Best 2”ish Lift for 2.5 Gen?
Discussion in 'Suspension' started by AggiePhil, Mar 15, 2023.
  1. Mar 15, 2023 at 7:32 AM
    AggiePhil
    AggiePhil [OP] Texas Chapter President
    College Station, TX
    2020 Smoked Mesquite Platinum 4x4
    What are some of the best lifts around 2” that include rear leaf springs for a 2.5 gen? Been wanting the Dobinsons lift for quite some time now but I think it’s closer to 3”.
  2. Mar 15, 2023 at 8:07 AM
    PermaFrostTRD
    Northern NY
    1. are you wanting to lift the rear 2" as well?
    2. budget?
    3. usage?
    This will help the most knowledgeable folks steer you in the right spot.
    AggiePhil[OP] likes this.
  3. Mar 15, 2023 at 12:01 PM
    AggiePhil
    College Station, TX
    1. Yes, will need to lift the rear an equal amount (or close to it) to maintain the factory rake. Can then use Roadmaster RAS to get an extra inch or so, as needed.
    2. No limit to budget at this point.
    3. Mostly on-road, but want the look of a slight lift and ability to bump up to 34" or 35" tires (it has the factory 32" tires on it currently).
    With my 200 lb. camper shell and 200 lb. DECKED system, I really think I need a kit that replaces the factory leaf springs. Nothing crazy, but something slightly beefier back there. The Dobinsons kit checks this box, but I wish it gave a bit less than a 3" lift.
  4. Mar 15, 2023 at 12:07 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    With that much weight over stock can you confirm the Dobinsons kit will still yield the advertised 3" lift?
  5. Mar 15, 2023 at 12:21 PM
    AggiePhil
    College Station, TX
    400 lbs. ain't that much in the bed, plus I was planning on using the RAS to gain an additional inch or so in the rear if I need to.
    PermaFrostTRD likes this.
  6. Mar 15, 2023 at 12:22 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It's enough to sag but yeah the RAS should negate it.
    AggiePhil[QUOTED][OP] likes this.
  7. Mar 15, 2023 at 1:26 PM
    PermaFrostTRD
    Northern NY
    I'd look at assembling from parts and multi company. Fox 2.5 w/ or w/o resis (depending on your wants/needs) will get you nicely 2" up front. Alcan or Deaver leaf packs. And while fox doesn't have anything for the rear that will accommodate 2" lift, maybe Bilstein or King does. OME rear Shock absorbers might accommodate 0-3" im unsure. That way you could maintain the rake, have a pretty plush but sturdy ride where you need it.
  8. Mar 15, 2023 at 2:03 PM
    AggiePhil
    College Station, TX
    Hmmmm. So really no companies offering kits for a minimal amount of lift? Why does everyone want to go sky high with these things? Everything I've read says 2" is about as high as you should go. :confused:
  9. Mar 15, 2023 at 2:13 PM
    Steelruger22
    Steelruger22 New Member
    Aaron
    All over the place
    2016 Tundra Silver Sky Double Cab
    Leer Topper, Platinum Bumpers, Limited Grill, TRD Skid plate+cat plate, 5100's all 4 corners, Rear Airlift Bags, Compass/smartlink rearview mirror, Ditch Lights, LED Headlights/Fog lights, Husky Mats, Fog Light mod, DRL Delete, Window vents, Marathon Seat Covers.
    Bilsteins on the middle clip, 1.9in setting might be a good option for the front for you. I have been really happy with my 5100s
  10. Mar 15, 2023 at 2:14 PM
    AggiePhil
    College Station, TX
    I appreciate that. I keep reading so many different things about the Bilstein shocks. Some love em, some hate em. Hard to know till you try it, I guess. Remind me...those are the ones that require you to reuse your stock coil springs, right?
  11. Mar 15, 2023 at 2:19 PM
    Kung
    KG, VA
    I just bought a Toltec/Eibach lift that'll do about exactly that; have yet to put it on though.
  12. Mar 15, 2023 at 2:24 PM
    AggiePhil
    College Station, TX
    Link to that kit? I'm not familiar with it. Thanks!
  13. Mar 15, 2023 at 2:28 PM
    Kung
    KG, VA
    I believe this is it: The site says it's backordered, but I *believe* that they have some of the stuff in their backup warehouse, so they shipped the stuff same day. :)
    My requirements are same as yours, I believe - mostly on-road, with some minor off-road; and wanted the ability to bump up to 33.5" - 34" tires.
  14. Mar 15, 2023 at 2:41 PM
    HulkSmurf14
    2014 Tundra Limited
    Tastefully enhanced...
    2mchfun likes this.
  15. Mar 15, 2023 at 2:52 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    I used Eibach coilovers up front for 2 inches, and for the rear I used CB +3 shackles and RAS for a total of 2.5 inches in the back. I also carry about an extra 200 lbs in static weight in the back. You could do CB +2 shackles and it will give you 2 inches in the back. No leaf springs though.
    BravoDeltaRomeo likes this.
  16. Mar 15, 2023 at 2:54 PM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    Running the OEM TRD Fox kit plus RAS HD. Static load of 300+ lb in the bed (retractable bed cover, house battery, axe & shovel, and a Plano trunk full of tools). It looks like the factory rake to me, just a couple inches higher. This pic isn't the best, but it is current:
    HulkSmurf14 and PermaFrostTRD like this.
  17. Mar 15, 2023 at 3:22 PM
    PlatinumPro
    PlatinumPro New Member
    2015 PlatinumPro Crewmax
    Bilstein 6112+5100s, Rigid Lighting, Fuel 20x9 Bronze Blitz
    it depends which model you go with and how you order them. 5100's are lighter duty and can be ordered set up with springs OR the basic kit which is shocks, perches and clips but require you to reuse your springs and top hats. 6112's are considerably heavier duty and can come either set up or shocks, perches, clips and springs and require just the top hats from your old shock.
    i've had both and they're a great option for an inexpensive decent lift with 6112's being a better ride IME.
    I'd guess people that don't like them are people too cheap to buy what they should be buying and trying to budget lift then expecting perfect results.
  18. Mar 15, 2023 at 4:01 PM
    Gobstopper
    Gobstopper New Member
    My 6112’s at 1.9 have been great, awesome ride quality.
    Sleeper16plat and Johnmatrix like this.
  19. Mar 15, 2023 at 4:17 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  20. Mar 15, 2023 at 6:32 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    2021 SR5 TRD Sport 4x4
    It's probably impossible to beat 6112's at their price point.
    Johnmatrix likes this.
  21. Mar 15, 2023 at 6:52 PM
    PermaFrostTRD
    Northern NY
    Not disagreeing, but fox 2.0’s are currently cheaper and might beat the 6112’s. (Up to 2”)
  22. Mar 15, 2023 at 6:53 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Looks a little funny but you can fit 35s with no lift if you want. I’m pretty sure I just got about 2-2.5” front lift with the lowest Dobinson option spring (and 2-2.5” in the back with their leafs). The people getting crazy high numbers are using the springs meant for bumpers and/or extra lift (then get 5” or so haha).
    CaptRussia253 and AggiePhil[OP] like this.
  23. Mar 15, 2023 at 7:01 PM
    biebs96
    PA
    Another positive opinion on 5100s up front. Had them installed on stock tires and immediately noticed a “planted” feeling.
    Fast forward to 35s and a rear lift… the 5100s were the best bang for the buck.
    Dawoofles likes this.
  24. Mar 15, 2023 at 7:02 PM
    be_unscared
    be_unscared Not a truck doctor
    Brendan
    Central Cal
    21 Army Green w/skewp 4x4
    Icon stage 2 AAL. Just put mine on. 2.5” all around, but it’s adjustable so could’ve just as easily done a 2” lift. Not sure why this hasn’t been mentioned, but yes there are plenty of options to get a 2” lift
    Edit: I have 35s as well
  25. Mar 15, 2023 at 7:03 PM
    be_unscared
    Brendan
    Central Cal
  26. Mar 15, 2023 at 7:04 PM
    BillyB
    BillyB New Member
    Billy
    AZ
    I rode in a truck with Fox 2.0. It had quite a bit of body roll. It did soak up minor road imperfections better.
    It was plusher off-road for lower speed stuff and washboards, but once you start to pick up speed I feel the 6112 is better.
    For the record, I do have 6112/5160, so I obviously have spent the most time with this setup and only 1 ride on Fox 2.0.
    WTXSR5 and PermaFrostTRD[QUOTED] like this.
  27. Mar 15, 2023 at 8:58 PM
    Terndrerrr
    Music City
    6UR-FE
    My brother! What sliders are you running?
  28. Mar 15, 2023 at 9:13 PM
    be_unscared
    Brendan
    Central Cal
    “Tyger” bolt ons. Came with the truck when I bought it. I’ve only had it a couple weeks so it’s possible the original owner threw them on there. I’ll most likely change them out for something higher quality and with a solid plate for my kids to step on.
    Terndrerrr[QUOTED] likes this.
  29. Mar 15, 2023 at 10:11 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    ZPhilip and AggiePhil[OP] like this.
  30. Mar 15, 2023 at 10:26 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
    Elka 2 inch with a set of Deaver Overload replacement spring pack.
    IOCN Stage 3 set at 2 inch
