Best Performance Chip?
Discussion in 'Performance and Tuning' started by EdwinHallett, Dec 13, 2014.
  1. Dec 13, 2014 at 8:56 PM
    EdwinHallett
    EdwinHallett [OP] New Member
    Edwin
    2014 White Tundra TRD Offroad 4x4
    ProComp 6" Lift, 18" Fuel Moto wheels, ProComp Xtreme Terrain 35" tires, full-TRD exhaust.
    Currently running a full TRD exhaust, no intake(yet). Any suggestions on a performance chip?
  2. Dec 14, 2014 at 6:47 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Hypertech interceptor is what I have. Gives some extra oomph.
  3. Dec 14, 2014 at 8:14 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    Hypertech - though be warned of their known issues. MIL due to MAF faults and loose terminals in the connectors. From the sounds though Hypertech has GREAT customer service!
    Bullydog just released a tuner as well.
    Cutzby40 likes this.
  4. Jan 11, 2015 at 10:43 PM
    Kwazziee
    Kwazziee New Member
    2014 Tundra 4X4 SR5 CM 5.7L TRD Off Road, Bilstein 5100, CB 3+ Shackles, CB Shims, CB Carrier Drop Kit, Flowmaster American Thunder Catback, 5000K HID, Blacked Out Taillight/3rd Brake Light, 4 x 5 inch KC Driving Lights, NFab Front Bumper Light Bar, Fuel Crank 18x9, Toyo Open Country 295/70/18, Custom Audio System and JBA LT Header w/ JBA mid-pipes (in progress), NFAB W2W - 6 steps (next on to-do list)
    The loose terminal issues has been resolved a little while back. I have first hand experience with Hypertech customer/tech support experience and I have to give them a 5 stars.
  5. Jan 11, 2015 at 10:50 PM
    csuviper
    Broomfield, CO
    I recently started getting the MIL code P0101 for MAF :( removed at the moment till I find out a fix.
  6. Jan 17, 2015 at 11:30 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    You running an aftermarket intake set-up with the correct HTI tune?
    Or stock set-up?
  7. Jan 24, 2015 at 9:27 PM
    csuviper
    Broomfield, CO
    I added the drop in filter in July and called Hypertech because there wasn't an option for drop in filter. They told me to run the stock setting. No problems till I added the exhaust. Guessing that it opened up air flow just enough to throw the sensors off.
  8. Jan 26, 2015 at 6:18 AM
    14burrito
    2014 SR5 CM 4x4 5.7
    Some people run drop ins with an aftermarket CAI setting with no DTC issues. Just a thought.
  9. Jan 26, 2015 at 7:17 AM
    csuviper
    Broomfield, CO
    Good thought. I was going to call Hypertech to check with them if that is an option, vs just making the change myself and hoping it works.
  10. Oct 24, 2016 at 3:18 PM
    Dustydirt19
    Dustydirt19 Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    I throughthis up in another thread but I figured I'd start my own about the Bully Dog Performance Chip...Couple questions... sorry im a newb:annoyed:
    1. This I'm assuming is a better option than the hypertech inceptor because of the code problems?
    2. Will this be affected at all cause I have an S&B CAI?
    3. Does this calibrate the speedo for bigger tire size? If not can it be used in conjunction with the hypertech in line speedo calibrator?
    Pros......Cons?
  11. Oct 24, 2016 at 4:03 PM
    CM-LENNY
    CM-LENNY No Complaints
    San Diego, CA
    2015 4x4 CrewMax SR5
    PRO shocks, 37's Nitto G2's 4:88 diffs, few other mods
    Hey Dustin, I can't comment on the Bully Dog programmer, but I installed the hypertech speedo calibrator and it works great for tire size correction. If you do the hypertech speedo calibrator, leave the usb cord hooked to the in-line unit under your dash so you have easy access to the cord for any corrections needed with your laptop computer. It took sometime back and forth, but I got my speedo dead nuts with this product. Again sorry I cant comment on the programmer.
    Dustydirt19 likes this.
  12. Nov 3, 2016 at 9:13 PM
    Kilos
    Kilos YotaPro
    Brett
    AZ
    2017 TRD Pro Barcelona Red
    Icon Stage 6 suspension Method NVs matte black w/Toyo Tires 35x12.5s SDHQ Sliders Cab mount chop Precision LED interior lights (6000k) GTR reverse LEDs 20% acrylic tint (heat resistant) Inyati spray in bedliner Black TRD Pro bed inserts Vivid Racing Leather wrapped steering wheel AJT Designs TRD shift knob AJT key fob Morimoto LED fog lights Full JL Audio sound system upgrade Kenwood 995S HU
    Anyone chipped their TRD Pro? Curious what's available and what performance can be gained. A Google search didn't turn up much good info...
  13. Nov 3, 2016 at 10:21 PM
    BullyDog
    Hypertech
    Kilos likes this.
  14. Nov 4, 2016 at 6:19 AM
    scout495
    scout495 New Member
    Does the chip void factory warranty?
  15. Nov 4, 2016 at 7:51 AM
    Sixpack
    Sixpack New Member
    Central Florida
    2014 Silver Sky Tundra CM TRD 4x4 Limited
    Moto Metal 951 18x9 rims with 285x75x18 Nitto Terra Grapplers , ESP lockable under seat storage, Husky mats front and rear, ReadyLift 3/1, Undercover Flex trifold bed cover, Bed Rug, interior LED's, 15% tint all around, TRD CAI, Bully Dog Platinum GT tuner, TRD rear sway bar, Flowmaster Series 44 dual exhaust system, LED head lights and Fog lights, 32" LED light bar in lower bumper cover, Switchback running lights, much more to come...
    Sean, which one is better?
  16. Nov 4, 2016 at 8:14 AM
    AnonVet
    AnonVet That's what she said!
    Weatherford TX
    2015 TRD SR5 CM
    7 inch pro comp 35x12.5 RPB Repulsars (Hate'em) 18x9 Rhino Glamis Bilstein 5100's TRD Pro grille Murdered out Spyder heads Smoked tails Leds all around her Debadged Go Rhino BR5 Front Bumper
    From what i've read, the bullydog is easy to to install and take out when you have to take the rig in for its servicing
    Kilos likes this.
  17. Nov 4, 2016 at 3:20 PM
    dirtydeeds
    Keith
    USA
    more than I can list here
    Bullydog is definitely better. But hypertech is easier to install and remove.
    Either will void the warranty if there was catastrophic failure and it was still on the truck when you send in the truck for the warranty work.
    Moral of the story, run bullydog and if the trick blows up remove it.
    Sixpack, Harris1881 and trayday like this.
  18. Nov 5, 2016 at 8:38 AM
    AnonVet
    Weatherford TX
    2015 TRD SR5 CM
    probably some of the best advice i've heard. That's an awesome quote. "if the truck blows up remove it"
  19. Nov 5, 2016 at 10:33 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    What is noticeably gained from installing these? I installed a plug and play on my last NA gas truck and all I noticed was a governor change and option to remove the rev limiter.
    dirtydeeds likes this.
  20. Nov 6, 2016 at 7:27 PM
    dirtydeeds
    Keith
    USA
    better throttle response, quicker off the line, revs quicker, speed governor removal, slightly more decisive shifting,
    overall just a little better driving truck.
    trayday likes this.
  21. Nov 6, 2016 at 7:27 PM
    dirtydeeds
    Keith
    USA
    and if it blows up remove it. hahahahahaah
    trayday likes this.
  22. Nov 8, 2016 at 11:43 AM
    Sixpack
    Sixpack New Member
    Central Florida
    Does anyone know what the difference between the Bully Dog BDX and the GT Platinum Gas is?
  23. Nov 8, 2016 at 2:51 PM
    Sixpack
    Sixpack New Member
    Central Florida
    That and the GT comes with a mount is what I gathered as well...
  24. Nov 8, 2016 at 3:53 PM
    dirtydeeds
    Keith
    USA
    The gt was a great piece back when it was released like 15 years ago.
    But like cell phones, tuners have evolved and that is what the bdx is. An iPhone style tuner versus a flip phone (gt)
    The bdx brings bullydog into the 21st century.
    Tunes are the same. And download procedure is similar.
    Wifi capable. Modern day.
    Kilos, Sixpack and GNTundra like this.
  25. Nov 23, 2016 at 8:11 PM
    SwampTundra
    SwampTundra New Member
    Macky
    Sorrento, La.
    2017 Tundra Crewmax Limited 5.7 FFV
    K&N CAI, Husky Liners (So Far)
    ANY IDEA ON A PERFORMANCE CHIP FOR 2017 5.7
  26. Nov 23, 2016 at 8:12 PM
    Bullydog tuner?
    Unichip
    Hypertech module
  27. Nov 23, 2016 at 8:13 PM
    SwampTundra
    Macky
    Sorrento, La.
    bully dog only makes up to the 15s. I contacted them
  28. Nov 23, 2016 at 8:13 PM
    Go big. Magunson S/C
    SOTABOY, AxelsHumanDad and ColoradoTJ like this.
  29. Nov 23, 2016 at 8:14 PM
    SwampTundra
    Macky
    Sorrento, La.
    that's what I want bad sean! how do I find one and aren't they like 6500?
  30. Nov 23, 2016 at 8:15 PM
    Blackfriday deals. Toytec is having a 10% off sale
    ColoradoTJ and SwampTundra like this.
