Best older truck for my plans?
Discussion in 'Off-Topic Discussion' started by Atomic City Tundra, Mar 8, 2019.
  1. Mar 8, 2019 at 11:32 PM
    Atomic City Tundra
    Atomic City Tundra [OP] Cam Tower Leak Addict
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    So I have been kicking around the idea of getting an older truck to build into a camping/overlanding rig. I have a severe soft spot for the dent side Ford pickups (1973-1979) - I think they are the best looking trucks ever made, and pretty tough to boot. I have owned 3 of them. But, the legroom is a little lacking.
    Another era of truck I like are the late 90s/early 2000s Dodge Rams. I had a pretty bad experience with a 2000 Dodge Ram 2500 with a V10 - thing was in the shop a lot. That said, I still like them and probably should have just went with the Cummins.
    But it got me to thinking of starting a thread to see what others thought. Thought it would make a fun thought experiment. Any older truck is fair game. What do you think would make the best camping/overlanding rig? But, there are a few requirements:
    1. Has to be a pickup. I still want to be able to take it and do some work with it.
    2. Has to be a 3/4 or 1 ton. I am not going to be one of those that builds up a camping rig out of a 1/2 ton, only to be maxed out on payload all the time because of all the shit I have put on it.
    3. I would prefer it be a manual transmission - or at least have the option of swapping to a manual fairly easily.
    4. I am 6'8" and would like to be able to sleep in the bed. That dictates an 8' bed, but I would consider a 6'5" bed - as I can make that work. But, the 8' bed is preferable.
    Gas or diesel is fine - just as long as I have a fair amount of payload to work with to put stuff on.
    What do you think would be the best? And why?
  2. Mar 9, 2019 at 12:00 AM
    AlmightyCrash
    AlmightyCrash Tundra Rookie, Jeep Veteran
    Crash
    San Leon, TX
    2015 Tundra MGM SR5 TSS CrewMax
    I think it would be great to drop the power plant of your choice in a 49 chevy dually with a custom bed.
    Another fun option would be to put a classic body on a new chassis. At the last garage I worked in, we put a 50s international on a 2000s dodge Cummins 4x4 chassis.
    Classic Willy’s pickups could be a lot of fun too!
    The possibilities are endless.
  3. Mar 9, 2019 at 12:03 AM
    Atomic City Tundra
    Devin
    New Mexico
    Which is why I thought it would be a fun thread. :thumbsup:
    Thanks for the input!
    Mountun Goat likes this.
  4. Mar 9, 2019 at 12:08 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    I love the old highboys tho I like the earlier bump sides better.
    Noodle, joonbug, Watt maker and 2 others like this.
  5. Mar 9, 2019 at 6:50 AM
    Atomic City Tundra
    Devin
    New Mexico
    Bump for the morning crew.
  6. Mar 9, 2019 at 7:04 AM
    Outbound
    Aaron
    Northern Alberta
    I would never own a Ford. Even an old one. My family has never had luck with Fords, even going back to the 70s. My grandfathers tried them on their ranches and farms. None were reliable. I had a 2013 F150 *spit* and it was a nightmare.
    The pre-07 Rams are a great engine wrapped in a turd. The 5.9L Cummins inline 6 was a hell of an engine but the rest of the truck would fall apart around them.
    My personal pick would be a 2003 - 2006 Chevy Silverado or GMC Sierra with the Duramax diesel engine and Alison transmission. You'd want to upgrade the suspension and the front end components as they were the weak points, but other than that they're great trucks. Very comfortable to spend long trips in, good fuel economy (and easily tuneable) and very reliable. For an 8' bed, you'll be stuck getting a regular or extended cab.
    I'm just not sure if they Chev/GM trucks came in manual. If they did, it may be hard to find.
    There's a ton of other options but it kind depends on your budget too. LOL
  7. Mar 9, 2019 at 7:10 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    A square body Chevy with a Cummins transplant would be pretty cool. Solid front axle and a nice stack of leaf springs in the rear. Leg room lacking on those too as I remember.
    May not be many left at this point.
  8. Mar 9, 2019 at 7:55 AM
    BestGen
    BestGen New Member
    Paul
    IMG_2776.jpg ^This one has a Cummins 5.9 swap. IMG_2777.jpg Love the front ends on the 'bumpsides' IMG_2778.jpg :stirthepot: Just helping you out man!!!
    KarmaKannon, JC303, joonbug and 8 others like this.
  9. Mar 9, 2019 at 8:03 AM
    Atomic City Tundra
    Devin
    New Mexico
    It is hard to argue with personal experience. So I understand where you are coming from with the Ford comment. For me, the most reliable pickup truck I ever owned was a 1976 Ford F150 with a 360.
    As far as regular vs extended vs crew cab, I actually want to keep the rig as short as possible, as a shorter wheelbase can get more places a bit easier while wheeling. I know the short wheelbase thing goes against the 8' bed, but I really would like the 8' bed because of my stature. All that is to say I think the ideal for me right now is a regular cab with an 8' bed.
    As far as budget, I would like to keep it under $30K. I would do any work myself (aside from engine machining), so that helps in that department.
  10. Mar 9, 2019 at 8:04 AM
    Atomic City Tundra
    Devin
    New Mexico
    The bump sides look pretty damn nice, too.
  11. Mar 9, 2019 at 8:07 AM
    Atomic City Tundra
    Devin
    New Mexico
    No matter what I end up with, it will have a solid front axle - even if I have to convert it.
  12. Mar 9, 2019 at 8:20 AM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    X2 on the solid front axle for sure.
    Hondoman and BestGen like this.
  13. Mar 9, 2019 at 8:23 AM
    Grumpy Uncle
    Pat
    CO
    One of my all time favorites. 73 Highboy!83255b72ef988e1045b21010dec139b0.jpg
    JC303, Boerseun, Watt maker and 8 others like this.
  14. Mar 9, 2019 at 8:24 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Get a crew cab for company! Gotta be tall skinny tires tho. Straight axles on Seaver’s. Cummins 4bt turbo is nice and light and has more than enough power. They have bellhousings that bolt right up to ford transmissions also. Boom. 100k it’s yours haha
    KarmaKannon, Blueline, Twinky and 3 others like this.
  15. Mar 9, 2019 at 8:24 AM
    Grumpy Uncle
    Pat
    CO
    I have entertained over the years doing the same thing as you with the 73 Highboy.
  16. Mar 9, 2019 at 8:35 AM
    BestGen
    BestGen New Member
    Paul
    Dig those US Mags!
  17. Mar 9, 2019 at 8:41 AM
    Grumpy Uncle
    Pat
    CO
    Man Dad had the same setup, except his was the Limestone Green.
    Black Wolf and Mountun Goat like this.
  18. Mar 9, 2019 at 9:00 AM
    I bought a new 75 F150 4X4. Always regretted not getting the RC 8' F250 Hi Boy. Almost all the logging outfits in town used the Hi Boys for good reason. The Chevy trucks of that era had decent motors but cheap crap plastic interiors. My dad's new 74 WHITE 4X4 RC 8' Power Wagon was a base model but was one hell of a truck I have to admit.
    Add. I traded in my 69 Chevy RC 4X4 with 6 foot bed for my 75 Ferd. That 69 Chevy was way better than the new Chevy trucks that followed, (74+). a 69 HD with 8 footer would be cool but pricey right now for good reason too.
    Grumpy Uncle[QUOTED] and BestGen like this.
  19. Mar 9, 2019 at 9:31 AM
    BestGen
    BestGen New Member
    Paul
    I hear ya! Really miss my old Chevs... :frusty:IMG_0205.jpg70 Suburban 383, SM465, NP205, Rockwell axle w/factory Detroit Locker. IMG_0203.jpg72 Blazer 350, TH350, NP205, D44 & 12bolt
    Kerch71, Sunnier, Noodle and 6 others like this.
  20. Mar 9, 2019 at 9:32 AM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Beauty!
    BestGen[QUOTED] and Black Wolf like this.
  21. Mar 9, 2019 at 9:34 AM
    Yeah! 73 on down to 66?? maybe
    Mountun Goat[QUOTED] likes this.
  22. Mar 9, 2019 at 9:38 AM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
  23. Mar 9, 2019 at 9:43 AM
    KarmaKannon, Sunnier, BestGen and 2 others like this.
  24. Mar 9, 2019 at 10:03 AM
    Atomic City Tundra
    Devin
    New Mexico
    Good gawd. Pictures like that almost seal it up for me. Really nice truck.
  25. Mar 9, 2019 at 10:09 AM
    I thought the same thing!
  26. Mar 9, 2019 at 10:16 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m a little partial to the late 90s dodge ram with a Cummins and a manual transmission. They always intrigued me.
  27. Mar 9, 2019 at 10:17 AM
    Atomic City Tundra
    Devin
    New Mexico
    I like them, also. I think they look great, and I like the Cummins.
    15whtrd[QUOTED] likes this.
  28. Mar 9, 2019 at 10:21 AM
    15whtrd
    15whtrd Mr. Blonde
    I feel like if you addressed all the weak links around the truck it would be unstoppable.
  29. Mar 9, 2019 at 10:31 AM
    Grumpy Uncle
    Pat
    CO
    Now imagine that with a 427 or a 460 C.I engine!!:thumbsup:
  30. Mar 9, 2019 at 10:39 AM
    Grumpy Uncle
    Pat
    CO
    My dad got it the year I was born, and kept it until 79, then he got a 79, another favorite of mine. The 79 was dark metallic brown. It had a 351W and 4 speed. I would love to have either. Maybe one day.
