Best LED / halogen bulbs for '15 Platinum
Discussion in 'Lighting' started by powdergeek, Nov 18, 2020.
  1. Nov 18, 2020 at 7:49 AM
    powdergeek
    powdergeek [OP] New Member
    Peter
    2015 Toyota Tundra Platinum 1794 Edition
    Fully stock but for a tonneau cover and LED lights
    I work full time in a hospital and my stock halogens are not giving me the light i need. What are some options for best halogen or LED? Installed some Auxitos in the hi/lo beams and the spread is horrible on low. Hi is decent but i need better.
    Ideas?
  2. Nov 18, 2020 at 7:58 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. Nov 18, 2020 at 8:06 AM
    powdergeek
    Peter
    Thanks much! I will check it out.
  4. Nov 18, 2020 at 8:19 AM
    frichco228
    For halogen, I have used silverstars in a few vehicles and they were always a noticeable improvement over the stock bulbs, easy to find and cost is good. I do not know much about LEDs available but there can be issues with light pattern when installing into halogen housing. Some also need relays so they do not flicker.
    I am sure others will chime in, plenty here have done various lighting upgrades from halogen bulbs, LED bulbs, headlight swaps to LED.
    One last thing in case you did not know, you can adjust the height/beam on your lights- can make a big difference if they have been pointed down vs straight out. The dial is probably on the lower right of the steering column.
  5. Nov 23, 2020 at 6:04 AM
    Charliebrn
    Charliebrn New Member
    NW Ohio
    2017 DC Limited 4x4 Tundra
    Tyger Folding Tonneau cover Polished stainless running boards LED interior lighting VLED Footwell Kit LED Bed lighting
    Yea... you could swap out the entire headlight housings for something like the TRDPros, but it’s an expensive option. The other way is to replace the bulbs with LED bulbs. There are a few out there, but my experience has been good with Auxbeams... something like $35 at Amazon.
    good luck and let us know what you decided.
    BTW, nice looking truck!
  6. Nov 23, 2020 at 3:48 PM
    WILLINH
    WILLINH New Member
    BILL
    NEW HAMPTON, NH
    2019 TUNDRA
    Check out Headlight Revolution. SV4 and the morimoto 2 stroke 3.0 are excellent. They have a great sale right now.
  7. Nov 23, 2020 at 3:57 PM
    PhearCVBz
    PhearCVBz New Member
    2021 Black Tundra DC, 2024 Black Tundra CrewMax
    I just ordered a set of the Auxbeams last night. They have a 10% ($4'ish) coupon right now. Figured it was worth a shot...A lot of people say its still not a good solution, but others have said they are surprisingly good.
  8. Nov 23, 2020 at 4:44 PM
    Vleds micros for bulbs or Morimoto XB leds for an entire housing.
