Best location for airbag compressor?
Discussion in 'Suspension' started by Zero One Actual, Jul 11, 2019.
  1. Jul 11, 2019 at 6:08 PM
    Zero One Actual
    Zero One Actual [OP] Member among Members
    I am going to be installing firestone airbags on my 2019 Crewmax.
    I also got the airlift wireless one EZ kit.
    https://www.airliftcompany.com/shop/25980ez/
    I was wondering if anyone has found a good spot for the compressor on the Tundra? I have read in other posts that above the spare tire works well. So that is my number one choice for now unless anyone has other recommendations or opinions.
    Thank you for your assistance.
  2. Jul 16, 2019 at 3:02 PM
    Zero One Actual
  3. Jul 16, 2019 at 3:19 PM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    It depends on where you're at and the weather the truck sees. I'm in Wisconsin and we install alot of these at my shop and because of the winters and road treatments here we always recommend mounting the compressor inside the cab of the truck. It's not the most ideal place for it but it has definitely cut down on compressor failure. Moisture and extreme cold will kill a compressor pretty quick.
  4. Jul 16, 2019 at 7:51 PM
    Zero One Actual
    I am in South Carolina. No snow. Very few cold days. But humid.
    Where in the cab? I have the under seat storage under my crewmax back seats. So I could see if it fits into one of those possibly.
  5. Jul 17, 2019 at 6:41 AM
    duece292
    Greg
    Green Bay, WI
    Under the rear seat is where I normally put it. It's usually a little cramped but it works. The hard part with the wireless one kit is finding a good place to mount the manifold. It needs to be oriented a certain way.
    Being in SC, I think you'd be fine putting it outside unless you're close to the coast and have to deal with salt water or salt air. Humidity isn't as bad as the 5 month barrage of snow, road salt, brine and dampness that we deal with here.
    Zero One Actual[OP] likes this.
  6. Jul 17, 2019 at 7:10 AM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    I'm in nw Ohio. Mounted in front of spare (dont have one 37s) on the very front cross brace of the bed. It's been there 2 years without issue. I fabbed up a splash shield with a rubber mud flap. Ends are open.
  7. Jul 17, 2019 at 9:20 AM
    Zero One Actual
    Thank you both. I am installing setup tomorrow with a friend and we will take a look at both spots! Do you have a pic of the mud flap condom?
  8. Jul 18, 2019 at 12:13 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    Not handy but I can grab one next time its on the lift.
  9. Jul 18, 2019 at 12:53 PM
    Duneflyer
    Duneflyer MGM is the light at the end of the tunnel
    Darren
    Yuma AZ
    2017 1794 edition Crewmax 4x4
    Nitro 4:88 gear package with locker in rearend, Procomp 6" lift, mid travel arms, with devers on back, Fox 2.5 coilovers
    . In SW AZ but it's on the frame near the back door
  10. Jul 18, 2019 at 1:27 PM
    TomC843
    TomC843 The wheel weaves as the wheel wills.
    Tom
    Charleston, SC
    16, 4X4, 4U3, Katzkins, Flowmaster, ARE MX, Swing cases, TRD skid plate, Volant CAI....
    this works for me, hi from SC.
  11. Jul 18, 2019 at 3:07 PM
    Zero One Actual
    Instal went super easy and took four hours.
    @Coachbuilder1 airbag spacers
    Air Lift 25980EZ
    Firestone Ride Rite kit for Tundras
    I decided to mount the compressor behind the rear left passenger seat. It is very quiet due to the seat and carpet dampening the sound. When it bleeds down its as loud as a balloon letting out air and as it inflated I can still carry on a conversation at a normal volume level.
    The EZ mount is very easy to instal as are the firestone bags with the coachbuilder airbag spacers. I used them due to the fact that I have his +3 shackles and he recommended them.
    We also installed an additional schrader valve for inflation as a back up because you never know.
    The remote allows for up to three preset PSI settings and you can also arrow up or down as you see fit and it takes a few seconds to get to the PSI you desire.
    timdske, Duneflyer and duece292 like this.
