Bent horns
Discussion in '1st Gen Tundras (2000-2006)' started by Evillain, Dec 18, 2020.
  1. Dec 18, 2020 at 11:27 AM
    Evillain
    Evillain [OP] New Member
    2002 tundra trd
    Bent
    I am looking at and considering buying a clean 130k 2002 4x4 trd. But the owner rear ended another vehicle bending the horns and moving stuff around a little...Is 4K too much $ is this something I can fix with Moderate welding and body skills
  2. Dec 18, 2020 at 11:34 AM
    Ericbike6
    Ericbike6 So we're doing this shit today?
    Eric
    Austin, TX
    2019 Tundra TRD 4X4 sport
    Air bags, ARK liners, misc bullshit added also
    That's not repairable, needs a new frame.
    If your gonna use it for a farm truck or something like that, then go for it. Otherwise I would pass
    Stuck in the '00s likes this.
  3. Dec 18, 2020 at 11:43 AM
    Evillain
    2002 tundra trd
    Bent
    Thanks for your Re!
    Not very fixable then? Eh...
    Frame pull weld up parts etc?
  4. Dec 18, 2020 at 12:05 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I can't tell what I'm supposed to be looking at in this picture. I was expecting a picture of your horn for honking that is bent.
  5. Dec 18, 2020 at 12:12 PM
    Evillain
    2002 tundra trd
    Bent
    View of front frame extension (horn)skewed from front impact
    Nice truck till young driver hit somebody
  6. Dec 18, 2020 at 12:16 PM
    Evillain
    2002 tundra trd
    Bent
  7. Dec 18, 2020 at 12:20 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    No, not for $4k. Maybe $1500 if its for a farm or just an off road rig that you don't care about much, or even a parts truck. And damn, that was a beautiful truck.
    edit- hard to tell what we aren't seeing but how does the frame look behind that point? You would have to cut that section off, can't tell how far back the damage goes. If it stops before the coil buckets then new front end of the frame could be fabricated but might not be great in an accident.
    There are other trucks without this problem in fairly close price ranges, I would look elsewhere.
  8. Dec 18, 2020 at 12:24 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
  9. Dec 18, 2020 at 12:25 PM
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    That's a BIG ouchie...walk away.
  10. Dec 18, 2020 at 12:49 PM
    Glock 40
    Glock 40 I'm here to break shit
    Yukon Cornelius
    Way up thar
    2000 AC Limited 4X4 4.7L
    Deadpool Edition
    Run away, it should have a salvage title. Not fixable.
  11. Dec 18, 2020 at 1:24 PM
    Professional Hand Model
    Hand Protectors
  12. Dec 18, 2020 at 1:26 PM
    Hand Protectors
  13. Dec 18, 2020 at 1:46 PM
    Airbags deployed?
  14. Dec 18, 2020 at 2:06 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I'm perplexed by how the frame damage is so severe while the front bumper isn't that bad. It's like the frame absorbed all the impact.
    MS22 likes this.
  15. Dec 18, 2020 at 2:32 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    Maybe the car slid under the bumper . . . or hit a lower stationary object?
    Either way Run Forest Run !!!
  16. Dec 18, 2020 at 2:50 PM
    Glock 40
    Yukon Cornelius
    Way up thar
    Deadpool Edition
    It's been donkey punched.
    1lowlife, MS22, Leo's first and 3 others like this.
  17. Dec 18, 2020 at 4:22 PM
    Evillain
    2002 tundra trd
    Bent
    No airbags deployed
    I looked at A tundra 03 last winter that spun o icy overpass and was same way but he only wanted 1 k... everytning above bumper was fine rear corner was a little fungo too
  18. Dec 18, 2020 at 4:26 PM
    Evillain
    2002 tundra trd
    Bent
    ‘Golde hands’ thank you for the graphic showing approximate correct alignment of the chassis rail (post 12). I don’t have any comparatives prior to that. Good bit of distortion there, damn ! Thanks
  19. Dec 18, 2020 at 6:14 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    A real shame--nice wheels, too.
  20. Dec 19, 2020 at 6:08 AM
    04DCTundraMan
    04DCTundraMan Crimedog McGriff
    Ryan
    2004 Salsa Red Tundra Limited DC
    Sony Head Unit, Pioneer Speakers, Back up camera, Blacked out Emblems, SPC Control Arms, OME 2.5" front lift, 1.5" rear spacer, Flowmaster Super 44 muffler, LineX bedliner
    Trucks ded
    Pucks18 and FlyingWolfe like this.
  21. Dec 19, 2020 at 8:03 AM
    Question is, how is the rest of the frame aligned? Would have to get it on a frame table and check for square. Bent horns may only be the visible part. If the frame is straight overall, You could straighten, reweld and reinforce the front protruding frame sections. That wouldn't bother me. Price needs to be cheaper for a "totaled vehicle" though. Relatively low miles and otherwise good condition.
    Tundra2 likes this.
  22. Dec 19, 2020 at 7:04 PM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    How's that 'awning' over the rear slider?! . . . I'd sell hot dogs/ burgers out of that thing !!!!! Rad!
    TRDFerguson likes this.
  23. Dec 19, 2020 at 8:32 PM
    Stuck in the '00s
    Mikey
    SE Wisconsin
    Forget and leave your slider open a couple inches before a rainstorm and you'll appreciate it.
  24. Dec 20, 2020 at 7:30 AM
    Hand Protectors
  25. Dec 30, 2020 at 5:25 PM
    Evillain
    2002 tundra trd
    Bent
    Thanks for the input, i appreciate the group think too.
    So ... I found a 2000, ext cab, v8, 2wd, w a replacement frame in nice condition at a local salvage emporium. Do you know or does anybody know whether the frame will serve this 2002, ext cab w 4wd ? (2002 Frame is diamond w multiple distortions got it to a frame guy to measure up)...
    Thks
  26. Dec 30, 2020 at 5:55 PM
    koditten
    Kirk
    Midland of the Mitten
    I don't know what you all are afraid of.
    That's an easy fix for a frame shop.
    All my Toyotas have been front end crash, salvage titled trucks . I fix and drive them.
    It's a 18 year old truck! Who gives a shit if it was in in an accident. Fix it and drive it. You know going in to the deal that it does not have the safety features of a new truck. Wear your seatbelt.
    Take those pics to a frame shop and ask if they can give you a ball park estimate. I bet it's less than $500.
    Hint: if they want the work, leave a $100 bill on the counter. Let them know you are buying lunch. You just went to the front of the line buying lunch for them.
    SouthPaw, Evillain[OP] and Tundra2 like this.
  27. Dec 30, 2020 at 7:56 PM
    Evillain
    2002 tundra trd
    Bent
    I hear that!
  28. Dec 31, 2020 at 2:10 AM
    artsr2002
    artsr2002 2005 Tundra DC SR5
    'Yonder
    This lil guy has seen some shit! LOL
  29. Dec 31, 2020 at 2:38 AM
    HBTundra
    HBTundra New Member
    2006 DC 2wd
    I'd like to see how much that thing 'Dog Tracks' !!! . . . IE, when you're driving behind it you can see all 4-wheels!
    :facepalm:
  30. Dec 31, 2020 at 4:05 AM
    artsr2002
    'Yonder
