belt problems
Discussion in '2nd Gen Tundras (2007-2013)' started by tagteam12, Jan 29, 2018.
  1. Jan 29, 2018 at 12:04 PM
    tagteam12
    tagteam12 [OP] New Member
    2007 silver trd tundra
    so ive replaced my fan belt 3 times now. first time it shredded, replaced it. 2nd time i hit a pot hole and the belt just fell off, no damage to belt. replaced tensioner pulley. its now come off for the 3rd time. shredded again. any suggestions?
  2. Jan 29, 2018 at 12:50 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
    Tell us a little more about this belt you speak of...what year Tundra?...Pics?
    Welcome from Western NC! :thumbsup:
    GNTundra and bicklebok like this.
  3. Jan 29, 2018 at 12:50 PM
    Something not right. Who is doing the belt install?
  4. Jan 29, 2018 at 1:00 PM
    tagteam12
    I have a 2007 SR5 tundra. Dont remember the brand of the belt i used. First and 2nd replaces belt was out in by father in law cause I was away at work. 3rd was a mechanic.
  5. Jan 29, 2018 at 1:04 PM
    Something loose? Any of the pulleys? Seen members on here like the Gatorback belt..I like Gates
    GNTundra likes this.
  6. Jan 29, 2018 at 1:17 PM
    tagteam12
    Think the belt we used was dayco.
  7. Jan 29, 2018 at 1:35 PM
    tagteam12
    Duralast from autozone.
  8. Jan 29, 2018 at 1:51 PM
    tagteam12
    I just replaced the pulley cause it had a little wobble in it. Thinking i might hv to replace tensioner assembley also. It’s a 5.7. Liter
  9. Jan 29, 2018 at 2:07 PM
    tagteam12
    Called dealer to get a price. Said about $123.
  10. Jan 29, 2018 at 2:18 PM
    Roman
    Roman Toyota Parts Master Vendor
    Roman
    Franklin, TN
  11. Jan 29, 2018 at 2:29 PM
  12. Jan 29, 2018 at 2:41 PM
    Roman
    Roman
    Franklin, TN
    Patriot likes this.
  13. Jan 29, 2018 at 3:07 PM
    tagteam12
    Thanks for the part info.
  14. Jan 29, 2018 at 3:32 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    When you say "fan belt" we're talking serpentine belt right? One of the only issues I've ever had with a Tundra was the serpentine belt on my 07. It had signs of cracking at only 35k. It was replaced by the dealer 'cause there was also a water pump leak that was still under warranty. Well, the dealer didn't line it up right, all the grooves weren't in the slots correctly and the belt shredded within a couple k miles.
  15. Jan 29, 2018 at 3:45 PM
    tagteam12
    I had my water pump replaced about 6 years ago. Had a crack in it. Didn’t notice any difference until I needed oil change and they took skid plate off. It had collected on top of it.
  16. Feb 7, 2018 at 11:54 AM
  17. Feb 7, 2018 at 11:56 AM
    Roman
    Roman
    Franklin, TN
    It's part only. Once you add it to your cart, you can input your zip for a shipping quote. Shouldn't be too much on just the tensioner.
  18. Feb 7, 2018 at 12:12 PM
    Thank you!
  19. Mar 16, 2021 at 11:01 AM
    Tundralicious
    Tundralicious New Member
    Toytoy
    2020 Tundra TRD Sport Premium
    Stock for now
    I had to replace my Serpentine Belt on my 2020 Tundra with 13 000km. Only a 1000km after, it's starting to make the same noise....It's squealing hard under idle. I'm not sure what to do anymore. I'm very disappointed in Toyota products. I made the change not too long ago to Toyota and if it keeps happenning, I want to get rid of it.
  20. Mar 16, 2021 at 8:24 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level Lift, DIY SAIS preventer, headers.
    Take it back to dealer, under warranty right?
  21. Mar 16, 2021 at 8:26 PM
    Dalandshark
    Northwest
    Yes, had the same problem with my recently. The whole tensioner should do the trick as others said. Check the fan bracket bearing too when you have the belt off.
  22. Mar 16, 2021 at 8:28 PM
    Tundralicious
    Toytoy
    Stock for now
    I will be the 2nd time for the same problem.
