Best code reader for Tundras, other Toyotas?
Discussion in 'Recovery & Gear' started by chuckfinley, Nov 12, 2021.
  1. Nov 12, 2021 at 6:32 AM
    chuckfinley
    chuckfinley [OP] New Member
    2021 LR Tundra TRD Pro
    2021 LR Sequoia TRD Pro
    Looking at OBD II scanner, I presume, but what is best?
  2. Nov 12, 2021 at 6:38 AM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
    BravoDeltaRomeo likes this.
  3. Nov 12, 2021 at 8:26 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    2019 Tundra Crewmax Limited TRD DadWagon
    Do you leave this device in full time to use with Fusion? I'd like to get this set up and haven't had a chance to figure out how it all works.
    Within Fusion, is there a purchase option to run code for the various outputs we wish to monitor, such as transmission temps?
  4. Nov 12, 2021 at 8:31 AM
    boostedtrdpro
    Jeremy
    I literally just got it like a month ago, and yes I leave it in most all the time. I did purchase the Toyota modules or whatever it is that they call it. I’m still very new to this and haven’t quite figured it all out myself. I’m hoping it will give me good data to look at once my supercharger comes in and we start tuning the truck. I bought it based off recommendations from guys on this forum, that will probably be more helpful.
    DZ_[QUOTED] and diablodalton like this.
  5. Nov 12, 2021 at 8:46 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Glad I'm not the only one!
  6. Nov 12, 2021 at 5:57 PM
    Black
    Black Raised Hands Surround Us. 3 Nails To Protect Us
    2014 Tundra Limited CrewMax
    Falcon Leveling System, Coachbuilder +1s, RCI Skid Plates
    When you buy the OBDLinkMX+
    If you use the OBDLink app that comes with the device you don’t have to pay for anything all the vehicle add ons are free.
    There is no reason really to use another app.
    Fusion, Torque, and OBDLink are all pretty much identical programs.
    Here is a helpful thread. Long and lots to read as there is a bit of a learning curve to the app.
    https://www.tundras.com/threads/obd-thread-pids-apps-dashboards.60459/
    The bigger the screen the better as on the phone it can be difficult to make some good dashboard because you are limited in size.
    I have a Galaxy Tab I use to monitor when off-roading.
  7. Nov 22, 2021 at 11:04 AM
    DZ_
    DZ_ New Member
    Frederick Co., MD
    Updating this thread - I bought the above recommended OBDLink MX+ and did the setup this morning in the driveway while the truck warmed up. Fairly simple and straightforward to set up following the instructions and prompts. I was able to download the Toyota specific add-ons, at no additional charge.
    @Black How do you have your tablet mounted? I bought a 10" tablet to run GAIA, which works great, but haven't landed on a great mounting solution. Works great in the tank bag map sleeve on my motorcycle.
    boostedtrdpro likes this.
  8. Nov 22, 2021 at 4:39 PM
    Black
    @Black How do you have your tablet mounted? I bought a 10" tablet to run GAIA, which works great, but haven't landed on a great mounting solution. Works great in the tank bag map sleeve on my motorcycle.[/QUOTE]
    I have a Trackform tablet holder to be mounted to an ICS dash mount that I will get around to installing some day.
    Industrial Metal Drill Base Tablet Mount - By TACKFORM [Enduro Series] - iPad Holder for wall or truck. ELD Mount | Compatible with iPad Mini, IPad Pro 12.9, Galaxy S, Surface Pro & Switch https://smile.amazon.com/dp/B079TGWRNR?_encoding=UTF8
    https://www.ics-fab.com/products/tundra-amps-dash-mount
    DZ_ likes this.
