Best Sounding Blue Tooth Speakers - What do you use?
Discussion in 'Off-Topic Discussion' started by AZTundra, Jul 30, 2023.
  1. Jul 30, 2023 at 3:13 PM
    AZTundra
    AZTundra [OP] No Longer a New Member
    Paul
    Phoenix, AZ
    Just curious what everyone else is running for bluetooth speakers. I've got a small JBL flip bluetooth speaker that I've been using for a couple years. It does a decent job for the small size that it is and battery life is pretty decent as well. I normally take this with me whenever I'm working in the garage or on the back patio and stream Sirus Xm to it through my phone app.
    I just ordered a Marshall Stanmore II bluetooth speaker in black with gold trim the other day. Looking forward to trying it out once it arrives. This one is not so much portable because it does require it to be plugged into an outlet, but the reviews I've read were highly rated on this model. It's a bit pricey at around $380, but looks to be a well made unit and I like the guitar amp look of it. Anyone else have the Marshall Stanmore II? If so, what are your thoughts on it.
    Buy Marshall Stanmore III Bluetooth Speaker | Marshall (marshallheadphones.com)
  2. Jul 30, 2023 at 3:21 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Probably don't sound as good, but I've used these for quite a while; pair 2 of them up and the sound is pretty decent!!!
    Plus they float and are water proof...
    texasrho83 and AZTundra[OP] like this.
  3. Jul 30, 2023 at 4:01 PM
    centex
    centex New Member
    I’ve got a Bose flex I use. Sounds great.
  4. Jul 30, 2023 at 4:04 PM
    Gene_in_FL and AZTundra[OP] like this.
  5. Jul 30, 2023 at 5:15 PM
    RichterScale
    Ron
    WNY
    2021 DCRB as base as it gets
    pin stripes (+5 hp)
    Bose SoundLink Mini II
    I've had it for a while. It was $100 (I think) when I bought it and I was pissed about spending so much, but it was worth it at this point. Still holds a charge for a long time and sounds incredible for being so tiny.
    AZTundra[OP] likes this.
  6. Jul 31, 2023 at 4:29 AM
    ryanjay11
    ryanjay11 New Member
    I’ve had a Bose Soundlink Color II for about 8 years and it’s been fantastic. It sounds amazing and the battery lasts for a long time.
  7. Jul 31, 2023 at 5:59 AM
    g6t9ed
    g6t9ed Novice Tundra Modder
    2017 Black CrewMax 1794 4x4
    I use DXOMark for wireless speaker choices. Depending on what situation I'm in, it helps give me a baseline on where to start. I like their constantly updated and easy to read rankings. According to their results, they state that the Marshall Stanmore III is a pretty good speaker. So, it seems it tracks with the reviews that you read.
    Edit: Reread your statement and wanted to make sure your post wasn't a mistake. You stated you purchased a Marshall Stanmore II but linked to a Marshall Stanmore III. Seems there's quite a difference between the two with the II being the better between them, according to DXOMark.
  8. Jul 31, 2023 at 6:15 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Sonos blows the Bose and every other speaker I’ve owned out of the water. They have a good military discount as well.
    AZTundra[OP] and texasrho83 like this.
  9. Jul 31, 2023 at 6:20 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
  10. Jul 31, 2023 at 6:20 AM
    ryanjay11
    I'm going to sell my full Denon/Polk surround sound setup and go with the Sonos Ultimate Immersive Set with Arc for home theatre. I've been very impressed with Sonos.
    AZTundra[OP] and BTBAKER[QUOTED] like this.
  11. Jul 31, 2023 at 6:21 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    I have their sound bar with built in surround and for not having actual surround, it sounds awesome.
  12. Jul 31, 2023 at 6:24 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Bought this one on Amazon back in 2021 and it's very good for the little bit of money you spend. Initially purchased to do something at school, but I use it every time I'm in the garage or working outside. Plenty loud but not so loud the neighbors complain.
  13. Jul 31, 2023 at 8:15 AM
    RichterScale
    Ron
    WNY
    pin stripes (+5 hp)
    A guy at work had one just like that and had it on his cart all summer while he was painting. I was blown away by how small it was and how good the sound was. It sounded like something 5x it's size.
    They didn't have that model when I looked for one, but they had the mini II. I liked the smaller profile and that it was stereo so I grabbed one to try. Even though mine is smaller, there's more low end. Which is hard to believe and kinda cool, but it's almost too much low end. I wish it had a little 3 band EQ. I think the one you have has an overall better sound, but I still like the mini.
    BTBAKER and AZTundra[OP] like this.
  14. Aug 10, 2023 at 8:00 PM
    Gene_in_FL
    Gene_in_FL SUPER genius
    FLORIDA
    2016 SR5 DC 5.7 2021 SR5 DC 5.7
    I have its little brother, the JBL Extreme 3. We're happy with it, but that Boombox takes it to a whole nuther level.
  15. Aug 17, 2023 at 7:11 AM
    SD Surfer
    Bruce
    So Cal
    Just got a Bose Soundlink Flex ($129 at Costco) and it sounds really good for it's small size.
    AZTundra[OP] and RichterScale like this.
  16. Aug 27, 2023 at 5:02 PM
    fyrfytr26
    fyrfytr26 New Member
    Eastern PA
    2021 DC SR
    I got this as a promotional piece when I bought a Milwaukee cordless ratchet.
    Uses the same batteries as the ratchet if I’m away from a 120v source. And if I can plug in, it will charge the ratchet batteries.
    For in the shop or on a job site it works great. Mine lives on top of my toolbox. I’m sure there are better options as far as sound quality, but really what more do you need in a portable speaker? For the price I paid I have no complaints. Especially since I wouldn’t have spent money on something like a speaker for in the garage - it’s just not that big of a priority to me. IMG_1223.jpg
