Bed Rail System
Discussion in '2.5 Gen Tundras (2014-2021)' started by Ahutch_6, Aug 31, 2020.
  1. Aug 31, 2020 at 12:20 PM
    Ahutch_6
    Ahutch_6 [OP] New Member
    2017 Toyota Tundra SR5 crewmax
    Anyone got a link to a installation video for a bed rail system? I am trying to figure out if I can put a bed rails system on my 2017 Toyota Tundra Crewmax with a spray in bed liner.
  2. Aug 31, 2020 at 12:21 PM
    Porkchop Express
    Porkchop Express Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    yes you can.
    I just used some unistrut and stainless steel bolts. I think i was around $40 for parts and three beers for time.
    BlackSheep and Sunnier like this.
  3. Sep 3, 2020 at 6:52 PM
    SuperWhite20
    SuperWhite20 New Member
    Robert
    Georgetown TX
    2020 Tundra Crewmax SR5 4X4
    TRD Sway bar. Deck Rails, Maxliner rear floor mat, Driver side grab handle. Dee Zee bed mat
    Yes! I put it my 2020 SR5. Just get a tap to clear the liner material out of the holes before bolting it up. I believe (without going in the garage) it is an 8mm x1.25 Tap.. which you can get at Lowe’s or Home Depot. Or any parts house. I tapped them out while waiting for my order to arrive. Took about 20 minutes to install the three rails. I ordered the PFCC Tacoma cleats as they are black and look much better. Also the little tie downs too off Amazon.
  4. Sep 3, 2020 at 7:18 PM
  5. Sep 3, 2020 at 8:00 PM
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    I just did this a couple weeks ago. Two 10' superstrut channels, a handful of m6-1 bolts and washers, and about an hour's time is all you should need.
    glowblue likes this.
  6. Sep 3, 2020 at 8:13 PM
    jr1016
    jr1016 New Member
    Ric
    Sacramento, CA
    2020 CM TRD Sport
    No need to tap the hole. I have a spray on bedliner on my truck and when I installed it I just poked the holes and put the screws it came with through it. The thread doesn't start at the edge.
  7. Sep 4, 2020 at 2:21 AM
    ezdog
    ezdog New Member
    Gateway To The West
    I have had it both ways and I bet it depends on the job done with the liner.
    Not a deal at all though to chase the holes with a Tap real quickly to make sure there is less frustration when mounting the rails,is it?
    You can get a Tap for under $10 so I suggest running it through the holes whether needed or not.
    But yeah you can mount a bed track if you can turn a screwdriver!
