Best options to paint/powder coat rock rails?
Discussion in 'General Sequoia Discussion' started by MannFrank86, Apr 28, 2024.
  1. Apr 28, 2024 at 9:06 AM
    MannFrank86
    MannFrank86 [OP] New Member
    Hello everyone. I have an 01 sequoia and it has rock rails welded to the frame. They’re still solid but in bad need of a powder coat job. Am I correct in assuming I’ll need to cut them off, have them blasted and powder coated, then have them welded back on or is there another, less expensive and easier way? I tried to sand them and use truck bed liner a few years back but that didn’t last very long, especially where I put my foot to step into the vehicle. I think I’ll add some grip tape to these high traffic areas next time. Thanks for the assistance.
  2. Apr 28, 2024 at 9:13 AM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    2021 DC Cavalry Blue SR5 TRD Sport 4x4
    Rustoleum 9100. It’s expensive but amazing. I like to mix in a little sand to give it some grip
    MannFrank86[OP] likes this.
  3. Apr 28, 2024 at 9:15 AM
    MannFrank86
    Thanks for the reply. Would I still need to cut the rails off to do it correctly?
  4. Apr 28, 2024 at 9:18 AM
    MannFrank86
    You weren’t kidding about it being expensive. That said, if it lasts longer than powder coating, it’s worth it.
  5. Apr 28, 2024 at 9:19 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    You have rust in welds, it's nearly impossible to treat that without grinding rusty welds off and rewelding.
  6. Apr 28, 2024 at 9:23 AM
    MannFrank86
    Thanks for the reply. Would sandblasting fix that issue? I assume it would.
  7. Apr 28, 2024 at 9:42 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    Grinding wheel will do, but at the expense of weakening the weld. I.e. need to weld over a new bead.
  8. Apr 28, 2024 at 2:00 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    Just clean it up and put the 9100 on it. It’ll be fine lol.
  9. Apr 28, 2024 at 2:37 PM
    brobert225
    brobert225 Firm grasp of the obvious
    Your rails should not be welded on. Look underneath for the cap screws and hopefully you can get them out. Wire brush them and prime the base and you should be fine. Rock rails are meant to be used and paint is better than any coating.
  10. Apr 28, 2024 at 2:44 PM
    MannFrank86
    I’ve looked many times, they’re absolutely welded to the frame.
  11. Apr 28, 2024 at 2:50 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    I would just tape around the area and rattle can it. Get 2 or 3 coats on. Then some skateboard tape where you step.
  12. Apr 28, 2024 at 3:08 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
  13. Apr 28, 2024 at 3:14 PM
    rmorse
    rmorse New Member
    Bobby
    Bowie, MD
    What? Lol. They make bolt on sliders, weld on sliders and bolt + weld sliders. No way of knowing if they’re welded or not without looking at it so if OP is saying they’re welded, they’re probably welded
    Rodtheviking and MannFrank86[OP] like this.
  14. Aug 24, 2024 at 8:38 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Wire brush, rust converter and Steel It paint.
