Best Headunit for an Amateur Install
Discussion in 'Audio & Video' started by GoCards82, Aug 14, 2019.
  1. Aug 14, 2019 at 7:28 PM
    GoCards82
    GoCards82 [OP] New Member
    Just purchased a '19 Crewmax a month ago. Love this damn truck. Had a '16 F-150 with the 2.7 V6 and aluminum body. That truck was the worst. A handtool box fell over and punched a hole in the bed.....no shit.
    The one thing I hate on my Tundra is headunit and sound, so looking to upgrade. Can anyone point me to a couple of units that have a pretty clean install with Carplay? Android Auto would be a plus also.
    Thanks
    CaptainJohnnySR5 and ManoTundra like this.
  2. Aug 14, 2019 at 8:14 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    xma and ManoTundra like this.
  3. Aug 14, 2019 at 8:16 PM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I installed a Pioneer GM Digital Series GM-D1004 under the seat. 100 bucks, It made a huge difference in the sound. I'm still using the stock speakers.
  4. Aug 14, 2019 at 8:17 PM
    TuFerLife
    TuFerLife New Member
    Taylor
    Chattanooga, TN
    2018 Tundra TRD Sport 4x4
    3" Toytec Eibach coilovers with .5" coachbuilder shims and Coachbuilder +3 shackles, JBA Upper Control Arms, Fuel Assault 20x10 -18 offset on 35x12.50 Cooper ST Maxx, Amp research stepbars, JBA Long tube headers, custom mid pipes and TRD Replacement exhaust system by Dirty Deeds, TRD Black Chrome Tailpipes, Bullit liner spray in liner, S&B CAI, Katzkin leather with Degreez heated and cooling system, Husky floorliners, Coachbuilder roof rack with 13 Rigid pods and Switchpro switch, TRD skid plate, Pop-N-Lock, Auto Tailgate down mod, Rattletrap sound deadener in headliner and door panels. Kenwood DDX 9906XR headunit with full Tech 12 volts sound system and dash cam.
    @james@tech12volts just hooked me up with an entire system, which included the Kenwood ddx9906xr, JL subs, hertz speakers, and a dash cam...
    Dude’s service is top notch! It’s going to be so sick. A couple pictures from my install so far...
    xma, CaptainJohnnySR5 and ManoTundra like this.
  5. Aug 14, 2019 at 8:45 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Another happy return customer of @james@tech12volts here. I first did his speaker upgrade w the stock radio and wow it was good already. I recently upgraded my radio from James also with the maestro rr module to retain steering wheel control and live data from the ecu. KENWOOD dmx906s it has wireless CarPlay with I love.
    TXTundra2722 likes this.
  6. Aug 14, 2019 at 8:55 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Another vote for getting in touch with James @tech12volts
    I love my kenwood headunit with maestro rr +TO2 harness, JL amp, Hertz door components, JL dash tweeters and JBL sub in custom box, all from James at an amazing price and excellent support and instruction.
    I wouldnt recommend anyone else other than James and won't ever do a car audio upgrade without involving him in some way
    TXTundra2722, xma and BlueBottle like this.
  7. Aug 14, 2019 at 8:58 PM
    Welcome from NY.
  8. Aug 15, 2019 at 8:03 PM
    xma
    xma New Member
    TX
    17 Cement CM TRD Pro
    Yup. James hooked me up with everything but the HU too, and it ROCKS!! Still contemplating the HU too....someone talk me into it / out of it— I am right on the fence!!
    TXTundra2722 and Pudge like this.
  9. Aug 15, 2019 at 8:13 PM
    Pudge
    CT
    Do it!!!!! You will not believe the difference it makes. And the android auto/CarPlay is great. I have and old kenwood and even it blows away my OEM JBL entune. I mean they even took pandora away from entune, it's useless. Go aftermarket and you won't regret it
    BlueBottle and xma[QUOTED] like this.
  10. Aug 15, 2019 at 8:26 PM
    xma
    xma New Member
    TX
    That’s it — one more nudge and I’m in.
    TXTundra2722 and Pudge[QUOTED] like this.
  11. Aug 20, 2019 at 2:59 PM
    Kwikfish
    Kwikfish Get your poop in a group!
    Tri cities,WA
    16 CM SSM
    The HU is where I'm thinking about starting,I hear it's the best bang for the money to start with.
  12. Aug 20, 2019 at 4:55 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    KENWOOD made my truck so much better. But wireless Apple carplay is what won me. Maestro rr was icing on the cake for me.
    ManoTundra and TuFerLife like this.
  13. Aug 20, 2019 at 6:58 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    I just installed mine today, and had the wireless carplay working... but now I’m having issues. I had to splice TPMS to program the remote start from JRT, but now it’s giving me this screen...
    Ugh!
    Harlan_2nd Gen likes this.
  14. Aug 20, 2019 at 7:01 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Did you use the KENWOOD gps antenna? If not switch to it. I had issues using the Toyota gos antenna. While you have the radio out I would check the vss connection and make sure it’s still good. I don’t know how tpms has anything to do with vss. Is your maestro unit still plugged into your obd port?
    TuFerLife[QUOTED] and Pudge like this.
  15. Aug 20, 2019 at 7:25 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    If you like to tinker with Android......12.1" Android Tablet Head Unit.
  16. Aug 20, 2019 at 8:12 PM
    TuFerLife
    Taylor
    Chattanooga, TN
    Good info. I also found a thread on issues people are running into and hopefully I can figure out a fix. I’ll pull it apart and look at this tomorrow.
    Appreciate the help.
  17. Aug 20, 2019 at 9:21 PM
    Harlan_2nd Gen
    Harlan_2nd Gen New Member
    2007 XSP Double Cab
    Bed cover LED Low Beam, High Beam
    What model Kenwood did you put in?
  18. Aug 25, 2019 at 6:42 PM
    cmiller219
    cmiller219 New Member
    Nashville, TN
    2018 Cement CM Tundra
    What all did you get? Spoke with him weeks ag o still waiting to hear back.
  19. Aug 25, 2019 at 8:24 PM
    Kwikfish
    Tri cities,WA
    16 CM SSM
    I talked to a local shop and 500 for a amp and install,james@12volt sent me a link for a package deal that's on sale,I want something simple to get more out of the system and not go broke....ya I know...
