Best 5w30 oil for tundra ?
Discussion in 'Performance and Tuning' started by FabioXc, Mar 12, 2025.
  1. Mar 12, 2025 at 7:01 PM
    FabioXc
    FabioXc [OP] New Member
    None
    I live in AZ which is hardly ever below 60 or even 70
  2. Mar 12, 2025 at 7:40 PM
    reywcms
    reywcms New Member
    Rey
    Beaverton,Oregon
    2017 Tundra Platnium
    Too many mods to come
    Amsoil
    Js18tundra, Ebrperk, Abell207 and 2 others like this.
  3. Mar 12, 2025 at 8:10 PM
    ZPhilip, Desert_Racer, Ace96 and 7 others like this.
  4. Mar 13, 2025 at 2:17 AM
    Clemsonman14
    Clemsonman14 New Member
    2020 SR5 Crewmax 4x2
    OP you’ve come to the right place. If there’s one thing everyone agrees on in this forum it’s what weight oil to use and what type of oil to use. I suspect you’ll have a definitive answer in no time
  5. Mar 13, 2025 at 2:49 AM
    OHwendTrd
    OHwendTrd Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Best? Subjectively I’ll agree with Amsoil. $$$
    Preferred, 5w-30 Pennzoil ultra platinum. 5k OCI.
    GAMark and FabioXc[OP] like this.
  6. Mar 13, 2025 at 3:09 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Kirksoil 10W-40 for maximum bearing and cylinder wall protection.
    2500 mile OCI
    Ebrperk and PermaFrostTRD like this.
  7. Mar 13, 2025 at 3:38 AM
    Retired...finally
    20w50. Change it once and drive the Wifes car everywhere. Don't even start the Tundra after the oil change. That causes excess wear. Your engine will last forever.
    hagrid, Saltyhero13 and BlackNBlu like this.
  8. Mar 13, 2025 at 3:43 AM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I was using Pennzoil Ultra Platinum but it's got pretty expensive. I do 5k OCI so I'm going to be switching to Kirkland.
  9. Mar 13, 2025 at 3:50 AM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    Noticed that too (on Amazon?), Walmart online has it for $89 for a 3pk.
  10. Mar 13, 2025 at 3:57 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    In AZ I would use 10w30 if not 5w40.
    Amsoil changed formula around 2012, it's not what it used to be. Only 10w30 is still the old formula, I think?
  11. Mar 13, 2025 at 4:06 AM
    _none_
    _none_ Poser
    2020 DC SR5 4x4
    Use whatever ya want, it doesn't matter. Just change it regularly.
    dondino, Norfolk757 and nobodyintexas like this.
  12. Mar 13, 2025 at 4:54 AM
    Good job guys. Made it all the way around the horn on the first page. Can close this one down now. Or run it for the next 32 pages…..
    Retired...finally and hagrid like this.
  13. Mar 13, 2025 at 5:06 AM
    BlackNBlu
    BlackNBlu Justa Member
    Rich
    MN
    24 Limited CM 5.5 Blueprint TRD OR
    5100's, 285/75/18, Air Lift bags, bits and bobs
    Only 32?
  14. Mar 13, 2025 at 5:23 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Pages, years or brands of oil?
    KNABORES[QUOTED] likes this.
  15. Mar 13, 2025 at 6:07 AM
    Ace96
    Ace96 New Member
    Western KY
    2021 Voodoo Blue TRD Sport
    I recommend using a degreaser every other oil change. Helps keep the engine clean on the inside.
    hagrid likes this.
  16. Mar 13, 2025 at 6:14 AM
    Norfolk757
    Norfolk757 עַם יִשְׂרָאֵל חַי
    Tom
    Norfolk, VA
    2015 White Tundra- CrewMax TRD Off Road
    Costco Kirkland for the win.. 5W-30, also just change it every 5K.
  17. Mar 13, 2025 at 6:18 AM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Penzoil Ultra Platinum
    OHwendTrd and Rodtheviking like this.
  18. Mar 13, 2025 at 6:19 AM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    The oil has detergents
  19. Mar 13, 2025 at 6:21 AM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Supertech is better than Amsoil.
  20. Mar 13, 2025 at 7:47 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Shots fired.
    OHwendTrd and PermaFrostTRD like this.
  21. Mar 13, 2025 at 7:57 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Can the engine tell the difference between the best oil and midrange oil if both are changed every 5k miles?
    Retired...finally likes this.
  22. Mar 13, 2025 at 7:58 AM
    Retired...finally
    I prefer Simple Green. It comes in 2 gallon jugs and two jugs puts you squarely in the operating range on the dipstick. For even better cleaning, reverse the battery terminals and run the engine backwards. Caution: Do this life hack only on the spring or fall equinox lest upon returning your battery terminals to the correct position after the degreaser flush you have a 50/50 chance of your truck waking up thinking it's in the Southern hemisphere and Google maps verbal prompts are in an Australian accent. Cool for a while but it does get old.:facepalm:
    JH8473, hagrid and Hbjeff like this.
  23. Mar 13, 2025 at 8:22 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Pennzoil Platinum or Ultra in 10w30
  24. Mar 13, 2025 at 9:17 AM
    Adamace1
    Adamace1 New Member
    2021 SR5 Tundra doubleCAB
    None....
    Amsoil SS if money is no issue
    Mobil one if you want to save money
    Kirkland oil if your cheap
    And from what I have seen and read 0w20 seems to be what was put in the million mile tundras, so is thicker really better...
    FabioXc[OP] likes this.
  25. Mar 13, 2025 at 9:46 AM
    BlackNBlu
    Rich
    MN
    I am deeply saddened by this semi-serious, half-hearted (and other hyphenated descriptions) recommendation.
    I fully expected to see a variation of Spraynard's tribologist approved formulation of -20W60 whale sperm oil humanely harvested from ethically sourced humpbacks.
    You're slipping man. You feeling alright?
  26. Mar 13, 2025 at 10:24 AM
    Leedaar
    Leedaar New Member
    2016 Tundra CM
    This!!!!
  27. Mar 13, 2025 at 11:11 AM
    JH8473
    JH8473 New Member
    2025 Tundra SR5
    None
    Nope
  28. Mar 13, 2025 at 11:23 AM
    PKFan
    PKFan my pronouns are (she/it) - c'mon, say it fast
    2018 Inferno! DC SR5 4x4
    Tyger Blade running boards, Valhalla's Shield cat plates
    There is a Pennzoil rebate at the moment for PP and PUP which makes it at or below the Kirksoil price when it's on sale (at least for me at Walmart). Just note the valid vendors (Walmart in-store OK, WM.com no bueno).
    hagrid likes this.
  29. Mar 13, 2025 at 11:28 AM
    LightTheBeam
    LightTheBeam New Member
    Sacramento, CA
    2024 Tundra Limited
    Bone stock (for now)
    Mobil 1 tastes the best.
    Daedalus and AZBoatHauler like this.
  30. Mar 13, 2025 at 11:48 AM
    713Tundra
    713Tundra New Member
    HTX
    2017 BBP Limited TRD OR CM
    Based on the reviews I've seen/read, Valvoline Restore and Protect seems to be the new king on the block.
