificing a seat or the middle console. i’ve seen some people on these forums go for the self powered amp option. there’s not a lot of info online about the 2006 DC specifically and i’m wondering what others have used? Just today i picked up 2 12s and an amp for free that someone was giving away but i highly doubt i’ll even be able to fit 1 12
  2. Aug 2, 2022 at 3:28 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    I have a custom fiberglass box for two 8's that fits in the storage compartment under the rear seat. You want it?
    Otherwise put the twelve on the back seat.
    04DCTundraMan likes this.
  3. Aug 2, 2022 at 3:58 PM
    Dang, you must not have used the search feature here. I've seen at least half a dozen different setups, both powered and not, using the under-seat cubby, and even the space behind the rear seats. You're lucky in the DC, you've got way more options than the AC in my opinion.
  4. Aug 2, 2022 at 4:04 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    AFA1E316-3535-48FC-AC3C-163F06EC1FB1.jpg Kicker and some grass!
    no there aren’t many “great” options. When life gives you lemons, you make lemon drop shots!
  5. Aug 2, 2022 at 4:06 PM
    rowennntheboat
    Rowen
    the only problem is with the 06 double cab we don’t get any of that space under the rear passenger seats
    SlickBox likes this.
  6. Aug 2, 2022 at 4:19 PM
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    Might want to show what you mean. There's plenty room in our DC's.
    Here's just one of many "subwoofer" threads in this Forum alone by a simple search of this Forum.
    1st gen tundra double cab subwoofer | Toyota Tundra Forum (tundras.com)
    pic of DC back seat subwoofer placement possibilities....
  7. Aug 2, 2022 at 4:37 PM
    rowennntheboat
    Rowen
    This is what i’m working with, i out the bottle to show how barely deep it is, as well as it being sloped. and the single side compartment on the passenger side idk how or if i can get that thing out of there and if that would even be a viable space to do it with. now i may be incorrect on all of this it just seems like there would be be enough space for anything
  8. Aug 2, 2022 at 5:44 PM
    That's a hell of a lot of airspace when you consider the myriad of shallow-mount sub options that kick just as hard as their counterparts. As someone who worked in the audio/customization industry at a shop that regularly competed in IASCA events in the SE USA, I've heard single 8's kick harder than 2x12s. Don't get stuck on diameters. Enclosure design is far more important
    Maybe you need to think more creative if you want to go larger?
  9. Aug 2, 2022 at 6:14 PM
    Riverdale21
    Riverdale21 Speed seeker
    OTP ATL
    06 SR5 Tundra TRD Off Road
    Dirt Deeds injectors, Addco rear sway, AEM dry flow air filter, last ever set of Stan's Try-Y headers, Borla full custom exhaust, front level, wheel spacers, and lots of electronics.
    shifty` likes this.
  10. Dec 10, 2023 at 2:43 PM
    bigt123
    bigt123 the one and only
    2006 SR5 Double Cab 2WD
    how in the world did you guys flip your seats up like that, I cant figure out how
  11. Dec 10, 2023 at 3:26 PM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    Pull the handle to drop the seat back onto the seat bottom. Pull the handle and lift the seat bottom to raise the seat. It's hinged in the front and swings up toward the back of the front seats.
  12. Dec 10, 2023 at 3:27 PM
    Pull cord on the front flips one way. Lever on the back flips the other way. If I'm not mistaken.
    abcinv likes this.
