Best Replacement Headlight Bulbs?
Discussion in 'Lighting' started by Rngr188, Sep 17, 2017.
  1. Sep 17, 2017 at 2:32 PM
    Rngr188
    Rngr188 [OP] Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    I can't do aftermarket assemblies or retros but I want to improve my lighting. What's the general consensus on the best replacement bulbs? Also maybe replace the DRL and fogs also. Truck is a 17 Limited. Thanks.
    kenomouth64 likes this.
  2. Sep 17, 2017 at 2:35 PM
    Halogens?
  3. Sep 17, 2017 at 2:41 PM
    I went with Sylvania Ultra Stars i like them they bright to me also I got em for fogs too but I got H11s even though they are H16 and Sylvania don't make Ultra Bright in H16 so I used a dremel to grind away on the metal notches a bit wider on the base plate on the bulb to fit in the fog light housing works for me
  4. Sep 18, 2017 at 3:43 PM
    Rngr188
    Chad
    Harrison AR
    I just want to stick in some good quality halogen replacement bulbs that are way better than stock. Is that even possible? If so what's the most recommend? PIAA, Sylvania, Phillips, etc?
  5. Sep 18, 2017 at 4:18 PM
    chphilo
    chphilo Tundra addict
    Western PA
    I have Philips Crystal Vision (high beam, low beam, fog lights). I originally got them to match the LED DRL (the stock was too yellow), but they are very bright.
    Comparison to stock light (Yellow fog light is stock, low beam's Crystal Vision)
    Philips Crystal Vision (low beam)
    Illumination (Crystal Vision, low beam)
    Illumination (Crystal Vision, high and low)
    equin and Jbarber333 like this.
  6. Sep 18, 2017 at 4:37 PM
    Cell phone pics? What are all pic settings?
  7. Sep 18, 2017 at 4:38 PM
    Post #3
  8. Sep 18, 2017 at 4:51 PM
    TheBeast The Beach
    LEDs ? HIDs ?
  9. Sep 18, 2017 at 5:19 PM
    Rngr188
    Chad
    Harrison AR
    I just want a plug in replacement halogen bulb.
  10. Sep 18, 2017 at 5:20 PM
    Rngr188
    Chad
    Harrison AR
    What about the zxe?
  11. Sep 18, 2017 at 5:21 PM
    Omohundro
    Omohundro 2018 Not a Pro
    Jody
    McMinnville TN
    2018 Tundra Platinum
    I have LEDs from PIAA, I'm very happy with them. I am however swapping to the 18 LEDs. 59b043ac1a639a76cd5ffcf0ee7c5aea_3c9e02f90728351594366c39a20977b8599b7646.jpg
    I LEDededed mine to death when I bought it.
  12. Sep 18, 2017 at 5:22 PM
    Those are the "blue/blue white" bulbs
  13. Sep 18, 2017 at 5:30 PM
    Rngr188
    Chad
    Harrison AR
    Which series? Those look nice!
  14. Sep 18, 2017 at 5:53 PM
    Omohundro
    Jody
    McMinnville TN
    H4 (9003) High output 6000k
  15. Sep 18, 2017 at 6:01 PM
    Omohundro
    Jody
    McMinnville TN
    The only thing I didn't like was having to cut the rubber boot on the back of the lamp. ac7569cea68b9b9f837cd2a228ae1042_afa0168ebd4b4310f6e246e94520a0bf7958fe85.jpg
  16. Sep 18, 2017 at 6:46 PM
    chphilo
    Western PA
    iPhone, whatever its default auto-setting is. The light output is not perfectly white, but it seems to match the led strip pretty closely for halogen bulbs.
  17. Sep 18, 2017 at 6:59 PM
    Gotcha
  18. Nov 10, 2019 at 11:34 AM
    deerfarmer
    deerfarmer New Member
    anyone using the Cougar Motor LED? they seem to be the highest rated and brightest. I just wanted Tundra owners opinions
  19. Nov 20, 2019 at 3:38 PM
    salmonator
    salmonator New Member
    Tigard, OR
    2019 Tundra SR5 4x4 DC
    TheCAPA1 likes this.
  20. May 4, 2020 at 8:25 PM
    TheCAPA1
    TheCAPA1 New Member
    Wes
    Southest TN
    2019 Tundra Crewmax
    Icon Six Speeds, King shocks
  21. May 14, 2020 at 8:57 AM
    17_TUNDRA_GUY
    17_TUNDRA_GUY New Member
    Mat
    2017 Orange 5.7L Tundra 4x4 SR5 CM
    Icon stage 5 lift, 33s, Icon billet aluminum upper control arms, Air bags, Black Rhino Rims, LEDs
    Did cutting the rubber boots let alot of dirt in? I live in the desert and take my truck on dirt road quite a bit. The possibility of mud/dirt coming up and into the headlights is what is swaying me away from doing this so just wanted to see how your trucks doing
  22. May 16, 2020 at 7:25 PM
    Omohundro
    Jody
    McMinnville TN
    I’m not exposed to a lot of dust, probably would not be ideal in your situation.
  23. May 19, 2020 at 11:15 AM
    17_TUNDRA_GUY
    Mat
    Thanks for your help
  24. May 19, 2020 at 11:23 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    I installed High (9005) and Low (H11) beam S-V.4 LEDs from Lightwerkz.net in the 2007... I like them!
    I have a set of H4 S-V.4 LEDs on the way for my 2002.
