Best soft roll-up tonneau cover for cargo management system
Discussion in '2.5 Gen Tundras (2014-2021)' started by NCSkeeter, Jan 1, 2019.
  1. Jan 1, 2019 at 6:45 PM
    NCSkeeter
    NCSkeeter [OP] New Member
    2019 Silver Tundra Crewmax 4x4 1794
    TRD Rear Sway Bar, Truxedo X15 Tonneau Cover, Toyota OEM Bed Mat
    Most of the soft roll-up covers I've seen look like they require removing the cargo management rails. The truxedo lo pro qt is the only one I've found that mentions these rails. Does it allow the use of the rails? Is it the only good option for a soft roll-up if I want to use rails?
    I used a trifold on my last truck which I liked, but I had to remove it to carry a bike with a fork mount on the front rail. I've thinking a roll up will work better for carrying bikes.
  2. Jan 1, 2019 at 7:05 PM
    jeffw6236
    jeffw6236 New Member
    Jeff
    San Antonio
    2019 MGM CrewMax 4x4
    Or you could put it on top
  3. Jan 1, 2019 at 7:10 PM
    39 Chev
    39 Chev New Member
    2019 Cement Limited
    2019 tundra 3.jpg The Access roll-up cover works with rails. In fact, I think it uses the rails to attach the framework. New truck I just picked up on Monday, so I haven't even had it rolled up yet, so I'm not sure how it attaches, but when I bought it, the dealer said they had one in stock if I had a Tundra with the rails, but would have to order if my truck did not have rails.
  4. Jan 1, 2019 at 7:14 PM
    polymerhead
    polymerhead New Member
    You can still use the rails on the Truxedo X15. Tiedowns/accessories are limited in adjustability between the tonneau clamps. I’ve gotten a bunch of compliments on it. It is basically convertible top material. The wrinkles in this pic were gone a few days after install.
    rebmo likes this.
  5. Jan 2, 2019 at 3:51 AM
    rsgt
    rsgt New Member
    2019 crew cab TRD sport 4x4
    all stock
    I have the same but my model goes over the rails and held on by strong velcro. Rolls up to with in 10 inches to the cab. The only water gets in from a car wash and that enters thru the sides of the tail gate.
  6. Jan 2, 2019 at 1:15 PM
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    X2 on the Access, I have the Access Lorado on my CM. There are 4 clamps on each side, and they clamp directly to the rail, so you just can't slide the tie-downs forward and back all the way. I ended up putting my low-profile rings in the rail around the middle of the bed while I was installing the clamps, and I put the large tie-downs on the cab rail. Works well enough, I can still slide the rings back and forth between the clamps.
  7. Jan 2, 2019 at 4:02 PM
    Nighthawk
    Nighthawk New Member
    Keith
    Frederick Md.
    2018 Tundra Limited crewmax
    linex bed Truxedo Pro F-15 Tonneau,Weathertech mats,TRD exhaust,Matt Geckco bed lights,hood light,shorty antenna, all LED lights inside, Fomoto oil drain valve,
    I agree with polymerhead I put pro x15 from Truxedo and love it,the new fabric is awesome.image.jpg
    polymerhead, NCSkeeter[OP] and rebmo like this.
