Best product for cleaning/protecting interior
Discussion in 'Detailing' started by Richard913, Jun 12, 2015.
  1. Jun 12, 2015 at 6:06 AM
    Richard913
    Richard913 [OP] New Member
    Rich
    2015 Tundra TRD Pro - Inferno
    Stock
    Hey all,
    The products I have been using to take care of my other vehicles does not seem to work well on the Tundra's interior. The couple products I have used either leaves it stick or dried out.
    I would appreciate any feedback on whats the best to use, and what I should stay away from
    Rich
  2. Jun 12, 2015 at 6:14 AM
    scratchex
    scratchex New Member
    2015 Tundra Limited
    3" lift TRD Exhaust 20" Fuel Lethal Wheels Toyo AT Tires Black Flares w/ spikes
    I use pretty much all of the products by Adam's Polishes. I use their Total Interior Detailer for the inside of the truck, it works great. Highly recommend them.
    http://adamspolishes.com/video?video_id=7
    They're currently running a sale for Father's Day. Promo Code: DAD15
    tat2ude39 likes this.
  3. Jun 12, 2015 at 6:30 AM
    Richard913
    Rich
    Stock
    Thanks. My daughter just recommended the same stuff, so I am going to go that route. Thanks!
  4. Jun 12, 2015 at 12:28 PM
    msg148
    msg148 Hulk Smash
    Philadelphia
    15 Tundra Platinum Package
    7" BDS coilover lift kit w/Fox front and rear suspension, 20" Monster 2 Rims, 37" Deegan Tires, TRD Exhuast, TRD Intake, Bushwacker Pocket Flares, Blacked out Mirrors/Door handles, LED interior lights, Stubby Antenna, Bakflip F1 Tonneau Cover, 20% Tint Front windows
    Just ordered it as well. Thanks for the coupon code.
  5. Jun 14, 2015 at 10:03 PM
    2015TRSPROSD
    2015TRSPROSD 2015 Tundra TRD PRO
    2015 TRD PRO CREWMAX
    XPEL protective Film (XPEL.com) Whole vehicle Tundra stamped letter insert (black) TRD PRO bed stamp letter insert Punisher Hood Decal (Matte Black) Fender and side cladding (TrdSparks) Side steps (Iron Cross- Linex coating) Retrax Pro Bed tonneau cover (Black) Punisher skull hitch cover (color matched custom paint) Michelin Defender LTX MS 295/70/18 Toyota Tundra 14-15 LED Taillights - Dark Red Smoked Lens Opt7 Headlights (bright as the sun pure white light) Tundra center console decider TRD Cold Air Intake Stubby antenna Weather Tech all weather mats TRD Brake pads Titanium exhaust wrap (covers exhaust pipes) Painted Engine Cover (Color Matched) Optima battery Billet Aluminum Optima Battery cover (Skull design-Optimatrays.com) TRD Sway Bar Kit Headlight Revolution (Gen 2 fog lights) Headlight Revolution Stealth light bar Color stable window tint Door sill protective trim Drivers side Grip Assist Hamdle add on LED bulbs inside & outside placements Focal front speakers and tweeters Kicker rear speakers JL stealth box subwoofers Kicker 4 channel amp Kicker mono amp Rebadged Whole
    I use their products as well. The soap gun works so well. The undercarriage spray is great. The glass treatment works great.
  6. Jun 15, 2015 at 1:03 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    code not valid and its not even fathers day yet.
  7. Jun 15, 2015 at 1:16 PM
    scratchex
    2015 Tundra Limited
    Sale ended on June 11th. They always run promo codes though my guess would be that the next one will probably be for July 4th if not sooner.
  8. Sep 3, 2016 at 5:46 AM
    Shawn850
    Shawn850 New Member
    Shawn
    Ontario, Canada
    2016 Tundra TRD Pro
    Custom Rock rails, ARE truck cap with Rhino-lining
    All depends on what you are trying to clean.
    I'll assume you mean the plastics in which case try and stay away from ArmourAll.
    While it looks great initially, it'll cause you grief in the long run as it makes the plastics more prone to sun damage and drying out.
    I'd suggest first that you look at the product to see if it's actually a "cleaner" as opposed to a spray on "protectant"..and use a micro fiber towel as it won't leave streaks, etc.
  9. Sep 3, 2016 at 6:18 AM
    I've been using the chemical guys. Only thing I don't like, is its not shiny when applied.
    driverdog likes this.
  10. Sep 3, 2016 at 8:35 AM
    15whtrd
    15whtrd Mr. Blonde
    I like 303 aerospace for protecting the dash and other plastics. On a sidenote when I bought the truck I noticed how easily everything was scratched, after applying 303 aerospace it is a lot more scratch resistance due to it being slightly slick. At least for the light brushes with your shoes on the door kick panel.
  11. Sep 20, 2016 at 7:39 AM
    Shawn850
    Shawn850 New Member
    Shawn
    Ontario, Canada
    2016 Tundra TRD Pro
    I use an Auto finesse cleaner for the interior but have yet to figure out what I want as a protectant for the interior plastic.
    On the outside I use their product called "Dressle". It's a water based finishing product that lasts and gives a new look shine as opposed to a greasy type of appearance.
    Chemicals Guys " BareBones" for the wheel wells and any other dark or black underbody trim..just a word of caution with the last product...it's oil based and when wet, it'll pick up everything so give it time to dry.
    As far as Chemical Guys products in general...Meh, they aren't bad but there are better out there. I've recently used their citrus decreased which suggested a minimum of 6 parts water to 1 part product...it didn't actually do much until the mixture was 4:1.
  12. Sep 20, 2016 at 8:27 AM
    ToyotaTundraMike
    2015 Tundra
    Any of you guys tried the 303 automotive rather than the aerospace?
    Wondering what the differences are. Says its for use on vinyl, rubber, plastics, etc. Same stuff different bottle?
    Gonna order some of the Adams stuff for the inside, but definitely need something to put on my bumpers and plastic trim on the outside! Thoughts on which would be best?
    Law323 likes this.
  13. Sep 20, 2016 at 8:51 AM
    ToyotaTundraMike
    2015 Tundra
    driverdog and SouthBoundSteve like this.
  14. Sep 20, 2016 at 5:45 PM
    ToyotaTundraMike
    2015 Tundra
    Ordered some 303 and Adams Total Interior. Looking at some of their car wash products and I may have to give them a try after reading the reviews.
    Anyone try their "h2o guard and gloss" or butter wax?
  15. Sep 20, 2016 at 5:51 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    303!!!!!
    Law323 and SouthBoundSteve like this.
  16. Sep 20, 2016 at 6:27 PM
    ToyotaTundraMike
    2015 Tundra
    How often is the butter wax supposed to be applied? Thinking about getting both and starting off with the butterwax and then doing the h2o every wash after that until it needs another butterwax.
  17. Sep 20, 2016 at 7:06 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    303 hands down!!
    I hate the gloss, grease look. 303 keeps it looking clean and brand new!
  18. Sep 21, 2016 at 6:49 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I've always been a huge fan of Mother's VLR - it's an amazing cleaner and conditioner. If you have leather it prevents cracking and keeps it clean. It smells great too. It's like $7 for a bottle that will last years, so worth a try.
  19. Sep 26, 2016 at 5:29 PM
    ToyotaTundraMike
    2015 Tundra
    +1 for Adams Polishes interior detailer followed by some 303. Got them both in today and gave it a shot and came away very impressed. Will certainly be trying some more of Adams products and using some of the 303 on the outer plastics next wash.
  20. Nov 24, 2016 at 6:18 AM
    briarpatch
    briarpatch New Member
    Meguiars Natural Shine...mild cleaning properties....nice (very mild) scent...leaves a nice matte finish behind. Available at your local WalMart for 4.99/16 oz bottle
    PermaFrostTRD and driverdog like this.
