Benefit/Harm to Running W/O Front Sway Bar
Discussion in '2.5 Gen Tundras (2014-2021)' started by ThisGuy03, Jan 26, 2022.
  1. Jan 26, 2022 at 8:15 AM
    ThisGuy03
    ThisGuy03 [OP] New Member
    Las Vegas, NV
    ‘17 CM LTD TRD 4x4 MGM
    King 2.5s..TC UCA..35x12.50-18 M/T..AMP Steps
    Hey guys, do any of you run without your front sway bar? I’ve been driving mine since June 2021 without it. Alignment is fine, within spec. The only real benefit I’ve seen is gaining full travel capabilities for each side? I’m wondering if it has anything to do with the popping. /thump I’ve been experiencing lately. Dealer looked at it yesterday and didn’t mention anything about the sway bar haha!
    W3agle and Darkness like this.
  2. Jan 26, 2022 at 8:49 AM
    They will chime in but there are a handful of guys here that took theirs off.
  3. Jan 26, 2022 at 8:51 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    Not really sure about the harm but the benefit would be more/better articulation for offroading. It would move like a boat though in turns.
  4. Jan 26, 2022 at 8:54 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    Been driving without one for 5 years. I wheel my truck so I took it off for the articulation benefits. There will be naysayers but to each his own.
    831Tun, TRDFerguson and FrenchToasty like this.
  5. Jan 26, 2022 at 9:16 AM
    ThisGuy03
    Las Vegas, NV
    I’m mostly on road. But I wheel mine too. Thanks for the reply. Definitely boaty on the turns lol
  6. Jan 26, 2022 at 9:18 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    First gen here so take this as general observation.
    If your truck has stock suspension with progressive coils it will probably lean a lot and be twitchy going into/out of turns, especially at speed. Panic turns could get scary but I can't imagine it causing a truck to roll unless you're driving recklessly.
    If you have aftermarket coilovers, particularly with linear coils and a firm spring rate, you won't wallow as bad as a stock truck. You'll get the better articulation other mentioned because your independent suspension is now independent. You'll still lean pretty hard through turns but it is controllable, and you'll get used to it pretty quick.
    I have run Fox coilovers with 650lb coils, Camburg uca and no sway bar for over ten years. I am used to it and I sometimes have fun pitching my truck to one side through turns, leaning hard on the bump stop. When my wife started driving my truck on occasion I considered putting it back on to make it safer but since she generally doesn't drive it out of town I left it off.
  7. Jan 26, 2022 at 9:25 AM
    ThisGuy03
    Las Vegas, NV
    Awesome insight!
    I run Kings 2.5s ext travel with out of the box compression. TC Poly UCA’s . I enjoy the way it rides!
  8. Jan 26, 2022 at 9:30 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    The only thing, and I can't confirm it, is it might lead to a bit faster tire wear on the outside edges. I suppose it depends how hard you turn. I like to pretend I'm driving a stadium super truck when I drive. The only time I saw such tire wear was before I did a full rebuild on my front end and didn't bother rotating my tires for a while. Since the renewal I haven't seen such wear again. Rotate tires often and it probably will not happen.
    joseph_womack likes this.
  9. Jan 26, 2022 at 9:33 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Most who run w/o claim a better ride on the road as in feeling less bone jarring bumps. They also mentioned taking corners slower
  10. Jan 26, 2022 at 9:39 AM
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    I'll quote my other post...
  11. Jan 26, 2022 at 9:46 AM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Echoing the other replies, removing the FSB helped a ton with off road comfort, and also got rid of the jarring I’d get going over road irregularities at speed. I also take curves a little more carefully but not a huge difference over having the FSB.
    joseph_womack and FrenchToasty like this.
  12. Jan 26, 2022 at 9:57 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    As stated by @Darkness, removing the sway bar makes the IFS truly independent. So even on the road a bump on one side isn't transmitted to the other side like it is with the SB installed. I seriously doubt it's absence has anything to do with the noise you mentioned. I haven't experienced any ill effects from removing it and I don't have to drive slower through corners, it just leans more.
  13. Jan 26, 2022 at 9:59 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    I've tried chasing Warren on the mountain hills and it's true... he does not slow down through corners :rofl:
  14. Jan 26, 2022 at 10:23 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    2018 5.7 4x4 Crewmax TSS
    If the sh!t hits the fan on the highway and you have to saw at the wheel, you will wish you had a sway bar.
    ejes, 2mchfun and FrenchToasty like this.
  15. Jan 26, 2022 at 10:51 AM
    Tundra_361
    Tundra_361 New Member
    Victor
    2019 Black 1794 4x4
    I had Icons with no sway bar. Ride was smoother without it. Didn’t notice any significant increase in body roll.
  16. Jan 26, 2022 at 10:56 AM
    joseph_womack
    joseph_womack @ 4x4bound
    Joe
    Louisiana
    2007 RCLB, 4WD, 4.7L V8
    3/1 Lift, 35s, Front Bumper, etc etc
    Side note: :fistbump: Hey from BR, La
  17. Jan 26, 2022 at 10:59 AM
    joseph_womack
    Joe
    Louisiana
    Not gonna restate what everyone has been stating about body roll suspension etc, all true, I haven't had mine on for a couple months now.
    However, would you like to go into more detail about the thunk/popping you're talking about?
    Is it a loud pop when reversing in full lock? Or starting to accelerate slowly while in full lock?
  18. Jan 26, 2022 at 11:00 AM
    pvn.beluga
    pvn.beluga New Member
    Phuc (Phooc)
    Connecticut
    Either you're distracted or you're tailgating would be the only reason why this would happen.
    agunday21 and joseph_womack like this.
  19. Jan 26, 2022 at 1:14 PM
    Tundra_361
    Victor
    2019 Black 1794 4x4
    Curios if you have driven the truck without the sway bar?
  20. Jan 26, 2022 at 2:57 PM
    ThisGuy03
    Las Vegas, NV
    So its really weird. It’s almost the same sound as someone posted up in a different thread here a while ago but I don’t think to OP is around anymore. When I apply brakes at a certain speed, low speed like, 15mph and under, I can feel a pop/thump in the pedal and the steering wheel. Straight wheels, no turning. In reverse if I can hear the popping and or almost stressing of metal on metal pop/stress. Straight wheels and sometime when half way to full lock. Never while turning the wheel do I hear this noise. It’s so weird
    joseph_womack[QUOTED] likes this.
  21. Jan 26, 2022 at 3:01 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Maybe a worn out UCA ball joint.
    joseph_womack and 831Tun like this.
  22. Jan 26, 2022 at 3:02 PM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    My wife's old Camry had something similar and ended up being the brake pads, or at least that's what the Toyota tech determined. There's enough clearance built into them that they can slide and "thunk" in the caliper during breaking. It may or may not be the same thing, but something to consider.
    BiggHertz, joseph_womack and 831Tun like this.
  23. Jan 26, 2022 at 4:21 PM
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Cypress, TX
    2018 SR5 X Series Tundra (sold) - why, why, why
    I had a clunk with my Taco - never did take it in as I now have the Tundra, but had read it was most likely the drive shaft. It only happened when low speed, and only happened once on the change of direction (i.e. did it when I first would brake going forward, and not again after. Once I would go in reverse and slow to stop, it would do it again, but not again as long as I never put it back in drive). sounds like a UCA - hopefully not a CV joint?
  24. Jan 27, 2022 at 6:26 AM
    ShreveportTSS
    ShreveportTSS Huh?
    Eric
    Louisiana
    Absolutely. You just have to drive like you don't have a sway bar.
  25. Jan 27, 2022 at 6:45 AM
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    Looks like a good time to me.
    831Tun, joseph_womack and Cruzer like this.
  26. Jan 27, 2022 at 7:33 AM
    Cruzer
    Cruz
    Sunnyvale, CA
    That video said that the truck would’ve handled the test better if it had a REAR sway bar. We’re all fucked :rofl:
  27. Jan 27, 2022 at 7:37 AM
    joseph_womack
    Joe
    Louisiana
    Oh totally forgot about this… is it only when you accelerate when it thunks? And when braking? I know you said this is all low speed, but try getting going fast off the line and braking hard, does it clunk both times? If so it could be a ball joint (probably UCA)
    Did you lift your truck? Factory UCA?
    Cruzer and TRDFerguson like this.
  28. Jan 27, 2022 at 7:38 AM
    RaginTxn
    RaginTxn New Member
    Ya done messed up..
    Cypress, TX
    hahaha, the might moose test (one that I have seen AND experienced a real life) - I think the point of the guy in the video is very valid - it is a good test that should be taken with a grain of salt (it's an edge case test). The conditions have & are regularly debated as not normal driving conditions (i.e. you're going to be using brakes - it's a great push the limits test but even "super handling cars" fail regularly - does it really need to apply to all vehicles - should all vehicles be held to the same standard when they are designed for different end purposes, etc. etc. etc.). I mean you can plan for edge cases, but if the moose test was an end all says all test then we can all say goodbye to our functional OR oriented vehicles.
    More to the point (and the point made well here) - drive the vehicle within the limits of the mechanical setup of your vehicle (i.e. if you don't have a sway bar and a lifted truck - drive it that way; if you want to "fly" through corners - get a beefier sway bar and/or get a "sport handling" setup, but don't complain about OR performance). One thing I would add is to make sure you also have appropriate bump stops (many people don't adjust their bump stops after they do their lifts, or if they're towing regularly heavy loads and not getting appropriate support in the rear). M2C
  29. Jan 28, 2022 at 3:15 PM
    handyman
    handyman New Member
    2016 Crewmax Limited in Sunset Bronze Mica
    BFG All-Terrain TA KO2 Tires, Pillar Grab Handle, Curt Front Hitch & Winch Mount, Smittybilt XRC-8 Winch, Escort Solo S3 Radar Detector, Tekonsha P3 Brake Controller, Galaxy DX 2547 CB Radio, Center Console Organizer & Tray, ESP Rear Seat Storage, SumoSprings, Pop & Lock Tailgate Lock, AMP Bed Step, AMP Side Steps, BacFlip G2 Tonneau Cover, and more pending.
    After watching the video, I've been driving for decades now, accident-free, without once having to turn that sharply at speed. I know the limits of my vehicle and never go beyond that. My turns are gradual and controlled.
    Also never encountered a moose or similar stupid enough to get in my way. Seen deer beside the road, but simply slowed down. Anyway, if I ever do encounter such a moose (and can't turn enough to avoid it), I'm certainly not going to lose control of my vehicle, risking my life, just to avoid hitting it. I'll simply hit the brakes hard to reduce the impact and let it go with that.
  30. Jan 28, 2022 at 3:20 PM
    handyman
    handyman New Member
    Weren't you paying attention? I watch everything in front of me, including that on either side of the road. Nothing (vehicles, pedestrians, animals, etc) potentially posing a risk escapes my attention and response.
