Best headlight halogen light bulb option vs upgrade?
Discussion in '1st Gen Tundras (2000-2006)' started by Halsted, May 13, 2025 at 10:17 PM.
  1. May 13, 2025 at 10:17 PM
    Halsted
    Halsted [OP] New Member
    2004 Tundra 4WD V6 AC Manual
    I finally had a headlight go out. I was nervous about getting pulled over, so I stopped at an auto parts store and bought the Sylvania Silverstars. Didn't have time to do any research. Now that I'm home, looking at reviews, these things apparently go out really fast.
    Here are some reviews on Walmart. Not great.
    These Phillips Crystalvision Platinum ones seem to get better reviews.
    What are people running that they are happy with? Is there an LED option?
    I considered the projector upgrade and read about it, but I don't think I have time to order those right now and take my headlights apart at the moment.
    Corndog123 likes this.
  2. May 13, 2025 at 10:53 PM
    455h0le_dachshund
    455h0le_dachshund Tesler Thought Experiment
    Reverend Hotdog
    TX...big surprise
    For LEDs, the CoLight mini projector LEDs are less expensive than the Silver Stars and put out decent light. They're pretty easy to install, but you have to remove the reflector, so there's no going back without buying new housings if you don't like em. On the bright side, you'd be primed for an HID projector retro fit.
    Pretty much all the higher powered halogens are going to burn up faster than the regular ones. There's a special harness you can buy that allows you to run the super high power halogens. Like 100w. You got a buy em online from Europe because they're technically illegal here lol. But again, they ain't gonna last forever
  3. May 13, 2025 at 11:24 PM
    Halsted
    Do you have a link to these lights? I read this thread on the upgrade, and all of the links are broken to Amazon.
    How hard is it to get the headlight out and then level the lights?
    I guess a third option would be buying a really cheap halogen bulb and then ordering the mini project LEDs.
  4. May 14, 2025 at 5:25 AM
    Mustanley
    Mustanley Two time totaler
    Hendersonville, NC
    2004 Limited TRD 4x4 DC
    Eibach Shocks/Coils|Doug Thorley Headers|Spintech 3000XL Muffler
  5. May 14, 2025 at 5:30 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    Silverstars do wear out fast - I went thru 3 or 4 sets in a few years.
    Auxito is the brand I have learned lasts a long time - does not Blind oncoming traffic - is a wide long beam illuminating more than OEM halogens. They fit Exactly as OEM - using the same reflectors to control light output and again they replace just like OEM - are the same size and do Not use fans anymore.
    Here is an example but you need to ensure they are the correct style for your vehicle.
    Amazon.com: AUXITO 2024 Upgraded H4 LED Bulb, 1:1 Mini Size No Adapter Required, 6500K White, Non-Polarity, 9003 LED Fog Lights, Plug and Play, Pack of 2 : Automotive
    Dirt Ferguson likes this.
  6. May 14, 2025 at 1:32 PM
    Halsted
    These look like LEDs. I've read that they blind oncoming traffic if you use the same halogen reflectors?
    These look great, especially if they are plug and play.
    Also it says they are fog lights.
    These are 9003 which should fit all first gen Tundras I think.
  7. May 14, 2025 at 2:25 PM
    Corndog123
    Corndog123 New Member
    Sam
    Tennessee
    2014 SR5 Tundra Crewmax 4wheel drive 5.7
    Rough Country suspension, 305s, ARB bumper, light bar, Smittybuilt 10k winch. XD Buck 25 rims
    I have _________ brand name of LEDs and I REALLY like them. Such a huge improvement over the OEM ones. NOW I can see!!
  8. May 14, 2025 at 2:28 PM
    Halsted
    The name is blanked out. Not sure if that was intentional.
    Corndog123[QUOTED] likes this.
  9. May 14, 2025 at 2:31 PM
    Corndog123
    Sam
    Tennessee
    It was because I have no idea of the name of them. Got them off of Amazon. I'll go back and find them again. Stand by.
  10. May 14, 2025 at 2:35 PM
    PVT Pablo
    PVT Pablo
    Paul
    Kitsap County, WA
    2023 Tundra Platinum Hybrid
    Dobinsons IMS 2"/1", BMS 1" Wheel spacers with OEM Platinum Wheels. Icon Sway Bar Spacer. 285/65/20 Firestone Destination XT Tires.
    Please don't put LED's in reflector housings.
