Bed step drama continues - need help
Discussion in '3rd Gen Tundras (2022+)' started by jmtz9, May 1, 2022.
  1. May 1, 2022 at 10:11 AM
    jmtz9
    jmtz9 [OP] New Member
    So I ordered the bed step part# PTS30-34000 which included part pts30-34000-bk, and pts30-34000-st.
    I opened the boxes up and I only got what you see here. I'm missing the other hardware (bolts). Does someone have the "FULL" installation directions with all pages that can share it? Also, does anyone have the sheet or know the specs of all the bolts that are needed to install? Needless to say, Toyota is not including installation directions in the boxes, and for the hardware to be missing is a huge miss.
    If anyone can help provide the info - greatly appreciate it.
  2. May 1, 2022 at 10:23 AM
    Acedude
    Acedude New Member
    Colorado Plateau
    2019 Sequoia SR5 4WD
    RCI aluminum front skid, Timbren rear bumpstops, Carhartt seat covers and cargo area cover, Weathertech floorliners, Hewitt SAIP bypass, genuinecoolingsystems trans cooler, Lexus front diff fill/drain plugs
    Esterdahl did the install. Mentions some Allen bolts that you may not have.
    https://www.youtube.com/watch?v=3sv9VckzWQY
    chiefbob likes this.
  3. May 1, 2022 at 10:26 AM
    jmtz9
    Thanks. I saw this several times but wanted the instructions he has. I am hopeful the specs for the bolts are on there as well.
  4. May 1, 2022 at 10:33 AM
    Wallygator
  5. May 1, 2022 at 10:40 AM
    jmtz9
    Wallygator[QUOTED] likes this.
  6. May 1, 2022 at 10:53 AM
    Wallygator
    I don't. I have never installed one. From what it seems the only difference would be the bumper designs from the two generations. It looks like the step is actually made by AMP Research. An it looks like it's the same step from the previous gen from yours. Maybe search for something on that. Here is a video I found
    https://www.youtube.com/watch?v=oZc1CIXNB4I
    Black Wolf likes this.
  7. May 1, 2022 at 10:59 AM
    Wallygator
  8. May 1, 2022 at 11:01 AM
    jmtz9
    Thanks, I checked everything out and it's not really helpful though. You would think the instructions for the exact part wouldn't be such a mystery. I appreciate you trying to help though.
    Someone out there has to have a copy.
  9. May 1, 2022 at 11:03 AM
    Wallygator
    Yeah sorry couldn't find the mystery instructions. Maybe goto a dealer near you and ask them for the instructions. Good luck and hope you find a solution soon.
  10. May 1, 2022 at 3:22 PM
    chiefbob
    chiefbob New Member
    I would contact Amp Research.
    They were very helpful when I contacted them about the OEM step and said it would be a few months for availability of the step.
    Wallygator likes this.
  11. May 1, 2022 at 3:51 PM
    Maharisc
    Maharisc w/Patty
    Karl
    2023 Tundra Platinum MBM Hv CM Adv Pkg
    Build date: 12/05/22
    elgreco likes this.
  12. May 1, 2022 at 7:12 PM
    KClav
    KClav MGM Limited
    2022 Tundra Limited CM MGM TRD OR
  13. Jul 6, 2022 at 1:01 PM
    southdunes
    southdunes New Member
    2022 Tundra Limited CrewMax
    Mine finally arrived and was missing the 2x M10 1.5 bolts for attaching the step to the sub assembly. Was able to find what I needed at THD, but still irritating to pay for overpriced parts and find them missing necessary hardware for install. That said, installed without issue and works as expected. For those needing to buy bolts, be sure to buy the correct threading (1.5).
    KClav likes this.
  14. Jul 6, 2022 at 1:52 PM
    FomoToyo
    FomoToyo Lunar Rock / Terra Enthusiast
    Jake
    Frederick MD
    2024 Tundra TRD Pro Terra
    M10 x 1.5 is the standard / most common pitch at least. If not specified that is usually what it is.
