Best Shorty vs. Long-Tube Headers: Which do I Choose?
Discussion in 'Performance and Tuning' started by trdprobped17, Jul 27, 2018.
Poll closed Aug 3, 2018.
  1. Shorty Headers
    9.1%
  2. Long-Tube Headers
    90.9%
  1. Jul 27, 2018 at 11:44 PM
    trdprobped17
    trdprobped17 [OP] New Member
    All, I am trying to decide which way to go for headers for my 5.7L. I prefer to keep my current catback exhaust system. As well as, I wish to keep the cat. I found this comparison online regarding the difference between the long tube vs the shorty headers. Which do you suggest?
    Long-Tube vs. Short-Tube Headers: Which Improves Your Exhaust Better?
    Performance Exhaust Headers
    Discover what’s right for you, a short or long-tube header.
    Headers are the first stop for exhaust gases on their way out of your cylinder heads and into the exhaust stream. To find a perfect set of headers, all you need to understand is how these two types differ. Read on to find out how the two styles improve performance at different RPMs and how choosing the correct one benefits your vehicle based on your driving style.
    Factory headers, or “manifolds” are generally designed to meet the most strict emissions requirements, and be cost effective to mass produce. These manifolds are generally cast, leaving inconsistent imperfections within the inner ports. These imperfections can restrict the flow decreasing the efficiency of the engine’s exhaust flow. Their port design is typically geared towards quiet engine operation. In addition, they weigh significantly more than an aftermarket header.
    Short Tube Headers
    Short tube headers are a great option if you are looking for more low to mid range power in reference to your rpm band. This is a good choice for someone who daily drives the vehicle or uses it for towing where you are not constantly at higher rpms. Short tubes use welded mandrel bent pipes rather than a casting. They are typically easier to install compared to long tube headers and also allow you to use your factory catalytic converters when needed. If you are in an emissions controlled state, short tubes are typically the only legal option.
    Long Tube Headers
    Long tube headers are a great option for high revving vehicles to allow for a lot of top end exhaust gas flow. The difference between these and short tube headers is the length of the primary tubes to the collector. Long tubes keep exhaust gasses separate from each cylinder for a much longer period of time. Due to their longer primary tube lengths, long tubes need more space to work with. They also typically eliminate emissions equipment like catalytic converters. Long tubes are a great option for someone who is racing and pushing their car to redline, looking to produce greater peak horsepower and doesn't have to worry about complying with emissions standards. Long tubes will cause a check engine light on most modern applications unless a custom tune is used to tune out the secondary oxygen sensors.
  2. Jul 28, 2018 at 10:49 AM
    Bo-Hunter
    Bo-Hunter I like fast
    Greg
    NOVA
    2009 RW 4x4 Truck
    Long Travel, DC Shortbed
    You will not see anything performance wise from a short tube header over the stock toyota manifold. It will however be louder.
    Saltyhero13 and trdprobped17[OP] like this.
  3. Jul 28, 2018 at 10:52 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
  4. Jul 28, 2018 at 10:53 AM
    trdprobped17
    Thanks. I am not looking for sound, but more performance.
  5. Jul 28, 2018 at 10:54 AM
    trdprobped17
    Thanks, I’ll check it out.
  6. Jul 28, 2018 at 11:02 AM
    dirtydeeds
    Keith
    USA
    more than I can list here
    The article is just copy/paste of incorrect information.
    I’ve extensively tested shorties on several vehicles and on several engine. With or without vvti. In each and every case shorties lose low end torque.
    After reading the section of the article saying shorties are good for towing I quit and started writing my response. Haha.
    My line in the sand is: stock manifolds need single exhaust that just replaces the muffler.
    Long tube headers gain 49hp 89tq with dual 3” exhaust with massive gains in low end torque.
    Skew12, Flyinryank, equin and 6 others like this.
  7. Jul 28, 2018 at 11:08 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    Of a Truth he says unto us, so let it be written, so let it be done!:amen::D
  8. Jul 28, 2018 at 11:08 AM
    trdprobped17
    Long tube seems to be the best way for more power. I’m just concerned about having to cut my pipes and possibly loosing my cat. What’s the best way to use the long tubes and keep my cat?
  9. Jul 28, 2018 at 11:17 AM
    dirtydeeds
    Keith
    USA
    You’ll want to start all over again with the mid pipe. You don’t want to cut your stock mid pipe nor tie into the stock mid pipe. It’s only 2” diameter.
    Best way to keep all 4 cats and bolt on long tubes is to send us your cats. We build them into a set of mid pipes that will allow you to simply bolt on the headers. Bolt on the mid pipes and bolt on the catback of your choice.
    You can use 2.5” exhaust or 3”. 2.5” gains 41hp 73tq. 3” gains 49hp 89tq. And all of this with your stock carbs built into the system as if they came that way. 760-877-4234
  10. Jul 28, 2018 at 11:30 AM
    Yota18
    Yota18 Inferno Club
    Upstate New York (the real NY)
    18’ 5.7 TRD Off-Road
    Stock
    The real question is how many mpgs do you gain lol jk
    How long is the turn around for that?
  11. Jul 28, 2018 at 2:22 PM
    dirtydeeds
    Keith
    USA
    Usually 30 days or less
  12. Mar 19, 2021 at 5:55 AM
    wildbill2020
    wildbill2020 New Member
    2020 tundra sr5 crewmax
    5% tint all around, 35% tinted windshield with a 5% brow, removed stickers/decals
    @dirtydeeds if I put long tubes on my 2020, with you building a mid pipe out of my factory cats, will I need to tune?
    Saltyhero13 and CaptainGrumpus like this.
  13. Mar 19, 2021 at 8:58 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    For this purpose, can you make cats removed from a 2014 or newer truck work on an old 2007?162430073_5510675318950287_6335262258516798873_n.jpg
    dirtydeeds[QUOTED] likes this.
  14. Mar 19, 2021 at 6:07 PM
    Downytide
    Downytide New Member
    GTA
    Lunar Rock with trail boxes
    I have long tubes and custom mid pipes with oe cats, no tune needed.
  15. Mar 19, 2021 at 6:16 PM
    TX210Tundra
    TX210Tundra New Member
    2008 RCSB 5.7 2WD "Sport" / 2022 Limited Hybrid
    2008 - SOS 2/4 Lowering Kit : Firestone Bags : Bilstein Sports at 4 corners : TRD Pro Grill : TRD Pro 18in BBS Forged : Grip Pro LSD : Mike's "ByeNanny" : ARH LT 1 3/4 : ARH Cats : 3" X-Pipe: 3" Dual Borla XR1's / 3" Vibrant Resonators: 3" Tail pipes: DIY SABM: TRD Intake : AFE T/B Spacer : TRD Accelerator : LED Interior/Exterior : Atoto Pro HU : Cerwin Vega 10in Slim : AVS Visors : Sequoia Leather Seats : TRD shift Knob - OVTuned "Spicy 91 Torque Tune" 2022 Limited Crewmax Sonic Red Hybrid - TRD Filters : EGR Window Visors : Cheer Dring Android Adapter : RC Bed Cover : RC 1.75 Level Kit : Undercover Swing Case
    Long tubes and full 3in dual exhaust from header collector to tip and no tune, she runs angry with safe AFRs
  16. Mar 19, 2021 at 6:56 PM
    Nowhereman
    Nowhereman New Member
    Al
    Monterey Bay area
    2021 Tundra SR5 / TRD / Cement
    Rough Country shocks, ReTrax cover, Summo springs, black out badging, bed extender, "some other things I can't mention"
    Looks to me like a smart header shop would build a long tube set with multi cat mid pipes as a package.
    Then charge a core charge for the buyer to send back their original cat mid pipes back for recycling..
    wildbill2020 likes this.
  17. Mar 19, 2021 at 8:03 PM
    wildbill2020
    What year is your truck?
  18. Mar 19, 2021 at 8:10 PM
    Downytide
    GTA
    2021
    wildbill2020[QUOTED] likes this.
  19. Mar 20, 2021 at 3:50 AM
    wildbill2020
    Did you use all 4 cats? Do you have a picture of the mid-pipe?
  20. Mar 21, 2021 at 1:48 PM
    Downytide
    GTA
    This is the only pic I have now, thankfully the headers are slip on design, so it left a lot of extra material for cutting, my exhaust guy also added custom v-bands as one of the clamps just kept leaking.
    I kept the TRD catback and added x-pipe as well.
    mfranzen89 likes this.
  21. Mar 22, 2021 at 6:14 AM
    wildbill2020
    Looks f
    Looks good!!!
  22. Mar 22, 2021 at 10:30 AM
    dirtydeeds
    Keith
    USA
    Any questions, reach out to Keith at 760-877-4234. He is always available to answer your questions and design the best system your money can buy.
  23. Oct 24, 2021 at 6:37 PM
    mfranzen89
    mfranzen89 New Member
    Mat
    Kansas City
    2021 Tundra TRD Pro LR
    What is the noise level difference from stock? Any drone?
    Pbed85 likes this.
  24. Oct 25, 2021 at 7:28 AM
    Downytide
    GTA
    quieter than stock, there's 0 drone and you can whisper on hwy speed, the best description I can give is a stock AMG V8 car, when you punch it, people will still notice you.
  25. Oct 25, 2021 at 9:18 AM
    dirtydeeds
    Keith
    USA
    It would he a disservice to a customer though. Some guys have very little miles on their trucks, while some have a lot of miles. I prefer to use each individuals actual cat’s from their truck. It’s a pita buys it’s the most fair way.
  26. Oct 25, 2021 at 9:52 AM
    Nowhereman
    Al
    Monterey Bay area
    There's ways; get mileage of said customer truck then pro rate costs. Remember, you want their business and give them the best product for their hard earned bucks.
  27. Oct 4, 2022 at 11:49 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    '21 Cavalry TRD Sport CM
    49hp and 89tq?! Just as a bolt on? Holy hell…
    dirtydeeds and TX210Tundra like this.
  28. Oct 5, 2022 at 7:26 AM
    dirtydeeds
    Keith
    USA
    Only if you run dual 3 exhaust with x pipe after the headers.
    all the while shorties do zero for Hp
  29. Oct 5, 2022 at 7:21 PM
    Toe404
    Toe404 just a poser
    Tomas
    Concord ,CA
    can I still retain factory cats? What’s the cost for something like that?
  30. Oct 6, 2022 at 6:00 AM
    dirtydeeds
    Keith
    USA
    We have multiple options. Give a call for pricing. 760-877-4234
