Best point to check level on a Gen3 Tundra
Discussion in 'Towing & Hauling' started by ca1ic0cat, Jul 29, 2021.
  1. Jul 29, 2021 at 8:49 AM
    ca1ic0cat
    ca1ic0cat [OP] New Member
    Eric
    Crewmax Platinum
    so far just steel wheels for winter
    Getting ready to tow the trailer, finally. Getting air adjustable spring helpers in the rear end. So the next question is where to best establish level. I've tried all over the truck with a small bubble level but nothing is level.
    Anybody found a good reference point?
    Thanks,
    Eric
  2. Jul 29, 2021 at 9:01 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    take measurements from the wheel hubs to the top of the fender and compare front to back.
    snivilous likes this.
  3. Jul 30, 2021 at 11:26 AM
    crewmaxlmt
    crewmaxlmt How dare you!
    scott
    2020 Crewmax Limited
    My truck had to be level for checking the ATF level procedure. All of the videos said to check level on a frame rail and cross member. With about an inch of rake, my truck sits dead level.
  4. Jul 30, 2021 at 11:33 AM
    AZBoatHauler
    So.Arizona
    Eyeballing it should get you close enough. If you really want to measure, I’d use the method suggested by @frichco228 or just throw a level along the bed rail.
