Beeping while driving
Discussion in '2.5 Gen Tundras (2014-2021)' started by KERNEL_DALE, Dec 21, 2022.
  1. Dec 21, 2022 at 12:34 PM
    KERNEL_DALE
    KERNEL_DALE [OP] New Member
    Norcal
    19’TRD-PRO
    hi guys was wondering if any of you experienced this.
    Just heard this annoying beeping sound while driving but when the vehicle is on stop. Beeping gone. Also this is on display on my dashboard.
    need your inputs how to troubleshoot it. Thanks
    Unionstreetwolf likes this.
  2. Dec 21, 2022 at 12:37 PM
    RustyShackle323
    RustyShackle323 New Member
    Stewart
    NC
    2019 Platinum - Barcelona Red
    Highly suspect it’s your lane departure that you have turned on. It’s the green little car in the top left corner of your screen under the ambient air temp.
    I have that turned off on mine.
  3. Dec 21, 2022 at 12:40 PM
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    I did turn it off still it beeps plus the display still the same ( truck )
  4. Dec 21, 2022 at 12:41 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Try disconnecting the battery for 15 min and see what happens.
    1lowlife likes this.
  5. Dec 21, 2022 at 12:43 PM
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Will try it in a few. Thanks
  6. Dec 21, 2022 at 12:44 PM
    Junior 88
    Junior 88 New Member
    Junior
    18 tundra Sr5
    7inch bds on 35s
    Seat belts?
  7. Dec 21, 2022 at 12:46 PM
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Seat belts are not in use as of this moment.
    only mine is in used ( driver )
  8. Dec 21, 2022 at 12:56 PM
    RustyShackle323
    Stewart
    NC
    Is your hood popped? When the truck shows up on the screen like that, it is usually the result of a door being open or the hood popped. Check your hood latch.
    Txexplorer23 likes this.
  9. Dec 21, 2022 at 12:58 PM
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Its closed..
  10. Dec 21, 2022 at 1:03 PM
    RustyShackle323
    Stewart
    NC
    OK. Still doesn’t totally rule that out though. Open the hood and or peak behind the grill and inspect the connector. The highlighted harness then runs up behind the latch assembly which I suspect is some kind of switch similar to the doors.
    Also, make sure all your doors are all fully closed.
  11. Dec 21, 2022 at 1:29 PM
    JDR76
    JDR76 New Member
    WA
    2021 1794 TRD OFF ROAD
    On mine, if I get the beeping and that view of the truck showing up on my display, the view usually shows a parking sensor illuminating, or a door/hood open, etc. I have never seen it just come up without indicating what the actual issue is. I checked the owners manual, which shows the errors that come up on the display, and there isn't one that just shows a truck without anything else.
    This makes me think there is something wrong with it. Odd things pop up like this from rodent damage, bad battery, etc.
    Jaypown likes this.
  12. Dec 21, 2022 at 1:43 PM
    bflooks
    bflooks New Member
    Metrowest MA
    Roll forward and see what happens.
    For me, the hood doesn't really show until I move, then it lights up in an orange outline and beeps at me. Took me by surprise the first time it happened.
    Could be any number of things, but the dash will light up where the issue is. Is your parking assist even enabled (bottom right of steering wheel panel, P symbol, green light if on) will beep at you everytime.
    Otherwise, as mentioned, the lane departure could be picking up the lines of the road. Gotta watch the dash while moving, though, so be safe.
  13. Dec 21, 2022 at 1:55 PM
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    Found the culprit. Loose connector to the latch.
    Thank you all for your vital inputs
    thanks @RustyShackle323
  14. Dec 21, 2022 at 1:57 PM
    JDR76
    JDR76 New Member
    WA
    Great! Thanks for the follow through and letting us know what it was.
  15. Dec 21, 2022 at 1:58 PM
    KERNEL_DALE
    Norcal
    19’TRD-PRO
    This thread really helps alot from upgrades to crazy troubleshooting tips.
    again i do appreciate all your time and suggestions. Thank you all once again.
  16. Dec 21, 2022 at 2:01 PM
    RustyShackle323
    Stewart
    NC
    Awesome! No problem, glad to help!
  17. Dec 21, 2022 at 3:18 PM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Good find. Hopefully this also helps someone else down the road with the same issue!
  18. Apr 20, 2024 at 9:15 PM
    Unionstreetwolf
    Unionstreetwolf New Member
    Paul
  19. Apr 20, 2024 at 9:26 PM
    Unionstreetwolf
    Paul
    Glad I found this post thread. Have a recently purchased 2021 tundra had same issue. Thought a door wasn’t closed all the way then noticed hood wasnt closed when I got home after I did a second walk around later that night. Truck was previously parked for a few hrs while was out to dinner. Hood not being closed caused the beeping but now have to get wiring repaired. Some loser apparently tried to steal the battery or awful attempt to Hotwire it.
    Glad I found thread though I was concerned I was having a major check engine issue. Never thought that alarm would be for a door or hood not being closed.
    have a great weekend everybody
    1UP, 1lowlife and KERNEL_DALE[OP] like this.
  20. Jul 24, 2024 at 10:17 AM
    10Silvertund
    10Silvertund New Member
    Rolf
    2010 Tundra SR5
    Check parking brake as well.
