Bed shaking
Discussion in 'General Tundra Discussion' started by GWRN1842, Jul 1, 2025 at 7:32 AM.
  1. Jul 1, 2025 at 7:32 AM
    GWRN1842
    GWRN1842 [OP] New Member
    Greg
    New york
    2025 tundra SR5 V6 twin turbo non hybrid
    None
    Hello, I have a 2025 tundra SR 5, my bed shakes pretty bad at times it’s even noticeable in my side mirror. It doesn’t do this all the time, I have tire balance checked and that is good. It’s under warranty, but can anyone give me any ideas or information if you have had same issue? I have not had it to the dealer yet. Thank you
  2. Jul 1, 2025 at 8:09 AM
    Retired...finally
    Flat spots on tires?
  3. Jul 1, 2025 at 8:50 AM
    GWRN1842
    Greg
    New york
    None
    No, it’s does it on different roads depending on how ruff the black top is. Some roads it’s nice and smooth. It has done this since it was new, it’s more noticeable now because I put one size bigger tires from stock. The suspension has all ways been super sensitive to the road. Thanks for the reply
  4. Jul 1, 2025 at 9:02 AM
    GWRN1842
    Greg
    New york
    None
    I honestly think it’s the stock shocks, I bounce on the bumper, then let it go and it hops more than it should. I’m thinking about bilsteins 6100 series.
  5. Jul 1, 2025 at 9:04 AM
    AZxp
    AZxp New Member
    '23 on 3.ohs and dirty sevens
    Just flex. On icon 3 inch diameter shocks and same thing. No improvement to bed shake after new shocks
  6. Jul 1, 2025 at 10:16 AM
    GWRN1842
    Greg
    New york
    None
    Thanks, it can shake really bad. It’s my first Toyota so I’m not familiar with the trucks.
  7. Jul 1, 2025 at 10:25 AM
    blenton
    blenton New Member
    Since truck beds are detached from the cab and are hard-mounted to the frame instead of rubber/poly body mounts, they will shake, especially if unloaded and on stock suspension. It's part of owning a pickup. Certain types of road surface will exacerbate the condition - as you have discovered.
    Different shock absorbers will help, but not totally eliminate it. The stock shocks are decent for what they are, but there are much better options out there. As well, the stuck rear springs leave much to be desired; very functional and carrying a load, but not great for other things. Depending on what you do with your vehicle, you may want to look in to a more comprehensive rear suspension overhaul to better meet your needs.
    Or throw a couple hundred pounds in the bed and help dampen it. I'm told tubes of sand are cheap and easy to remove if needed.
    EmergencyMaximum likes this.
  8. Jul 1, 2025 at 10:40 AM
    GWRN1842
    Greg
    New york
    None
    I will try that, I’m 55 and have owned only pick ups, this is my first tundra and the first truck I have owned that has this shake it shakes so rapidly it’s like riding in a car with a bad strut. And it’s my first truck with this type of suspension (not leaf) takes a little getting used to. My old lady and I get pretty good back massages from the seat LMAO thanks again
  9. Jul 1, 2025 at 11:00 AM
    blenton
    blenton New Member
    I misread your first post and was thinking you had a 2nd get truck. The 3rd Gen coil spring suspension shouldn’t behave like that. Does it only shake when the suspension is excited, like from hitting a bump in the road? Or is is constant or cyclical, independent of the road surface?
  10. Jul 1, 2025 at 12:12 PM
    GWRN1842
    Greg
    New york
    None
    When the road is slightly ruff, it begins as a slight shake then gradually gets worse until road smooths out. It like someone is constantly and consistently shaking the back bed. It’s not all the time only certain roads make it act like this.
  11. Jul 1, 2025 at 12:14 PM
    GWRN1842
    Greg
    New york
    None
    Once she gets going it gets pretty bad.
  12. Jul 1, 2025 at 12:21 PM
    GWRN1842
    Greg
    New york
    None
    I just purchased a set of bilstein 6100, I’m going to give this a try. I have checked everything I can and it seems to be to much extra travel when you push up and down on the bumper and let off. I have had good luck in the past with this brand, if not off to the dealer.
  13. Jul 1, 2025 at 12:26 PM
    Retired...finally
    Is the shake always the same frequency? If you think it is, try adding some weight like previously suggested.
  14. Jul 1, 2025 at 12:30 PM
    GWRN1842
    Greg
    New york
    None
    I put some sand bags in the back like you suggested and I’m going to go for a drive at 530 EST. The frequency always ends up the same, it starts off light gradually increases then gets to a certain point and doesn’t get any worse.
  15. Jul 1, 2025 at 1:42 PM
    blenton
    blenton New Member
    Is it a concrete freeway in particular? There is one highway that is concrete that does the same thing to my truck when I’m unloaded.
    BTW, everytime I read ‘Bilstein 6100’ I want to correct you that they are either 5100 or 6112… then I remember that they introduced the 6100’s and are available for 3rd gens. But every time I read it… Must be out of jealousy that we only got 5160’s. Or old habits. Haha. I really liked my Bilstein setup; hopefully they help the situation.
  16. Jul 1, 2025 at 1:46 PM
    Retired...finally
    Try putting the weight in different places. In the middle may not change anything. Corners should work best.
  17. Jul 1, 2025 at 2:37 PM
    Foster1
    Foster1 New Member
    2023 TRD Off Road
    Some bed shaking is pretty normal. All trucks do it.
    If you think it’s excessive you can check the bed bolts to see if they’re loose. Also what tire pressures are you running?
  18. Jul 1, 2025 at 4:45 PM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    What psi are your tires?
    blenton likes this.
  19. Jul 1, 2025 at 5:14 PM
    Leo's first
    Leo's first TRUCK GANG
    Groton ma
  20. Jul 1, 2025 at 5:36 PM
    Retired...finally
