Best PASSENGER Floor Mat
Discussion in 'General Tundra Discussion' started by aaronoto, Jan 3, 2020.
  1. Jan 3, 2020 at 9:31 AM
    aaronoto
    aaronoto [OP] New Member
    I figured when I upgraded from my 2012 to the 2019 that Toyota would have finally put a floor mat clip on the passenger side, but I see they still haven't...
    I've tried Weathertech's and the TRD rubber mat with all the little spikes and it still slides and deforms the mat... Do they Husky mats stay in place any better? Anyone running something that doesn't actually slip?!
  2. Jan 3, 2020 at 9:34 AM
    19TurdPro
    19TurdPro New Member
    2019 Tundra TRD Pro
    I'm running Gator Liners (made by Husky, half the price) and they don't move. It comes with a huge spike you drill down into the carpet, but I chose not to use it.
    Patch999 and aaronoto[OP] like this.
  3. Jan 3, 2020 at 9:38 AM
    CavBluTundra
    CavBluTundra CavBluisdabomb
    Howard
    2018 TRD Off Road Limited
    I have the Husky liners and did not use the spike on the passenger side. Stays in place just fine.
    aaronoto[OP] and Tundra234 like this.
  4. Jan 3, 2020 at 9:39 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
  5. Jan 5, 2020 at 6:18 AM
    T-Guy69
    T-Guy69 New Member
    Long Island
    Black 2020 Tundra SR5
    Are the Husky mats hard like the WeatherTech's? I am looking for a softer mat like in my Ridgeline. I had WeatherTech in my wife's old Mini Cooper and didn't care for them.
  6. Jan 5, 2020 at 6:29 AM
    Sunnier
    Sunny
    San Diego, CA
    Husky makes 2 versions, one kinda stiff and hard, the other more of a matte plastic. Both fit well and stay in place. Even on the passenger side. There’s a $41t ton of comparative info on this forum if you search. The best price always seems to be at Auto Anything through rep @eccracer104 on this forum. Maybe hit him up when you think you’ve decided, ask if he knows any other better option, but it always seems to be that Husky’s fit and stay in place best.
    eccracer104 likes this.
  7. Jan 5, 2020 at 6:34 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    I have the maxliner mats and had the same issue. Bought two strip of industrial strength Velcro, places them on the underside of the mat and it grips the carpet extremely well. Doesn’t slide anymore
  8. Jan 5, 2020 at 6:46 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    My Maxliners are Custom fit, they can't slip, they're rigid and conform to the sides up a few inches on footwell and back to under seat. They can't move as they fit snug as a bug. Super easy to clean, don't need to remove, just use a damp rag and wipe then slide the dirt in one smooth move off and out of the vehicle. Couldn't be any easier. I'd suggest those for front and rear, the rears cover more than other brands and custom fit again.
    Luck and enjoy those Toyotas. : ^ )))
    Atlas415 likes this.
  9. Jan 5, 2020 at 7:57 AM
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    I have the 3D Maxpider mats in my crewmax and the mats do not move.
  10. Jan 5, 2020 at 8:21 AM
    Patch999
    Kyle
    TX
    2017 Bad@$$ TRD Pro
    I got Gators as well. I was putting in my ESP long box so I didn’t want to spend a lot on something I might end up cutting to fit. I like em and they ship fast. Ordered them Friday night and had them Saturday
  11. Jan 5, 2020 at 8:42 AM
    muledawg
    muledawg New Member
    Ryan
    Indianapolis,IN
    2019 Silver Sky Metallic TRD CM
    Do these go back under the rear seat or just to front edge? Thanks. In another thread I thought I seen a rear floor mat that went completely back under the seat? Anyone know of any? Might have been someone’s custom work.
  12. Jan 5, 2020 at 8:50 AM
    19TurdPro
    2019 Tundra TRD Pro
    My Gator Liners go under the back seat.
    muledawg[QUOTED] likes this.
  13. Jan 5, 2020 at 8:59 AM
  14. Jan 5, 2020 at 9:13 AM
    aaronoto
    Thanks all, I'll take a look at some of these suggestions.
  15. Jan 5, 2020 at 10:02 AM
    muledawg
    muledawg New Member
    Ryan
    Indianapolis,IN
    Got mine ordered. Thanks
  16. Jan 5, 2020 at 10:17 AM
    RitcheyRch
    Richard
    Santa Clarita, CA
    They do not on my 2012 crewmax. They may on later models
  17. Jan 5, 2020 at 11:03 AM
    19TurdPro
    2019 Tundra TRD Pro
    You'll like them. Best of all, when you pull the warranty slip out it says "made by Husky Liners".
    They fold the back liner in half in order to fit it in the box. You may have to massage them a little with a heat gun to make them fit over the door sills snug. I had to on mine.
  18. Jan 5, 2020 at 11:17 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    Husky Liners X-act Contour stay put in my truck, even without using the floor mat clip carpet screw thing.
    Sunnier likes this.
  19. Jan 24, 2020 at 9:57 AM
    Atlas415
    Atlas415 New Member
    I have had weathertech for 4 of my 'Yotas and went with Maxliner this time becasue the weathertech were hard to clean after a while and they seemed to get stiffer.
    I'd highly recommend the maxliner over the weathertech. They look better and fit better and have not moved since I put them in. I have not done a side by side measurement between the 07 Tundra/weathertech setup I have against the 20 CM/maxliners, but they look like the cover more of the threshold of the door, too.
    I am really really happy with them and will eventually replace all my weathertech mats in all 4 of my 'yotas
    dv8TRDPRO likes this.
  20. Feb 2, 2020 at 6:56 PM
    dv8TRDPRO
    dv8TRDPRO NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    do have picts the liners installed?
