Best DIY Bed Liner
Discussion in 'General Tundra Discussion' started by kenomouth64, Jul 5, 2017.
  1. Jul 5, 2017 at 9:11 PM
    kenomouth64
    kenomouth64 [OP] New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
  2. Jul 5, 2017 at 9:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    On my 84 crawler I painted on the rust-oleum Truck Bed Coating from the one gallon paint can. It was too rubbery and didn't harden up. Could take chunks off with your fingernail. Wouldn't recommend it.
    No experience with Herculiner.
    kenomouth64[OP] likes this.
  3. Jul 6, 2017 at 11:21 AM
    duece292
    duece292 Appalachian American
    Greg
    Green Bay, WI
    As someone who used to spray, I wouldn't recommend any of the DIY liner products. The material goes on so thin that by the time you've applied enough to get decent coverage you'll have as much invested in the DIY stuff as you would having a liner sprayed in. The DIY stuff has little or no UV resistance so if it's exposed to the sun it will look like charcoal in pretty short order. The DIY stuff also doesn't have anywhere near the tensile strength of polyurea so it's pretty easily chipped and scraped off. Just my opinion but I would shop around for a Bullet or Vortex dealer. They're usually less than LineX or Rhino and the material is basically the same.
  4. Jul 6, 2017 at 2:25 PM
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2023 Silver Tundra Crew 4x4 Plat
    I've used the rust-oleum truck bed and it work just fine. It will require several coats. Depending on the usage of the bed it might need touch up areas after awhile.
  5. Jul 6, 2017 at 2:38 PM
  6. Jul 6, 2017 at 4:16 PM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I would not recommend rust-oleum truck bed especially from the rattle can. I applies way to thin and requires a ton of coats. I used this on my sliders and front, engine and rear skids and require too much touch-up. I finally just took my sliders in to get coated and haven't regretted it. If you actually use your bed and haul quite a bit I would just cry once and get it coated.
  7. Jul 6, 2017 at 6:02 PM
    kenomouth64
    Tetrus
    I appreciate everyone's reply. I think I am going to try the "Linerxtreeme spray on Bedliner Kit 3 gallon Black with GUN" kit.
    Or for that price... I called around and found a shop that would do it for $340. I will likely just have the shop do it, so I know it is done right the first time.
