Belt moldings for all years and models
Discussion in 'Toyota of Cool Springs Parts' started by Roman, Sep 6, 2019.
  1. Sep 6, 2019 at 9:06 AM
    Roman
    Roman [OP] Toyota Parts Master Vendor
    Roman
    Franklin, TN
    There's been quite a few requests for belt moldings here lately, so I figured I would create a thread to link people to that has all the links for the parts in the store.
    What's a belt molding? It is the black rubber strip on the inside and outside of the window that the glass rolls up and down into. If your window is down, your arm would rest on the belt moldings. These are the outer belt moldings:
    Over time, the sun and elements can cause the rubber to deteriorate and they start looking like crap. The inner belt moldings are usually fine.
    Here are links to all of the belt moldings grouped by model.
    2000-06 Regular cab and Access cab
    Passenger's Front
    https://parts.toyotaofcoolsprings.c...ip-access-cab-and-regular-cab-only-681600c010
    Driver's Front
    https://parts.toyotaofcoolsprings.c...ss-cab-and-regular-cab-models-only-682100c010
    2004-06 Double cab
    Passenger's Front
    https://parts.toyotaofcoolsprings.c...ather-strip-double-cab-models-only-757100c010
    Driver's Front
    https://parts.toyotaofcoolsprings.c...ather-strip-double-cab-models-only-757200c010
    Passenger's Rear
    https://parts.toyotaofcoolsprings.c...ather-strip-double-cab-models-only-757300c022
    Driver's Rear
    https://parts.toyotaofcoolsprings.c...ather-strip-double-cab-models-only-757400c022
    2007+ Regular Cab
    Passenger's Front
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-weather-strip-681600c030
    Driver's Front
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-weather-strip-682100c030
    2007+ Double cab
    Passenger's Front
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-681600c020
    Driver's Front
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-682100c020
    Passenger's Rear
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-double-cab-681630c010
    Driver's Rear
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-double-cab-681640c010
    2007+ Crewmax
    Passenger's Front
    Driver's Front
    Passenger's Rear
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-crewmax-681630c020
    Driver's Rear
    https://parts.toyotaofcoolsprings.com/oem-parts/toyota-belt-molding-crewmax-681640c020
  2. Mar 17, 2020 at 2:54 AM
    JQ3
    JQ3 2005 XSP rwd
    Great post! Does the 04-06 double cab work for the Sequoia?
  3. Mar 17, 2020 at 6:11 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    How about the moldings that go around the door frame for say an 01 4runner? I can spread the word on 4runner sites....after I buy mine, haha....
  4. Mar 17, 2020 at 12:17 PM
    Roman
    Roman
    Franklin, TN
    The front ones are the same, but the rears are not.
    A little off topic, but I can look it up for you. :D Is it the one on the door, or the one on the body? Which door?
  5. Mar 17, 2020 at 1:06 PM
    Johnsonman
    Austin
    Sequoia
    Good question, should have thought of that. Body on driver's side. It wears where someone's food drags on it right in the middle of the lower door portion...so it goes there and up and around sides up to top and across. Thanks!
  6. Mar 17, 2020 at 2:39 PM
    Roman
    Roman
    Franklin, TN
    Sunnier and Xsnrg2006 like this.
  7. Jun 14, 2020 at 7:11 AM
    Xsnrg2006
    Xsnrg2006 Smiley the Tundra
    Dale
    SoFla
    2006 Limited Crew Cab
    Hello Roman. Just wondering what the Front Dr Side Inner Belt molding on 2006 DC part # is. While replacing inner door handle couldn't figure how so much dirt had gotten inside panel then saw the split in that part. It has several opposing metal tabs on panel that I guess bend to R&R?
    Thanks!
    Nevermind, I bird dogged it.
    Make sure this part fits your car
    Door Window Belt Weatherstrip - Toyota (68174-0C030)
  8. Jun 23, 2020 at 12:30 PM
    LillDragun
    LillDragun New Member
    This ought to be a sticky!!! I've been searching for these and making sure I don't spend $85 on the wrong parts! Thanks for posting this! I didn't want to accidentally order the interior moldings! haha
    Xsnrg2006 likes this.
  9. Jun 30, 2020 at 9:21 AM
    kulrick87
    kulrick87 New Member
    What’s the part number for the back window trim for my 2018 With a roll down style back window
  10. Jul 12, 2020 at 10:10 AM
    snufus
    snufus New Member
    Daniel
    2006 Tundra SR5 DC
    @Roman thank you so much for this! Do you know for the dual cab (2006) does the rear drivers side belt molding include the little piece of rubber that goes over the belt molding and the other piece of trim (corner join)? I need that little piece of rubber but that is not listed on any of the diagrams for the rear door trims?
    Thank you good sir!
    Roman[OP] likes this.
  11. Jul 14, 2020 at 2:32 PM
    Roman
    Roman
    Franklin, TN
    Yep, it sure does.
  12. Oct 17, 2023 at 7:00 AM
    desert_al
    desert_al New Member
    Alec
    2004 TRD DC
  13. Mar 9, 2025 at 8:28 AM
    Thundra04
    Thundra04 New Member
    Keefer
    2004 Toyota tundra sr5 4x4 double cab 4.7
    -Fuel injectors (dirty deeds) -Cold (hot?) air intake -Long tube jab headers -Down pipe, American thunder exhaust -Tow package -Blow and go
