Best Pass-Thru Boot for Camper Tops
Discussion in 'Tonneau Covers, Caps and Shells' started by JOHN911, Jun 7, 2016.
  1. Jun 7, 2016 at 10:28 AM
    JOHN911
    JOHN911 [OP] New Member
    Toyota Tundra
    4 x 4
    I just bought a 2016 Tundra CrewMax, which has the power rear window. I also ordered an A.R.E. Z series cap with a tilt down sliding front window. My intention is to purchase some sort of boot to connect the windows from my truck cab to my front cap window. This way, I can run my air conditioning through to the bed on hot days and my dogs will be comfortable. The problems I am running into is...
    A) Because my entire cab window slides down, many truck boots are not big enough to go around it
    B) I have heard that all boots will leak
    Do any of you know of a boot that is large enough to work with the Tundra's power window. If so, have you heard whether or not they are having problems with keeping a seal?
    Thanks in advance for any information that anyone can give.
  2. Jun 7, 2016 at 11:25 AM
    TruckyTruck
    TruckyTruck Dumbest Username
    Gary
    Never seen one for the crewmax but would like to know too.
  3. Jun 7, 2016 at 12:38 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Just let them ride in the back seat and put your junk in the way back.
    Seriously though, I have seen what might work for you on my buddies old truck. It looks like it was designed for use when the front window of the top is removed. It is not inflatable like many I have seen. It is clear and looks almost like silicone rubber. It installs right at the outer edge almost to the point of making the joint flush from cab to camper shell.
    I know this is not the link or part number answer you were looking for but I hope it helps anyway.
  4. Jun 7, 2016 at 12:42 PM
    15whtrd
    15whtrd Mr. Blonde
    I was under the impression that the boots sealed to the paint of the truck. Also I think when ordering your shell you can have them integrate it into the cost of the shell and have it already attached to it. Also a small amount of 3M tape on your paint will keep the boot from chafing. I didn't think the opening of a double cab was any different than the opening of the crew Max just the crew Max window rolls down. I think they all leak a little bit but how often are you running your AC in the rain?
  5. Jun 7, 2016 at 1:36 PM
    Old Time Goat
    Old Time Goat OldTimeGoat
    14+ Tundra, Crew Max, 5.7L, 4X4, TRD, SR5
    Though, I haven't tried it yet, I have also thought about how to make this work. The only way that I could come up with is to use the split, pipe insulation that is inexpensive and is probably available in all hardware stores. It is relatively soft and hopefully would not harm the paint. By the way, I just picked up my new Leer cap 2 weeks ago and the instructions warn to be careful with the paint for 90 days. Do not use a high pressure washer on it, don't wipe it with a cloth, etc, etc.
  6. Jun 7, 2016 at 2:14 PM
    TruckyTruck
    Gary
    My great Dane is 180 pounds and slobbers bad. No way he's getting in the back seat! :)
    I remember they used to make a sleeve that connected the two windows, but I've only seen them for small windows. These weren't inflatable.
  7. Jun 7, 2016 at 3:41 PM
    Over the LINE
    New Orleans
    ...and you don't think three labs 70, 65 & 55 pounds don't make a mess. Marathon Seat covers all the way around and a custom dog sling.
    zcarpenter92 likes this.
  8. Jun 7, 2016 at 4:39 PM
    TruckyTruck
    Gary
    Well if you are good with it, good on you. But not me man. He shakes his head and slobber goes everywhere. Im constantly washing his slobber off the side if my truck just from him being around it. Love that dog though
  9. Jun 10, 2016 at 5:59 PM
    JOHN911
    Toyota Tundra
    4 x 4
    Thank you all for the replies. I think that after all of this, I am just going to leave the gap between the cap and the truck cab and not worry about what air conditioning gets lost. I've heard so many horror stories about the different boots, that I just don't want to risk it. But again, I appreciate all of you taking the time to try to help.
  10. Nov 30, 2016 at 2:51 PM
    N22WLZ
    N22WLZ New Member
    WV
    I've used an inner tube before, likely a 21" motorcycle tube. It seems as if the sound was still a nuisance unless there was something denser like a towel laid in between the cab and bed.
  11. Jan 28, 2019 at 9:08 PM
    SiberianTundra
    SiberianTundra I heard Unicorns get horrible MPG
    Greg
    War Machine
    Camper shell, LED lighting VLEDs, Front Camera, Pro Comp wheels. Trd HID LED headlights. ESP storage rear seats.
  12. Sep 9, 2023 at 7:11 PM
    Curty
    Curty New Member
    Curt
