Best bug remover
Discussion in 'Detailing' started by Franco4x4, Aug 18, 2020.
  1. Aug 18, 2020 at 8:06 PM
    Franco4x4
    Franco4x4 [OP] New Member
    2019 tundra CM
    Best bug remover?
  2. Aug 18, 2020 at 8:16 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    I always use turtle wax bug and tar remover...works ok for me
    Sean492, Tchase and TxLock21 like this.
  3. Aug 19, 2020 at 5:02 AM
    War Machine
    War Machine SSEM # 5 3MW
    Well, Shine Supply Bug Off is the best chemical I’ve tried. That said, a spray bottle full of water and some Bounce sheets also work great. Just don’t let it sit on he paint for long. Use the Bounce sheets, then go back over it with a detail spray.
    Stroke250 and ToyoMafia like this.
  4. Aug 19, 2020 at 5:04 AM
    ToyoMafia
    Magic carpet.
    Cool slaps and plastiDip
    X2 for shine supply bug off
    War Machine likes this.
  5. Aug 19, 2020 at 6:41 AM
    CourtJester
    CourtJester New Member
    Alabama
    2019 Tundra TRD Pro, 2015 Tacoma
    There was an article several years ago in a motorcycle magazine covering the best bug remover for motorcycle helmet face-shields. Out of everything that they tried, it was determined that saliva was the best because of the proteins in it help break down the bugs and separate them from the surface.
    Drink plenty of water and spend some time spitting on your truck.
  6. Aug 21, 2020 at 5:58 AM
    Franco4x4
    2019 tundra CM
    Ordered shine supply. Thanks for the suggestion.
    ToyoMafia and War Machine like this.
  7. Aug 27, 2020 at 6:25 AM
    dspilot
    dspilot Professional Nomad
    North Mississippi
    2019 SR5 4X4 Silver Sky Metallic
    I've tried several of the chemical options, but I always go back to @War Machine's dryer sheet method. I just soak the front of the vehicle with the hose before I start washing, and deal with the bugs first before anything else......the dryer sheet makes it almost effortless (especially on a sealed/protected vehicle). I follow up with bedmaker after the wash so there's still some protection there.
    On a related note, this is a pic of what Carpro Bug-out did to some of the black plastic........
    ToyoMafia, War Machine and sotex like this.
  8. Aug 27, 2020 at 7:51 AM
    Franco4x4
    2019 tundra CM
    I actually tried shine supply bug of Monday night (should have took pictures) and it worked great. So far I haven't seen anything wrong with the black plastic on my truck. I would recommend it.
  9. Aug 27, 2020 at 8:02 AM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    The ceramic coating has worked wonders for me, but prior to that I have been used dryer sheets for years. They seem to work better than anything else I have ever tried - over 30 years of love bugs here in the South.
    dspilot likes this.
  10. Aug 27, 2020 at 8:14 AM
    War Machine
    I had the issue with Bug Off on plastic just this past weekend. I attributed it to not rinsing it off thoroughly or quickly enough. Definitely something to be careful of.
    ToyoMafia and dspilot[QUOTED] like this.
  11. Aug 27, 2020 at 8:45 AM
    Franco4x4
    2019 tundra CM
    Maybe I need to take a better look. I did rinse it off within seconds. I'll keep an eye on that for sure.
    dspilot likes this.
  12. Aug 27, 2020 at 10:29 AM
    CaptainGrumpus
    CaptainGrumpus The Mailman
    Maine
    2018 Inferno Tundra TRD
    I like Bug & Tar Remover. Works great and is an easy way to get rid off all those June bug guts.
  13. Aug 27, 2020 at 11:37 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    Did they test ejaculate??? :anonymous:
  14. Aug 27, 2020 at 11:49 AM
    TxLock21
    TxLock21 Bought a truck, got bit by the bug.
    I second this. Spray it on and let it sit for about 5 minutes (depending on the severity of bug guts), and it wipes right off.
  15. Aug 27, 2020 at 12:24 PM
    Tchase
    Tchase MostlyLurk
    Buckley WA
    2019 White Tundra Limited
    In work
    x2
  16. Aug 27, 2020 at 2:21 PM
    Bakershack
    Kelly
    Spanish Fort, AL
    2020 SSM 1794 4x4
    Sounds like you get WAY too excited about your truck! :bananadance:
  17. Aug 27, 2020 at 4:52 PM
    briarpatch
    briarpatch New Member
    Kenotek Anti Insect - never had any issues with it
  18. Aug 27, 2020 at 4:55 PM
    bensky
    bensky PlatinumPro
    Ben
    Utah
    2018 Red Platinum Tundra
    Auto soap and a pair of Nylons.
  19. Aug 27, 2020 at 5:52 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    Bakershack likes this.
  20. Aug 28, 2020 at 5:11 AM
    CourtJester
    Alabama
    I don't recall them mentioning that, but you can try it and post up your results though. It would make for an interesting write up.
  21. Aug 28, 2020 at 5:17 AM
    OMGOSH! @War Machine there's going to be an ACTUAL baby batter Tundra! :bananadead:
    Jim LE 1301 and War Machine like this.
  22. Aug 28, 2020 at 5:34 AM
    War Machine
  23. Aug 28, 2020 at 6:44 AM
    GODZILLA[QUOTED] likes this.
  24. Aug 28, 2020 at 7:45 AM
    ToyoMafia
    Magic carpet.
    Who knew getting bugs off the truck could be so entertaining
    GODZILLA and dspilot like this.
  25. Aug 28, 2020 at 8:24 AM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    With very tiny hands? :oops:
  26. May 29, 2024 at 7:37 AM
    TacomaTRD4x402
    TacomaTRD4x402 New Member
    Southern California
    '18 Tundra TRD Sport 2WD 5.7 Crew Cab MGM
    I just got back from a road trip to Texas and I'm currently dealing with all of the bug guts on my grill and valance.
    What exactly do you do with the dryer sheets? Just rub with a lot of elbow grease? I will most likely go and get something because lots of these bug guts seem to be one with the truck now :(
  27. May 29, 2024 at 8:29 AM
    TacomaTRD4x402
    Southern California
    Ended up using a spray bottle of soapy water and the dryer sheets and it seems to have done magic to my truck. No more bugs
    ToyoMafia likes this.
  28. Oct 6, 2024 at 10:54 AM
    Shooter8571
    Shooter8571 New Member
    Jack
    2023 Tundra Hybrid iForce Max 1794 trim
    none so far, but would like to
    Just stuff some sheets in the bottle of water? Or use them to rub off the bugs? :confused::confused:
  29. Oct 6, 2024 at 11:16 AM
    TacomaTRD4x402
    Southern California
    Nah, I soaked the guts first with soapy water them rubbed em away with dryer sheets.:thumbsup:
    Shooter8571[QUOTED] likes this.
  30. Oct 6, 2024 at 12:39 PM
    Shooter8571
    Jack
    Gotcha, thanks so much!
